Question about Pool & Spa
I have a Polaris 280 and one of the two screws that holds one of the wheels on is stripped.
The pool store wants me to buy a new Polaris, but I thought I would ask if there is another less expensive fix as it is otherwise working fine.
  • 1,631 Answers
You are referring to the wheel axle. The axle is held together to the vac sweeps base, with two bolts and nuts. What you can do, is remove the stripped one, going thru to get another new STAINLESS STEEL, bolt with a matching nut, and tighten it from the bottom. You will need to get access to the bottom, by removing bottom cover - two fasteners hold that.
Don't be intimidated, it doesn't matter what you use - a bolt or ???, you just want to secure the axle to the base. I would recommend a bolt and nut.
I added a link below, to show a diagram of the unit all taken apart.
Area of significance: Parts 13-16 The nuts, are recessed in a small Divet in the bottom of the middle bass.
Vac Sweep 280
Posted on Apr 16, 2015
  • Mike Tellegen Apr 05, 2016
    Where I mentioned 2 screws: That was in reference to the "AXLE" as it attaches to the main center portion of the cleaner. Yes, I agree the "Wheel" ***** is only 1 ***** and it is plastic. They break commonly - head comes off or the slot is stripped. If the head is gone or non usable with a screwdriver. Drill a hole then ***** in a wood ***** - not too tight, otherwise you risk tightening broken plastic ***** shaft. Use a drop or 2 of SuperGlue in the drilled hole, then let sit. Once dry & cured, use a ***** driver to unscrew the ***** and "Voila", out comes the broken ***** shaft.
  • 3,287 Answers
I was looking at photos and I see only one screw holding a wheel on - so I'm perplexed as to how two screws would do this and still be able to turn.
Anyway.. the generic way of solving a stripped screw hole is to drill and tap the hole to the next size greater screw and supply a new screw that would match the hole and tapped threads. You would also need to enlarge the hole(s) of whatever the screw passes through (wheels?).
If enlarging holes isn't an option, consider filling the hole in. A recommended material is JB Weld. Consult the web site to help you select the JB Weld product that would work best with the material that it will be in contact with. Apply as per instructions. Allow to cure / setup. Then, drill and tap the hole to match the original screw. reassemble.
JB Weld World Strongest Bond
Posted on Apr 15, 2015
Polaris 280 wheel tilted
see if inside wheel mount broken or loose
Jun 10, 2012 | Polaris 280 In - Ground Pool Cleaner with...
My wheels are not turning on polaris 280
Make sure that your thrust jets are properly positioned. You will also want to check for any obstructions in the wheels or axles that would restrict movement. Often with these automatic pool cleaners, one of these two problems is causing restricted movement in the wheels.
Jul 02, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Pool sweep wheels are not turning
Problems with the sweep hose on these pools cleaners usually just means that you need to do some fine tuning. Start by trying to adjust the sweep hose adjustment screw. To adjust, turn off the booster pump and turn the screw clockwise to decrease motion and counterclockwise to increase. You might also need to replace one or both of your swivel ball bearings (part #D20).
May 19, 2010 | Polaris 280 In - Ground Pool Cleaner with...
How do i change the axle of a polaris 280 pool cleaner. I am trying to change the axle on my polaris 280 pool cleaner. I can't seem to get the top off so that I can reach the screws to change it out. ...
Here is copy of the users manual for these pool cleaners. It has a detailed diagram of all of the parts that is pretty easy to follow. Find the section that you need to change and you should be able to see how to access it. Hope that helps.
http://www.backyardcitypools.com/images/Polaris/Polaris-280-manual.pdf
Oct 10, 2009 | Polaris 280 Black Pool Cleaner
My wheels are not turning on my Polaris 280, what can I do?
When my polaris wheels stopped spinning it was the water jet which spins the turbine was clogged. The in-line filter had failed and some small debris had passed through to clog the jet. Easy fix to take off the top cover then take off the turbine cover and examine /clear the hose (clamped on by zip ties) and the plastic jet.
Jul 27, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 280 - tank track keeps coming off
I battled with the track falling off for over a season. The pool guys said they fixed it. Tried the previous solution to adjust middle wheel but no luck. My solution was to remove the left wheel and the tank (to get to the screws). The wheel mount allows for minor adjustment but it is also reversible. Turn the mount around and this will extend the wheel base much more. Mine ran for several hours after doing this and so far the track stays on.
Dec 28, 2008 | Polaris 280 In - Ground Pool Cleaner with...
Pool & Spa Logo
456 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
