Question about Canon iR5000-6000-L1 PS Ver 1.0
How to the install block gear unit drum and corona wire install?
How to the install scanner and camera?
    Sergeant:
  • 166 Answers
Go to Canon website, and download the manual for the instructions - http://bit.ly/1G1CIhq
Posted on Apr 17, 2015
Unable print 40
Try one or more of these options: Clean the corona wire in the drum unit,replace the drum unit with a new one, clean the electrodes of the drum unit and body of machine,
Jan 11, 2014 | Brother DCP 9010CN - multifunction ( /...
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Mar 19, 2013 | Minolta EP4000/5000 CS/PRO Copier
Corona wire problem
Hi, you can clean the corona wire easy, just follow those steps:
1) Turn of printer power and unplug all cord including phone cord.
2) Make sure the scanner is closed, then lift open the top cover by its handle.
3) Remove both the drum unit and toner cartridge assembly for the color desired to be replaced.
4) With the drum unit removed, push down the GREEN lock lever to remove the toner cartridge.
5) Slide the GREEN tab left to right several times to clean the unit's primary corona wire.
6) Before installing new toner cartridge, shake it from side to side to distribute toner.
7) Remove protective cover from cartridge.
8) Insert cartridge into drum unit until it snaps in place.
9) Ensure that you are inserting the correct color toner cartridge into its proper place and then slide the drum unit into the printer.
10) Close the top of the machine and then reconnect all cords; turn on power to ensure proper installation.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
Vertical Lines through incoming faxes and copies.
Sometimes you may see vertical streaks/black lines
on the faxes you receive. Either your FAX/MFC's
primary corona wire for printing may be dirty, or
the sending party's fax scanner may be dirty. Clean
your primary corona wire (see pages 13-18), or ask
the sender to make a copy to see if the problem is
with the sending machine.
Cleaning the Drum Unit
We recommend you place the drum unit on a drop cloth or large piece of
disposable paper to avoid spilling and scattering toner.
1 Carefully turn the drum unit upside down.
2 Clean the primary corona wire inside the drum unit by gently sliding the tab
from right to left several times.
3 Return the tab to the Home
position (  ) before
reinstalling the drum unit.
Jan 31, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
The ride side of my faxes and copies are black, any ideas?
Sometimes you may see vertical streaks/black lines on the faxes you receive. Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Dec 31, 2010 | Brother IntelliFax-4100e Fax
Copies are black and where is this corona wire? I
Your cartridge has two sections, the drum and the toner section. The corona wire is on the drum section. There should be a blue tab on the top left hand side of your drum unit. Slide this tab across the cartridge one or two times, returning the tab to its original position. There should be an arrow on the blue tab that will match up with an arrow on the drum unit when the tab is in its resting position. Performing this action cleans the corona wire inside the cartridge. If this doesn't fix it you may need to purchase a new drum unit.
Dec 22, 2009 | Brother IntelliFAX 2800 Laser Fax
Copies are black . Changes toner and cleaned corona wire, but still coming out black & blotchy
(2) All black At the scanner
Check the following components:
- CIS harness
- CIS unit
- Main PCB
At the printer side
 Clean the high-voltage contacts for the grid and charger on the
drum unit, main cover, and high-voltage power supply PCB.
(Contacts and in the illustration given on page 6-28)
 Clean the charger (corona wires) itself.
 Check the connection of the laser flat cable on the main PCB.
 Replace the drum unit.
 Replace the high-voltage power supply PCB.
 Replace the main PCB.
Nov 24, 2009 | Brother IntelliFAX 2800 Laser Fax
Looking for corona wife for brother 8860dn MFD.
Try to get some corona wire stock which was quite common back in the day and install it in your drum.
Aug 14, 2009 | Brother MFC-8860DN Printer
The paper keeps jamming in my konica photocopier and the following message appears F28 3 Contact service department
F28 High voltage leak. (coronas)
The corona wires are arcing, it is located directly under the drum a unit with three thin wires. the end blocks go bad and it arcs causing jams and copy quality problems, replace the corona ***'y.
Other cause may be the High voltage unit for the coronas itself
check this site for the price
precisionroller.com
Dec 01, 2008 | Office Equipment & Supplies
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
Computers & Internet Logo
330 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
