Question about Exercise & Fitness
Keeps flashing FITBIT 6.60 - Exercise & Fitness
I got a new Fitbit and while setting it up it keeps telling me the email address is already an existing account
Solved: Email address rejected at setup - Fitbit Community
https://community.fitbit.com/t5/iOS-App/Email-address-rejected-at-setup/td.../837676
Nov 21, 2015 - 13 posts
Solved: I tried to set up my fit bit flex but was using either the wrong app or trying with the wrong fitbit device. ... Now, using the correct app, for the flex, it won't accept my email address because the app says that it's already in use. .... When you install and log on to the Fitbit App, select "Existing User" instead of "New User". Entered wrong email address during set up
9 Jun 2017
Email already in use
4 Aug 2016
How to change incorrect email address
24 Dec 2015
BRAND NEW SURGE BUT CANT SETUP SAYING ..EMAIL ...
28 Aug 2015
More results from community.fitbit.com
Fitbit and while setting it up it keeps telling me the email address is...
Mar 30, 2018 | The Computers & Internet
How to set time on fitbit
There are some specific things you can do depending ion what Fitbit you have, but without knowing that, here is some general advice. Theoretically the Fitbit should keep the time updated though syncing. I would try these steps in this order. Check if your device has the correct time before moving on to the next step.
1. Re-sync your Fitbit to your phone/computer
2. Check your settings on your dashboard to make sure you have the correct time zone selected.
3a. If you sync to a phone make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit (in your Bluetooth settings).
3b. If you are syncing to a computer, then try re-syncing your Fitbit. you might need uninstall/reinstall your software and make sure you are running the most recent version.
4. Try removing the device in the Fitbit app (should be under device settings) and then reconnecting it.
5. Try resetting your Fitbit (specific instructions depend on which one you have).
Oct 20, 2017 | Exercise & Fitness
The time is wrong on my fitbit hr
Theoretically the Fitbit should keep the time updated though syncing, but there are some things that throw it off. I would try these steps in this order. Check after each step to see if you have the correct time before doing the next step.
3. Make sure you do not need to update the app then try disconnecting and reconnecting the Fitbit in your Bluetooth settings.
Hope that does the trick!
Oct 17, 2017 | Exercise & Fitness
How do I reset the time on my fitbit charge?
How to Reset Fitbit Charge HR
  • Connect the charging cable to your tracker and plug the other end into a USB port
  • Press and hold the button for around two seconds and deprived of letting go of the button take away the charging cable from your tracker
  • Wait about six to ten more seconds after removing the charging cable discharge the button and keep holding it down again
  • Once "ALT" and a white screen flash, discharge the button and keep holding it down again
  • After you feel a vibration, discharge the button and keep holding it down again
  • As soon as you see "ERROR," discharge the button and keep holding it down again
  • As soon as you see "ERASE," discharge the button. The tracker is going to turn off
  • To about-face your tracker aback on, essayist the button or attach the charging cable (make abiding by bung in the added end of the cable). When you can see the time on your tracker is 0:00, you have successfully reset your device.
  • Next, you'll tell your Fitbit account that you're setting up a new tracker
That's how you can Reset Fitbit Charge HR and Fitbit Charge.
The Guide Of Reset Fitbit Charge HR Complete Guide
Dec 04, 2016 | Exercise & Fitness
I don't like the band on my charge. Will the band on a hr fit a Fitbit charge. The one on the charge keeps coming off my arm.
Fitbit Store: Buy Surge, Charge HR, Charge, Flex, One, Zip ...
https://www.fitbit.com/store
FitbitBuy Fitbit devices and accessories at our official online store for free shipping on $50+, 45-day money back guarantee and 1 ... Interchangeable Bands ... Fitbit Charge HRâ„¢. HEART RATE + FITNESS WRISTBAND .... United States (change).
Fitbit Charge HR Review: This Is The One You Want
gizmodo.com/fitbit-charge-hr-review-the-king-of-fitness-tracke...
GizmodoFeb 4, 2015 - The Charge HR, on the other hand, has a standard watch strap with a closure that ... Well, most fitness trackers out there are really just glorifiedpedometers. ... With the HRM, I took my pulse (or had a friend take it) and then check the display. ... Fitbit claims the Charge HR will last "up to five days" on a fully ...
Fitbit Charge HR Fitness Wireless Activity Wristband Review
Jan 19, 2016 | Exercise & Fitness
Fitbit 4.14 flashing
This happened to my Fitbit, but it occurred because of putting it through the washing machine and the dryer. When I first took it off the shirt it was on, I couldn't get a response of any kind from the device no matter how long I held the button or put it on the docking base. I followed the Fitbit site instructions to put it in a cup of rice overnight. The next morning, I pressed the button and got nothing. Then I put it on the docking base and it flashed "Fitbit 4.14." Everywhere I looked online said this meant the device was damaged and would need replacement. My husband suggested I try to reset it while it was on the base, so I held the button down until, to our surprise, the battery symbol came up, which meant it was low on charge and was no charging. I let it charge for awhile, took it off the base, pressed the button, and amazingly I got my normal display and it rotated through all the options just as it should. There's no guarantee that this will work on every device, but try all of that before you give up. It just might work.
May 05, 2012 | Fitbit Facebook Apps
Exercise & Fitness Logo
295 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
