Outdoor fan stop.but compressor running.termostat showing code e2
    Master:
    Sergeant:
  • 388 Answers
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
Air Conditioning Boca Raton
Posted on Apr 15, 2015
Compressor runs after 5minutes stop.kollin 1hp split wall inverter
Check thermostat setting outdoor unit fan motor its possible outdoor unit fan motor not running then its possible to compressor getting heat up and trip off .
Jul 24, 2016 | Inverter Heating & Cooling
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
My ac central air is blowing air but not cold
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device known as a "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning compressor. Another good device is called a "5-2-1" kit.
Jun 22, 2011 | Goodman CKL36AR36 Air Conditioner
Shows e2 on outdoor pc board and shows fan and timer on the indoor unit
try shutting off all power to indoor and outdoor unit. tighten all electrical connections, including grounds, power up and check again. let me know.
Mar 06, 2011 | Heating & Cooling
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Air condition. not cooling the house
Have you clean it at all?How about the filter?I would do those things first before I get someone to charge it.
Mar 26, 2009 | Coleman Mach III Air Conditioner
Oasis drinkingfountain - Why would fan run continually? Cools wel
The fan and compressor run at the same time.
Both get power from the on/off cold control termostat.
1.Defective thermostat.
2.Compressor not cooling.
If the water is chilling go to #1.
Mar 12, 2009 | Oasis P1AQ
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
