Question about Dryers
Latch for my dryer
The latch to keep the door closed on my dryer broke need to replace it
  • Dryers Master
  • 473 Answers
If you post brand and model I can usually get you the part number and suggest several sites to purchase.
Posted on Apr 16, 2015
  • 2,992 Answers
Try eBay, or one of the online appliance parts stores. They have been quite helpful to me.
Posted on Apr 15, 2015
  • 185 Answers
SOURCE: kenmore 90 series gas dryer door will not stay closed
try adjusting the door
Posted on Mar 24, 2008
  • 32 Answers
SOURCE: Door won't fully latch, light stays on, dryer won't function
There is typically a small plastic piece that catches the door and keeps it latched. The door has the male side and the frame of the dryer has the female side.
Either the male part on the door has broken off (or bent) or the the female part on the frame has broken. Replace this part and you'll be back in business. It is typically called a door latch and it comes with both the male and female parts.
Here is a picture
of a typical one.
Posted on Sep 23, 2008
  • 8 Answers
SOURCE: Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Posted on Oct 25, 2008
  • 244 Answers
SOURCE: broken latch on dryer door
buy new latch and striker. cheap.
Posted on Jan 17, 2009
  • 240 Answers
SOURCE: My Kenmore 90 dryer door keeps popping open
best way is to take door off and take it apart, metal tabs inside hold firm to door body.
Posted on May 03, 2009
How do I replace the door switch
Go to espare.com and watch the vidios about that
Dec 04, 2015 | Hoover Vision HD VHC691B White Electric...
Hey , I have a 1997 t-bird and I need help getting a name for a part , I don't know how to fully describe it , but a part to my door latch broke , and it's keep the door from closing all the way , the only...
It's called the door latch. You can't buy parts for it. You can buy the whole mechanism though. Or get one at a junkyard. A spring or small pin has broken inside of it. I tried to many times to find parts for the inside of these things. No luck.
Nov 03, 2014 | Cars & Trucks
Hi my creda t522vw dryer door won't close
This has happened on some of the front load commercial dryers in one of my building. The door alignment pin that mates with the latch was not meeting in the center of the latch. On one of the dryers the latch pin broke, I replaced the pin and thought I had fixed the problem. After a second parts search and realizing how much work it would be to open the front of the dryer to replace the hinge, I opened the door just enough to clear the housing and lifted up on the latch end of the door to try to bend the hinges back up. I had to pull up with more force than expected, but the door alignment was better and the latch mated properly. I then got out my RED Sharpie and wrote on the top of the, "PLEASE DON'T LEAN ON THE DOOR" The problem has not returned.
I hope this was helpful.
Jun 02, 2014 | Dryers
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer door won't stay shut latch won't catch
If this specific dryer has the door that opens forward (top to bottom as opposed to left to right, etc...) the common problem is that downward pressure on the door has bent it slightly. This happened on mine when one of my daughters would lean on the door while loading and/or unloading the dryer. If this is the case, then the door may pop open while running even though the latch looks good.
The best way to tell is just let the door rest naturally in the closed position. If it does not rest all the way closed, then the lower portion of the door & frame has been slightly bent as indicated above.
The door & frame has to be slightly bent/forced back out at the bottom. This can be accomplished with a large screwdriver or something similar such as a paint mixing paddle or basically anything that will fit between the bottom of the door (from the inside) and the dryer frame. Very slowly close the door with the paint paddle or large screw driver in place (again on the inside...not from the outside of the door). The goal is to just barely force the bottom of the door framing back out without warping it grossly.
Just take your time and be as gentle as possible & make small adjustments until the door will remain closed and latched.
The latch is really only required to keep the door secure while clothes are beating against the door interior. Proper alignment actually keeps the door closed.
Let me know if this helps.
May 06, 2010 | Whirlpool LEN2000PW Dryer
2002 F-250 door not register that it closed
The sensor is inside the door and is part of the latch to close the door. It has either come loose or is broke and you will need to replace the actual latch inside the door that keeps the door closed.
Mar 19, 2010 | 2002 Ford F250 Super Duty SuperCab
I HAVE A KENMORE 90 SERIES AND THE DOOR KEEPS ON OPENING, SO I TOOK ALL OF THE CLOTHES OUT TO SEE IF THERE WAS TO MUCH IN IT, AND EVEN WITH NO CLOTHES IT OPENS?? IT DOSENT APPEAR ANYTHING IS BLOCKING THE...
Inspect the door and when you open it, does the latch hold the door closed? If not the dryer door / latch may need to be replaced.
But check the door as it opens... the door hinges may have been damaged, causing the door to not close properly and the latch may not be damaged, only the hinges.
Good Luck!
Jan 03, 2010 | Kenmore 62602 Electric Dryer
Dryer door will not stay latched and causes dryer
ew whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Dec 20, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Door locks flipped around and now doors will not close
Most likely your door latch is broken and needs to be replaced. First, try to use a screwdriver and see if the lock jaw will reopen and when door is closed, if it will work properly. If it will not open or does not keep the door closed, it is broke and needs replacement.
Oct 01, 2009 | 2002 Kia Rio
Here is a picture
of a typical one.
Sep 22, 2008 | Dryers
Dryers Logo
Top Dryers Experts
