Question about OKI Office Equipment & Supplies
C9a0 on a oki data mps3537 - OKI Office Equipment & Supplies
OKI Error 0002
OKI error 002 is a main engine board failure. sometimes this can be caused by bad data received from the PC.
remove all cables from printer and only leave power on. run internal pages and if it works then most likley case is the bad data from USB/netowrk
Aug 25, 2014 | OKI B4350 Laser Printer
Okidata 30 turbo carriage keeps running when reaches far left
Have you contacted OKI Data? Live customer support is available 24/7 (within the US and Canada) at 1-800-OKI-DATA.
Jan 27, 2013 | OKI MICROLINE 320 Turbo Matrix Printer
NVRAM Failure oki
OKI provides live customer support 24/7 at 1-800-OKI-DATA (1-800-654-3282) in addition to a live chat feature during "normal" business hours. Visit www.okidata.com and look for the red "chat" button on the right. The skilled technical support staff should be able to fix your problem promptly.
Jan 25, 2013 | OKI B6500 Led Printer
Windows 8 says my oki c3200n is in an error state
Jan 22, 2013 | OKI C3200n Led Printer
Rear picture of c5100
Jan 17, 2013 | OKI C5100n Laser Printer
I need to know the size of the IT Belt reset fuse in an Oki c5500
Jan 14, 2013 | OKI C5500n Printer
My OKI B4600 is displaying error 134
It means the printhead [laser] is "missing" - but usually it's just the data cable at the end of the printhead has popped out. Very common - we have hundreds of Okis at our corp and I've fixed this many times. Turn the power off, pull either the left or right plastic clip AWAY from the printhead, and carefully insert the data cable back into the connector on the printhead. Put one end of the printhead nearest the data cable back into its plastic clip, and make sure the spring is seated on its little post on the bar, and then click the rest of the printhead into the clip on the end opposite of the data cable, again making sure the spring is seated on its post. Turn the printer on - your error should now be gone.
Mar 01, 2011 | OKI Electric Industry B4600 Laser Printer
I need linux drivers for OKI C5100n
Some Oki LED printers do have Linux drivers available. You should contact Okidata here:
my.okidata.com
or
Jan 21, 2009 | OKI C5100n Laser Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
63 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
