Question about Tolly Tots 1001531 Baby Genius Be-A-Star Sing-Along Jukebox
Do you know where I can download instruction sheet?
Cleaning instructions dymo letratag
Remove the cassette and moisten the supplied brush with some alcohol solution. Rub the print head to clean it. Make sure there is no tape wound round the rubber roll.
Feb 22, 2012 | Dymo LetraTag QX50 Thermal Label Printer
Mega blocks pirates of Carribean ship need instructions if possible
I will need to know which ship you have. If you would like me to get you the correct instruction sheet. Instruction sheets for all the megabloks pirate ships can be found at:
http://www.megabrands.com/en/customerservice/instructions.php?brandSelect=35
Jul 10, 2011 | Toys
Need to lengthen duration of fuel injection from pump.this is determined by screw#2 on top of carb ,but which way increases pump stroke & duration of "squirt"?
Evidently you have an S&S carb on your engine because the original Keihin CV does not have such an adjustment. Go to this site and download installation sheet number 51-1013.
http://www.sscycle.com/instructions/instructionslist.php?x_cat=24 I always have to refer back to the sheet when working on one of these carbs but I seem to remember that you turn the screw out to increase the pump shot but the instructions will tell you for sure. The installation instructions contains everything you need to know about your carb including a parts list.
Good Luck & Ride Sate
Steve
Jul 04, 2011 | Harley Davidson FLHR - FLHRCI Road king...
Instructions for the Mattel Barbie I Know You Smart Phone
This product is made by Kid Designs.
You can get an instruction sheet for Mattel Barbie™ by downloading the following;
http://www.kiddesigns.com/pdf/BE174_IB55563_15.pdf
BARBIE and associated trademarks and trade dress are owned by, Mattel, Inc.
Apr 26, 2009 | Mattel Barbie I Know You Smart Phone...
I need to install a lexmark x85 printer scanner
If you need to download the software/driver, go here: http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
Search for your printer (X85), then select your operating system and language. After you download the file, double-click it to launch it and follow the instructions on your computer screen.
I think you just need to install the software, but if you also need to set up the hardware, refer to the instructions in the Setup Sheet, which you can find here: http://www.lexmark.com/publications/pdfs/x85/en/setup.pdf
Follow the instructions on the Setup Sheet through step 13. At step 14, rather than inserting the CD, download and install the software as I've instructed above.
Oct 01, 2008 | Lexmark X85 All-In-One InkJet Printer
Tolly Tots 1001531 Baby Genius Be-A-Star Sing-Along Jukebox Logo
47 people viewed this question
Top Tolly Tots 1001531 Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Tolly Tots 1001531 Baby Gear Expert? Answer questions, earn points and help others
