Question about Plumbing
Eljer bathroom sink faucet cartridge replacement
The cold water drips an I need to replace the cartridge. I can see the whit stem, how do I remove it? Thanks Joe Wearden
  • 74 Answers
SOURCE: The unit has a croosbar connecting the hot and cold water. How do you remove the crossbar to replace the faucet
Do we want to remove the faucet from the top of the sink?
First shut-off the water via the two valves under the sink. Then un-thread the hoses from the bottom of the sink. Sometimes it is possible to do with ordinary house tools but more than likely you will need to purchase a basin wrench for about $10. This wrench will allow you easy access to the bottom of the faucet.
Then, using the same wrench, un-thread the nut that is threaded on the same threads as the hose. This nut if probably pretty tight and will take some effort.
Replacing is the exact opposite except when replacing be sure to use plumbers putty on the bottom of the faucet as a means to keep water from running under the faucet base and ruining your cabinet.
Posted on May 23, 2009
  • 6 Answers
SOURCE: can't remove moen bathroom faucet assembly to
If you are dealing with the type of Moen faucet I think you are, what you need to do is remove the pop-up rod. do this by loosening the locking bolt on the linkage under the sink and pulling the rod out from the top. Once the rod is out you will need to find the correct size allen wrench which goes into the center hole. there is a mounting bolt in there that needs to be unscrewed. Easy when you know how.
Posted on Jun 17, 2009
  • 251 Answers
SOURCE: bathroom sink faucet,(washerless) has a drip when
http://www.housetask.com/Leaky_Faucet_Repair.htm
a repair kit/cassette
most decent plumbing centres will be able to match up the old cassette
Posted on Oct 21, 2009
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
  • 102 Answers
SOURCE: leaky faucet
From the sounds of it. It is time to call in a Pro. Be sure to check references. I hope all goes well.
Posted on May 27, 2010
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
Search Fixya...
    • Test the dripping water with your hand to make sure that it is the hot water side that is leaking. Lay a rag over the sink drain to keep parts from falling down it. Locate the hot and cold shutoff valves under the sink and turn the knobs clockwise by hand until they close. If the knobs remain stiff, use a pair of pliers to gently turn them until the knob begins to move, then finish turning by hand.
    • 2
      Pry the decorative cap off the faucet top with a small thin, flat-head screwdriver. Remove the cap that has the "H" letter on it. Depending upon the handle screw configuration, use a flat-head or Phillips-head screwdriver to remove the handle screw. Gently pry up on the handle from all angles and pull it up and off the splines of the stem.
    • 3
      Use a crescent wrench to turn the hot water stem nut counterclockwise until it comes completely off the stem shaft. Wiggle the stem with your fingers and pull it out of the faucet. If the washer on the bottom of the stem is deformed, it indicates the source of the leak. However, remove the old seat from the faucet base with an Allen wrench or a seat removal tool.
    • 4
      Wipe out the inside of the seat housing with a rag. Replace the seat with the new one included in the repair package, using an Allen wrench or seat removal tool.
    • 5
      Place the new hot water stem shaft into the valve seat, and start the stem nut in by hand, turning it clockwise. Finish tightening the stem nut with the crescent wrench, but only to a moderate firmness -- do not over-tighten it. Place the handle back over the stem shaft and tap it down until it seats firmly. Replace the handle screw and tighten it with a screwdriver.
    • 6
      Turn the hot and cold water supply knobs counterclockwise until they are fully open. Turn the hot water faucet knob to the "On" position and check for leaks.
Jul 09, 2013 | Computers & Internet
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
Dripping bath faucet circa 1985. Can't ID model but appears to have 2 screws holding front of casting to main body for disassembly . Faceplate is square in shape and black in color HELP!
  • 1 Close the hot and cold water valves in the cabinet beneath the sink to shut the water supply off to the bath faucet.
  • 2 Remove the bath faucet's handle to access the valve cartridge. The faucet handle is removed by first detaching the handle's insert cap using the tip of a screwdriver or utility knife to expose the handle screw. Remove the handle screw with a Phillips screwdriver, then pull the handle off the valve cartridge stem.
  • 3 Loosen and remove the cartridge valve nut with an adjustable wrench. Some faucet models retain the valve cartridge with a snap ring and are removed with snap ring pliers.
  • 4 Pull the old valve cartridge out of the bath faucet base, using pliers.
  • 5 Insert the new replacement valve cartridge into the faucet housing and replace the nut or snap ring removed in Step 3, using an adjustable wrench or snap ring pliers.
  • 6 Reinstall the faucet's handle onto the valve cartridge post, then secure the handle's screw, using a screwdriver.
  • 7 Replace the insert cap into the handle to cover the handle's screw hole.
  • 8 Turn on the hot and cold water valves beneath the sink to restore the water supply.
  • Jun 15, 2011 | Kohler Plumbing
    I have had my Delta bathroom faucet about four years. The hot water side drips. Can not get it to stop. It is one faucet with hot and cold handles with all sitting on a small platforum. The platforum is...
    Go to delta website, take a picture of faucet with your cell phone and send. They should be able to identify and send you the parts. Meanwhile you'll have to turn water on and off from the emergency shut off valve under the sink. If it looks like the picture, it's probably the rubber seat and spring. If you don't want to wait go to your local "hardware" store. There may be someone there to help you. Bring the stem or cartridge, along with the rubber seat and spring. Don't use cold water while stem is removed. Turn cold off as well to prevent a mishap.
    Apr 23, 2011 | Delta Faucet Bathroom Faucet - Delta 2...
    My cold handle on a montecello faucet turns freely, however, nothing happins I have no cold water. What do I do?
    First check that the handle is tight. If yes take the handle off and turn on the water buy turning the stem without the handle if you still do not have water remove the stem and cartridge and see if you have water if yes clean or just replace the cartridge. If the faucet in old replace both.
    Mar 15, 2011 | Moen Bathroom Sink Faucet - 4-inch...
    My classmate
    Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
    Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Leaky moen 2 handle faucet
    Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
    I bought a replacement Danko faucet cartridge for an american standard bathroom sink and the package said hot/cold but when I installed it on the cold side the handle turns the wrong way. How do I reverse...
    Thae stem you got that said hot/cold were designed to fit old style cross handle faucets. So both hot and cold turned the same way. If the cold side you are replacing turns the opposite direction then you will need to get a cold stem. Danco does make them. Ask the retailer where you purchased the H/C stem. I hope this helps..
    Dec 29, 2009 | Danco Faucet Cartridge
    Replace inside stem on hot water Eljer shower faucet
    Sounds like you might need a gear puller -- hardware stores would have them -- or auto parts.
    Spray with contact cleaner wd-40 first, then install puller, depress ring and crank away at the puller.
    Apr 21, 2009 | Home
    Plumbing Logo
    89 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
