Question about Sony CFD-E10 - boombox - CD
How can i remove case on Sony Boombox CFD-E10?
Power intermittent when plugged into AC adapter. Seems like bad connection on printed circuit board - needs resoldering. Removed all (i think) screws, but can't remove case and don't want to break.
SOURCE: Sony CFD-E95L disassembly
There are 11 screws that need to be removed: Bottom - 2 on both sides of the word "ATTENTION"; 2 on the outer edge at the three and nine o'clock positions; 3 under the handle; 2 in the CD player compartment; and 2 in the upper left and right corners of the cassette compartment.
Posted on Mar 16, 2008
SOURCE: How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
Posted on Jun 12, 2008
  • 4 Answers
SOURCE: auxilliary jack for sony cfd-646 boombox
Are you interested in selling your sony cfd 646? i'm looking for spare parts! if so, contact me at: lizzymariascott@att.net
Posted on Apr 06, 2009
  • 561 Answers
SOURCE: how do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Posted on Jan 01, 2010
SOURCE: CFD-S300 Sony Boombox lost power cord
What should be the secondary voltage be on 115 volt primary transformer off the power cord for the CFD-S300
Posted on Aug 23, 2010
Sony cfd-s01 boombox radio
Hi Bart,
You will find there is a specification plate on the rear of the unit.
It should have a rating on it showing the wattage of the unit. This is usually the amount needed to operate all the functions of the boombox.
The wattage is your input voltage multiplied by the current draw in amps. So the amperage is the rated wattage of the unit divided by the input voltage.
Usually all power goes through the transformer, so I would use this input amperage as a guide, and assuming there is no power loss, use the same calculation for the output - you know it is 9 volts, so the wattage going to the unit is the same as the input wattage, so you can calculate the amperage from this.
Transformers usually work on AC input/output, so there will also be a rectifier to convert the AC to DC for your boombox.
I would add 10 - 20% above your calculation to make sure you have sufficient power. Also I suggest that you install a fuse between your transformer and the boombox for safety.
Feb 02, 2014 | Audio Players & Recorders
Would like to know where i may get the ac adapter for the sony cfd-e75 cd radio cassette -corder
Your Sony CDF-E75 does not require external power adaptor; it has an AC power input so you can plug here the included power cable. Do you need the power cable or do you need the internal transformer?
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 13, 2010 | Sony CFD-E75 Cassette/CD Boombox
Will not operate under battery power. Only operates with AC power adapter.
hi,
the problem could be from rust of the connector of the battery, open the battery case of the appliances and clean the connectors with a cloth soaked with methylated spirit, if this do not work, try opening the back cover of the appliances to check if the wire connecting the connector to the printed circuit board of the appliances is intact.
Also check for dry soldering, if found resolder.
May 25, 2010 | Sirius SUBX1 Universal Plug and Play Boom...
Sony CFD-E100 now only powers up on batteries
The AC inlet needs to be replaced, there are bad solder connections on the PC board for the inlet, or the traces are cracked on the board. I have seen all of hte above over the years for these types of units. The power board can be puirchased for $28.11 using part number: A-1124-986-A from tritronicsinc.com.
I don't have the part number for the actual inlet at teh moment, but I'll try to locate that number for you as well. Check for poor solder connections or a cracked trace first and update this with the results.
Dan
Nov 01, 2009 | Sony CFD-E100 Boombox
Purchase online at Sony.com, parts and accessories.
Jan 03, 2008 | Sony CFD-S300 Radio/Cassette/CD Boombox
AC Adapter
Go to a Radio Shack Store; take your monitor with you. If that isn't possible find "Radio Shack" on line, see if they have an email contact where you can ask questions; give them all pertinent info.
Dec 06, 2007 | Computers & Internet
Intermittent Power Problem when playing CDs
Hello db1964,
I have a cdf-e75 that had a similar problem, although the red power light was dim for all functions. (the radio, tape and cd)
After opening up the unit and inspecting, I found one of the pins on the printed circuit board for the power had broken away from the solder. (it is a tiny board where the AC connector is soldered to) Seems in my unit there is nothing securing the molded AC connecter to the plastic case except the the printed circuit board it is soldered to-It is a poor design; perhaps your is the same? I suspect over time pushing the AC cord into the back of the player may have broke the connection? Anyway, I soldered the connection and I have never had any additional problems as the unit has worked fine since.
Don't know if this helps, but my suggestion would be to open the unit and inspect the pin connections on the AC printed circuit board to see if any have a loose/broken connection. ( Mine was not noticible with the naked eye as I had to use a magnifying lens and a bright light. Hope this might help.
Dec 21, 2006 | Sony CFD-E95 Radio/Cassette/CD Boombox
No power to unit
Remove the power plug and reopen the unit. Usually the socket will be soldered directly to a Printed Circuit Board. Look in the underside (where the solder joints are and you'll see the joints associated with the power socket. One of these is either a bad connection or the solder pad has lifted and broken the track on the PC board. If it's the solder pads give them a workout with a soldering iron if it still plays up scrape the protective lacquer of the PCboard Tracks and resolder them to the socket's solder joints. This should solve your problem. The best way to spot a bad connection is to reinsert your plug (making sure the other end isn't plugged into the wall socket) and lever the plug up, down, left and right. If there's anything faulty you'll see it. The solder joints will move very slightly and if the track is fractured you should spot that too. One other tip is that there is a switch built into the socket which will disable the battery power when you plug the unit into power. I have seen a few of these switches go bad but the chance of that is extremely small. I'd put my money on the socket's solder joints. BMW
Jul 14, 2006 | Sony CFD-E75 Cassette/CD Boombox
Sony CFD-E10 - boombox - CD Logo
152 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
