Question about Frigidaire Refrigerators
How do I obtain access to the drain tube on my Frigidaire Freezer model FFU20F9G?
Need to know if I need to remove the bottom inside freezer floor to gain access to the drain tube.
  • Official Brand Answer
  • 2,267 Answers
Good Morning Shirley, thanks for your post!
From the information you have provided you need to access the drain tube on your Frigidaire freezer. The drain tube is located in the rear wall of your freezer. In order to do so you would need to disassemble your freezer and this is not a simple DIY job. I would recommend that you consult with a professional technician for proper disassembly and reassembly. This will help you avoid any future issues. -Matt
Posted on Apr 20, 2015
fridgetech
  • 473 Answers
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Posted on Oct 07, 2007
  • 1462 Answers
SOURCE: Ice build-up in freezer - Kenmore Model C978-66795-2
don't know this appliance but for guidence:
some appliances have the evaporator in a compartment at the top of the freezer and the drain comes out of the back and runs externally to the drip tray. there should be a grill in the compartment so just peer into it and see if there is ice build up.
wherabouts is the freezer ice forming?
Posted on Sep 05, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
Posted on May 19, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Defrost Drain clogged
Take a spray bottle with VERY hot water and spray it down the drain line
Posted on Jun 02, 2009
Testimonial: "Good advice. Wife called repairman before I could apply. Repairman did same thing, but with pressureized."
  • 2418 Answers
SOURCE: I have a Amana Bottom Freezer Refrigerator Model
You have to remove the bottom drawer, remove one of the drawer slider mounts on the freezer wall, and remove the rear panel. If yours has an ice maker you will have to disconnect it and remove it also. Unplug it so the water valve does not dump water on you while you are working inside.
Posted on Aug 13, 2011
Do I need to remove the bottom panel beneath the last basket of my freezer in order to see the drain tube for flushing
Hello Shirley, thank you for you post!
I understand that your Frigidaire freezer is leaking water onto the bottom panel of your freezer. This could be a possible clog within your drain line or an issue with your gasket. I would recommend performing a manual defrost on your freezer and you can do that by disconnecting power from your freezer for at least four to five hours. This will help clear out any clogs within your freezer.
You may also want to test your gasket and you can do that by using a dollar bill. Place the bill between your freezer and the freezer door. If you pull the bill and it provides resistance the gasket is good. If the bill slides out you may need to replace the gasket. It that all checks out to be in proper working order I noticed you wanted to access the drain tube. In order to access the tube you would have to remove the rear panel wall. This is not a simple DIY job and I would recommend reaching out to a professional for proper diagnosis and repair. I hope this information is helpful to you. -Matt
Apr 14, 2015 | Frigidaire Freezers
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have a Amana Bottom Freezer Refrigerator Model BC20ML that is about 20 yr.s old, works fine except the drain tube from refrig. compartment to evaporator drain pan sames to be plugged. Water and ice...
Aug 13, 2011 | Amana Refrigerators
Water in the bottom of the freezer that freezes, then the water goes out the door and is messing up my floor. My fridge is a Frigidaire side by side model MRS26LGJ. Yesterday, I cleaned out the freezer and...
The defrost drain located behind the freezer back panel has gotten clogged. You will need to remove the panel to gain proper access to the defrost drain. After removing the ice build up you will have to also clear the tube using boiling water alittle at a time poured into the drain opening. this will open the tube up and gain proper flow again.
Sep 22, 2010 | Frigidaire Refrigerators
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
My GE side by side refrigerator is leaving a puddle on the floor in the morning. There is also a frozen puddle on the bottom of the freezer. What might be wrong?
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number .
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is accumulating inside the bottom of the freezer.
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 13, 2009 | Frigidaire FRS26R4A Side by Side...
I have a frigidaire FRS26ZPH side by side that leaks water about twice a day on the floor by the doors. Where are the drains located so I can see if they are blocked?
What is happening is that there is a drain at the back and bottom of the inside of the freezer area and that drain is clogged with ice (freezer set too cold?) from inside the freezer or dust (you do actually vacuume out those coils once a year right?) from the back of the frigidaire. To fix this issue...
(Total work time about 30 minutes. 60 minutes counting explaining what you are doing to your friend or significant other :)
1.  Unplug the frigidaire so you don't zap yourself.
2. take everything out of the freezer, remove the shelfs and un screw the maintenance access panel at the back of the freezer area.
3. You should see a drain area at the bottom of the coils, using a straw or something semi-flexible, snake out that drain from inside the freezer to see if the clog releases. If there is a lot of ice and you cannot even get to the clog, be patient and gently remove the ice - DO NOT DAMAGE the coils!
4. Remove the back access panel to the frigidaire. Viewed from the back, you are looking for the fat black hose coming from above and behind the right side the fan (this is why you unplugged remember?) into the drain tray under the fan. Gently lift up on the hose so it flexes up and toward you so you can snake the hose from this other end too.
*Hint: If you are REALLY nice to your friend or signifigant other, they will gladly pour another dixi cup of water in the drain from inside the freezer so you can see for yourself that the drain is now clear.
5. Now the drain is clear and all your ice cream is melting in your sink. Be sure to reposition that black hose back to where it was in the drain tray so it does not get chopped up by that fan at a later date. Next... reverse your removal of the back maintenance access panel on back of the frigidaire. Re-install the maintenance access panel on the inside of the freezer area. (Now is a good time to use a clean & warm washcloth to gently clean the inside of your freezer.) Reinstall all the shelfs. Place your ice cream and all other items back into the freezer.
*If you have an ice maker, be sure to dump all that half melted ice now - it will just refreeze into an iceberg later and break your ice machine so no cubes come out.
6. Plug the frigidaire back in. Tomorrow, check the bottom of the freezer for another sheet of ice accumulation, meaning something else is leaking inside of your freezer. (Could be your ice maker)
Jun 20, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
May 27, 2009 | Frigidaire 26.0 cu. ft. Side-By-Side...
Clogged fridge drain tube
Oct 07, 2007 | Refrigerators
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
