Question about Frigidaire Freezers
Do I need to remove the bottom panel beneath the last basket of my freezer in order to see the drain tube for flushing
My freezer is working correctly, however ice is forming on the lower panel and water is pooling on the floor. I need to know if I need to remove the bottom floor panel to obtain access to the drain tube.
  • Official Brand Answer
  • 2,267 Answers
Hello Shirley, thank you for you post!
I understand that your Frigidaire freezer is leaking water onto the bottom panel of your freezer. This could be a possible clog within your drain line or an issue with your gasket. I would recommend performing a manual defrost on your freezer and you can do that by disconnecting power from your freezer for at least four to five hours. This will help clear out any clogs within your freezer.
You may also want to test your gasket and you can do that by using a dollar bill. Place the bill between your freezer and the freezer door. If you pull the bill and it provides resistance the gasket is good. If the bill slides out you may need to replace the gasket. It that all checks out to be in proper working order I noticed you wanted to access the drain tube. In order to access the tube you would have to remove the rear panel wall. This is not a simple DIY job and I would recommend reaching out to a professional for proper diagnosis and repair. I hope this information is helpful to you. -Matt
Posted on Apr 22, 2015
5 Suggested Answers
  • 12 Answers
SOURCE: Kitchen Aid Refrigerator Mod: KTRS22MJWHOO Date:09-00
By blasting the hole with compressed air
Posted on Aug 05, 2008
  • 124 Answers
SOURCE: Upright Freezer not freezing,
looks like low on freon. that causes freeze up. oddly enough they freeze up when charge is low , just the opposite of what you think they would do. you have a freon leak unfortunately. probably not accessible, and therefore not repairable. i would suggest, cut your losses and buy new. unfortunately for me and all other srevice techs, the days of affordable repair are over, you can now replace cheaper than i can fix and have a warranty and its new... good luck
Posted on Nov 27, 2008
  • 297 Answers
SOURCE: Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Posted on Apr 14, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Ice forms on the lower
The drain from the freezer is at the base of the evaporator section.
This is behind a plastic cover at the back inside, which must be removed to see it.
There should be screws visible, or clips which must be removed first. Often these are covered with plastic covers too.
Use a mould-killer spray, and a length of PVC covered wire to clear it.
Posted on Dec 25, 2010
ICE FORM AT THE BOTTOM OF THE FREEZER ALL THE TIME, LEAKS OUT ONTO MY HARDWOOD FLOORS AND FORM PUDDLES
Step 1: . Unplug the fridge. You can wait until later but don't forget.
Step 2: Freezer door. It's 4 screws, one in each corner. Just loosen them a few turns - don't take the screws out entirely - it's much easier putting the door back on when the screws are already in place. The door slides up & off.
Step 3: Lower basket. It lifts out, no tools required. Now's a good time to start eating all your ice cream.
Step 4: Upper basket. Remove the 2 screws at the front of the rails, then lift up the rails slightly on each side, to slide the basket forward.
On the plastic pieces at the back sides of the upper basket, push in two tabs with your screwdriver on each piece & pop them up. This will let the upper basket slide out off the rails.
Step 5: Icemaker. Remove the lower screw, then loosen or remove the two screws above the icemaker. Unplug the wire harness where it passes through the rear panel - squeeze the sides of the plug & pull. Lift the icemaker up & out. The water tube will slide out of the guide.
Step 6: Plastic guards.The thermostat guard is the skinny piece to the upper right. Push in (to the right) the tab on the left side in the middle. The guard opens like a door pivoting on the right edge, & pulls out.
The center fan guard has two tabs at the top on each end that push in toward the center, & another tab in the middle at the bottom of the guard that pops up.
Step 7: Freezer panel. Remove the 4 screws in each corner. Push the thermostat back through the slot at the top, & also push the icemaker plug back through its slot.
FAST/HARD WAY: Pull carefully up & out from the top middle edge. Be careful because that sucker is SHARP! The back panel will bend vertically in the middle as you remove it, but it's flexible & will pop back into shape.
SLOW/EASY WAY: If you don't like bending the panel around the drawer slides, you can take off the slides. The metal rails have tabs that push in to release the whole slide assembly, which pulls out forward. You only need to take the rail housings off one side - when you go to remove the rear panel, just pull that side first. To release the upper section (that you already unscrewed in Step 4), left it up, bend in & pull out - the back end has a tab through the freezer wall. The lower plastic slide housing unscrews with 4 screws.
Step 8: Ice Dam. By now you should see the ice problem. Typically the entire evaporator tray is completely iced, along with some of the tubing. MELT IT ALL. Warm water applied with a turkey baster works well. Be careful not to puncture the coils because ... that will ruin your fridge.
Do all the ice melting while the drain is still plugged so it runs out into the freezer floor where you can sponge it up. If the meltwater goes out through the drain hole, it can flood the pan under the fridge - no big deal, just dirtier water & more mess.
The drain hole is near the front of the rear tray in the middle. It's pretty wide (1/2?) & short, only ~2 inches long. It goes straight down into a rubber "duck bill" grommet that's probably plugged up with gunk, that you access from the back of the fridge...
Step 9: Drain grommet. Pull out the fridge so you can access the back side. Remove the screws (6?) around the lower access panel, pop the power cord up & tilt the panel out of the way. The plastic tray under the fan is the evaporator tray - that's where the water SHOULD normally be dripping into & evaporating from.
Behind (technically in front of) the fan, there's a black drain slide into the tray that leads up to your plugged drain. Push the slide aside to see the drain. There's a rubber "duck bill" grommet on the end. Pull it off & clean it - it's no doubt plugged with gunk. Better yet, trim the opening very slightly so the hole is larger - see this site for photos.
Step 10: Put it all back together. Some tips: if you lived hard/fast & didn't remove the rails & rail housing, getting the freezer panel back in place . Make sure you slide the tray rails all the way out before you start trying to put the rear panel back. Bend the panel vertically along the middle so it springs back into place on each side. Again, wear gloves. Once it's in place, don't forget to run the thermostat wire & icemaker tube/plug out.
When you put the the top tray back, make sure it's all the way to the front before you pop the plastic pieces on each side back down, so the gears on each side are aligned in matching grooves. Otherwise your drawer will be crooked & probably won't slide.
Hope this helps. I have a Whirlpool GX2FGDXVY but these steps work on other models too including Maytag etc.
here is the whole exert video of the whole eplanation watch it,(https://youtu.be/lhuBR1sKx7E)or
kingsley
May 12, 2015 | Samsung RS261MDBP - 26 cu. ft. Side by...
I have a 17 cu ft. frost free freezer, Model F17WCE and I believe the tube is clogged. I thought if I found the plastic tube, I would wash it out. I saw the tube from the front of freezer, while lying on...
Usually you can access a service panel to where the fan and evaporation department is.
I don't know about a wood but I did work on an upright not long a go and took some pics.
See the drain hole below the fan on the floor there?
Thats what ya gotta clear. I use a shop vac myself but I let the freezer thaw all the way out , you could use a hair dryer to melt the ice.
Aug 13, 2011 | Woods Upright Freezer V1613RW3
Ice in the bottom of freezer
Greetings,
the drain is clogged most likely...remove lower shelves, baskets, remove rear panel if self defrosting.. find the drain hole and use a hair dryer or hot water to defrost ice..once the surface ice is off...you will need to make sure there is no ice in drain tube going down under freezer. use a squeeze bottle with hot water and force it into drain. do this repeatly until water runs free down drain....Bruce Denton
Jan 09, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Some water dripping on the bottom and freezes onthe bottom of the freezer and sometimes theres water on the floor.
The freezer drain is cloged.Drain is in the bottom of the freezer floor in the back you may have to remove back panel. Run wire or somthing down drain tube to clear clog.
May 16, 2010 | Freezers
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Water pooling and freezing on bottom of freezer. Cools poorly.
Check door gaskets if sealing properly? Check to verify freezer is level? If all of the above are fine then look at your drain for the condenasation. It's located at the bottom of your back wall underneath the aluminum evaporator that the cold air comes from. (You will need to remove the back panel inside of freezer wall To get to the drain. It's probably plugged and frozen over. Do not use a chisel or knif instead take a cup of hot water and pour it Oder the drain area and let it sit. (Your freezer will not be running for an hour or so so think ahead or work fast). That being said you have to unplug unit first :-) once you remove all ice push a straw or something through drain to verify its draining through. You can also flush more water down it to watch it drain showing you that it's working. Start with this first.
Jun 22, 2017 | Kenmore Freezers
Ice accumulation at bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coils.
Use a hair dryer and melt the ice. Make sure and get the ice out of the drain hole as well.
After the ice is removed, be sure and flush the drain hole with hot water. A baisting surenge works great for the flush.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 01, 2009 | Freezers
Our 19.6 cf whirlpool "commercial" freezer (sn EV201NXMQ0312 building up ice in the bottom under the slide out basket. It actually builds up enough in a month or so to keep the basket from sliding out....
the ice build up is from a frozen drain line. you will need to remove teh rear cover in the freezer and you will uncover a coil at the bottom center there is a drain hole that allows defrost water to drain out. defrost any ice then flush the line out with warm water. if it doesnt clear right away you may need to use a large syringe or possibly a turkey baster to force warm water into drain.
BTW the door not sealing is not related to this problem. good luck peyton
Jan 27, 2009 | Whirlpool 19.6 cu. ft. Commercial Freezer...
Maytag Frostfree Freezer ice at bottom
hi thanks for the question .The drain tube is clogged up. Pull fridge away from wall, remove back panel, clean all coils. let thaw 24 hrs. find drain tube by drain tray clean tube to freezer thanks the appliance doc
Sep 28, 2008 | Freezers
Freezers Logo
209 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
