Question about Sewing Machines
Top threat bunching up under material - Sewing Machines
Either the top tension is too low, bottom tension is too high or you have not lowered the pressure foot.
Posted on Apr 16, 2015
  • Sewing Machines Master
  • 9,556 Answers
If it occurs when you first begin sewing, try pulling your bobbin thread to the top of the fabric first (see video).
Machine Minute Pulling Threads to Top
Posted on Apr 19, 2015
How do I raise the feed dogs
Make sure that your top and bobbin thread are the same and that the tension is set correctly. Then, be sure that the bobbin is put in correctly. If this happens when you are starting on an edge of your material, try putting a piece of material or even a piece of paper, like typing paper, under the edge of the material and sew a little beyond that and then onto your material. You can tear it off later. It gives stability to the edge of the material and should alleviate the problem. I hate when that happens! And, last but not least, be sure you are using the right needle. I love the ballpoint needles for most sewing projects.
Dec 30, 2015 | Baby Lock Evolve
Fee motion quiltng thrad breaks on top and bunches onthe bottom
Likely the thread is catching somewhere. Of course there's no detail here and no machine model. Might be using a model that won't do FMQ
Aug 28, 2014 | Sewing Machines
Thread to loose under the material
try changing the needle
adjust the top tenison one number or letter higher, using a scrap
piece of cloth to check the stitches till they look normal
clean under the needle plate and in the bobbin area for lint
Dec 02, 2012 | Sewing Machines
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
The top thread just hangs and knots on bottom of material
try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Feb 20, 2012 | Sewing Machines
When i sew the bobbin thread bunches up. what to do?
remove the thread and bobbin.
take out your manual and follow the exact instructions for threading and inserting bobbin.
If this does not help check the tension on the top(the number should be about mid way).
If it is too low it will bunch up on the bottom.
Nov 12, 2011 | Brother LS-1217 Mechanical Sewing Machine
My bobbin threat is bunching and after a couple of inches, the top thread breaks.
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
Apr 13, 2011 | Bernina Artista 180
Bunching and Looping (Bobbin Side)
Thread the machine with different color thread for the needle and the bobbin, then see which color is bunching up.Ill bet it is the top thread.
Jun 16, 2010 | Brother CS6000i Computerized Sewing...
Thread bunching
I discovered that when the thread is knotting up on the underside of the material that it is usually the threading on top and has nothing to do with the bobbin.
Jun 29, 2007 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
166 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
