Question about Whirlpool Dishwashers
Heating element was cracked, replaced and the light is still blinking and will not reset!?!?!
    Scholar:
    New Friend:
  • 123 Answers
Shorted out your control board when it got cracked.
Remove the kick plate of your dishwasher. There you should have the technical data sheet. Which will guide you through the automatic diagnostic process.
Posted on Apr 25, 2015
5 Suggested Answers
SOURCE: not working
Solution #3 is good, but you need to hit "High Temp Wash" and then "Heated Dry" back and forth 3x to reset the computer.
Posted on Oct 13, 2008
  • 38 Answers
SOURCE: DU1055XPTQ0 DISHWASHER STUCK ON
I believe its pressing heated dry, normal, heated dry, normal keys withing 6 seconds. There should be a tech sheet attached to the toe panel at the bottom front of the machine.
Posted on Feb 20, 2009
taran_2005
  • 10515 Answers
SOURCE: Next Step
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 08, 2010
  • 949 Answers
SOURCE: clean llight blinks, owner manual said to replace
The clean light blinking is due to a fault in heating the water, it could be several other things than the heat element. Here is a link to some instructions on how to reset the control so you can use the dishwasher, it also has a list of things that could have caused the not heating situation. Let me know if you have questions.
Blinking Clean Light
Posted on Jun 14, 2010
Green power light only on trevi exclusive
When power is turned on, the coffee selection button should blink during warming up. If it is not blinking then the following i possible:
1- The electronic sensor is bad. It is clamp mounted on the boiler to sense temperature and send message to control board to turn the heating off when it is ready to make espresso. The blinking light will be fixed to display this.
2- The heating element on the boiler is bad and not heating. The electronic sensor cannot relay any temperature as it is.not sensing the heating.
3- The electronic control board is bad and not sensing the temperature.
The machine should be opened up to test the sensor or the neating elements, and replace what is bad..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Aug 31, 2014 | Spidem Trevi Automatic Espresso Machine
What does it mean when my clean light blinks but I cannot cancel or reset it
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 21, 2014 | Kenmore Dishwasher With Ultra Wash And...
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Oct 02, 2012 | Dishwashers
Model 665.1602 Blinking green(clean) light. Manual says it's a heater circuit problem. What should be replaced?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 11, 2011 | Kenmore 24 in. 17692 Built-in Dishwasher
Clean llight blinks, owner manual said to replace
Jun 14, 2010 | Kenmore 24 in. 16049 Built-in Dishwasher
The
usually means u need service if u got your manual see if it mentions it, try to flip the breaker or power to it maybe it willl resets..... if u can find the tech sheet or wiring diagram on the unit maybe below behind kick panels somwhwere it might mention it,,,,,, i beleive sometimes that means ur heating element as gone out on some models,,, also some had 5 year part warrranties on the heating element... do not remove once u do u must replace that element.....hope this helps
Jan 31, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Kenmore 665.17032401 clean light keeps blinking 7 times and machine will not start
water heating problem. check heating element and computer board. if no problem found, computer needs reset-(key press sequence)
Jan 06, 2010 | Kenmore Dishwashers
Dishwasher blinking clean light
replaced control board with heater & t,stat
Jul 14, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Whirlpool gold
First press your "Sani-rinse" button and the your "Heat Dry" button and toggle between them a couple times. This will reset your control module. If the clean light continues to blink then it means that your heating element needs replacing.  This is not a big job, either. You will need to order a new element and come back for instructions if you can't figure it out quickly....
Dec 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
Dishwashers Logo
79 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
