Question about Ford Garden
Oil type in hydro transmisson
1997 ford new holland LS45 lawn tractor
2 Suggested Answers
  • 12 Answers
SOURCE: Ls45 ford/new holland lawn tractor burns fuses
Your describing a direct short either the switch or the wiring. The fuses are doing there job keeping somthing from burning up. I would suggest having the the unit looked at and find out where the short is and have it fixed.
Posted on Oct 06, 2014
Ls45 ford/new holland lawn tractor burns fuses when i turn the ignition on i replace fuses and it does it again what causes this?
Hi, The problem is a dead short in the wiring, you will need to trace the wiring from the ignition and look for any burnt, broken, or bare wires that are causing a short, once found just re insulate or replace the damaged wire
Oct 06, 2014 | Garden
How can i find parts for a 1971 ford lawn tractor serise yt-16-g?
Salvage yard for old mowers or new Holland bought out ford so try a dealer near you with your numbers,or someone on fixya may have what you need
Jul 23, 2014 | Garden
Where can i find parts for a 1971 ford lawn tractor serise yt-16-g
Try a New Holland dealer. Here in Canada that's about the only place for old ford parts
When checking transmission fluid in
if it is hydrostatic change filter and oil in the tranny you will be suprised just by doing that how many tranny problems are fixed plus it sounds like it dosnt enough fluid in it only other option replace hydro pump expensive you have to look at tractor is it worth it
Sep 15, 2013 | Toro Garden
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
How do you change the oil in a mountfield LS45 Lawnmower???
While I am not familiar with this brand, typically, in a four cycle lawn mower engine, there will be a oil drain plug in the bottom of the engine or on the lower part of the engine above the deck.
Thanks for your question @ FixYa.com
May 19, 2011 | Garden
Cub cadet hydrostatic transmission new lawn mower, hydro growls pretty bad when taking off, is this normal for the 1045 or 2045 series?
check the hyro oil level is up to the correct mark. but some hydro units make a noise if you set off on full revs quite rapidly
Jun 11, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Need a downloadable parts diagram for a Ford YT16H lawn tractor.
go to New Holland's web site they have all the info you need,heres the web site just type in "YT16H" in the parts search box and all the years will show up. Its not downloadable but you can certainly print out what you need.
https://webparts.pvassociates.net/cnh/webparts/main.php
Jul 14, 2009 | Ford Garden
I need an electrical wiring diagram
New Holland bought out Ford's lawn equipment division. You can contact your local New Holland dealer and purchase a manual for you lawn mower. The manual includes wiring diagrams. Or you can order a manual from New Holland online via this link https://www.newhollandtechpubs.com/. Hope this solves your headache.
Mar 30, 2009 | Ford Garden
Garden Logo
137 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
