Question about Garden
What does each prong on switch go were. It's a 5 prong switch.
  • Kprime
    Kprime Apr 15, 2015
    Hi Robert Phillips, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one. If you haven’t already done so, add a short description of the events preceding the beginning of the problem.
  • 2,963 Answers
Recommend repair manual. Try MFG website, or email their customer service, or try manualslib.com
Posted on Apr 15, 2015
Hy My Beko f freezer compressor gets very hot (can hardly touch it). Unable to source replacement ptc switch although the unit still restarts, it looks burned! Prob causes? Any suggestions please?
TRY THIS
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, sometimes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms, u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE
A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1
Feb 11, 2017 | Beko Refrigerators
I hear it starting up, then after few seconds it stops and the most left right light (ref temp 5) keeps blinking on and off. Please help xx
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
May 22, 2015 | Refrigerators
My fridge starting after some time stopping and not starting it self unless switch off power supply and then on it will again in auto
May 01, 2015 | Refrigerators
How do you properly wire a 2 prong rocker switch into a model M50A forced air kerosene reddy heater
If the switch has only two prongs, it has to be a single pole, single throw switch. This means that you just attach the prongs to the old switch wires. It doesn't matter which prong goes to which wire.
Dec 18, 2014 | Cars & Trucks
Can you wire a 2 prong rocker switch into a model M50A kerosene forced air reddy heater
If you are asking if it's possible to add a switch where none was before, it is. Just cut the hot wire and attach each side of it to each prong of the switch.
Dec 18, 2014 | Reddy Heating & Cooling
The driver's window is the only one with a relay. The regulator and motor are good. My problem is either the relay or the switch. The window relay on this car has 5 prongs. I went to a junk yard and...
The problem is you.
Sounds as though the switch is bad, and you need to go to a dealer and buy the correct one.
Why you would be in a junk yard, is beyond me,unless your employed there.
Why would you use a 4 prong unknown relay from a yard, instead of what you know is the correct one,a 5 prong?
Before you take on any more electrical challanges,go to night school for a basic coarse, before you short out something and ruin your vehicle
Sep 20, 2010 | 1998 Ford Contour
Inertia swich
Dodge dosent have a inertia switch the relay should have battery voltage on one wire with key on, ground on one wire,and when cranking the car another wire should get power but only while cranking and teh last wire will be power going out to you're fuel pump
Jan 10, 2009 | 1993 Dodge Dakota
Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Mar 15, 2008 | Cooktops
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
