Why does machine smell of stale water - Washing Machines
  • 1,602 Answers
You most likely have hose leak some where on one or more lines coming into the washer, need to check both water lines from the wall and the machine itself. it mite be a little drip once in a while, but it is building up or storing the water in the drain pan.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
IF YOU HAVE STACKABLE SYSTEM CHECK THE DRIP PAN UNDERNEATH THE WASHING MACHINE.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
check the overflow line to inspect for cracking, or is the machine balanced while it spins.
the water in setting in the bottom of the washing machine, going to have to be taken apart and dried out,
Posted on Apr 14, 2015
Smell of stale water from Avanti compact washer
It may not be draining very well.
I have a front load washer and run a cycle of a few cups of bleach through mine every couple months.
I also add vinegar to most washes but that's due to my teenage son's athletic wear.
Both those things do the trick.
You shoudl probably check the mechanics as well but the above is a stop gap.
Sep 14, 2012 | Avanti W789SA Top Load Washer
My dryer smells like an old wet wash cloth. It has a stale water smell to it and is making my clothes smell like it. I can smell it when i open the door and stand right in front of the dryer opening. the...
There is a very simple way to get rid of unwanted smells. I would suggest use a cup of white vinegar every wash to clean from stale muck and smells inside the machine.
Jul 24, 2017 | Dryers
Stale water smell in laundered towels and clothes
usually this is as simple as overloading the washer,, Its not able to drain out all of the dirty water so it smells foul,, try a smaller load,
May 25, 2011 | Samsung WF337AA Front Load Washer
Inside smells like stale water
YOU NEED TO RUN A (CLEAN CYCLE) ON THE WASHER.THIS CAN BE DONE WITH A 1/2 CUP OF AUTOMATIC DISHWASHER SOAP AND HOT WASH CYCLE. YOU SHOULD BE ONLY USE 2 TABLESPOONS OF H.E. SOAP IF THE WASHER TO PREVENT THIS
Apr 26, 2010 | GE WBVH6240F Front Load Washer
Mildrew, stale water smell in laundry
Run a very hot wash on your machine with no load
Fill a bucket with a strong solution of soda crystals and pour it into the machine first
Add some more crystals to the soap dispenser
Use an old fashioned soap powder for a couple of washes as well and reduce the load slightly
Modern soap powders do not contain certain bleaches and soda and the 40 degree wash leaves body fats and oils inside which cause odours
Jul 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Stale water smell
washer is under warrenty so called a repair man
May 18, 2009 | Roper RAS8244LQ Washer
Kenwood coffee machine stale smell
I used white vinegar and ran it through with hot boiling water about three or four times worked a treat
May 17, 2009 | Cuisinart 12 Cup Digital Thermal Coffee...
Samsung washing machine smell
Keeping the lid shut is one of the worst things you can do for a washer. Obviously, the company you spoke to does not know what they are talking about. It is strongly recommended that you leave the lid OPEN when not in use in order to ventilate the wash tub and allow it to dry. There is always a small amount of residual water in the drain pump and lines, however, that will not evaporate. With the lid shut this residual water can sour and cause odors.
Consumers that do not normally use a HOT water cycle, do not use bleach, or run the washer infrequently can also experience odor problems with mildew and odor. It is recommended that you run at least one HOT cycle per week, or run a cycle with bleach when washing whites to keep bacteria and odors to a minimum. I hope this advice helps you. Let me know if you require further assistance.
Oct 25, 2008 | Washing Machines
Stale smell on crockery after wash
Most commonly, this relates to sulfides or other impurities in the water itself, but may also be caused by a buildup of food soil within the washer. Smell a clean glass of water. Does it smell stale also? If no, clean the screens and wash water sump/tank within the machine.
You can also clean the inside of the machine by using a commercial grade dish machine detergent and increasing water temp if possible.
If the water smells stale, consult a local water expert for guidance in resolving
Aug 19, 2008 | Dishwashers
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
