Question about Rainbow E series Canister Wet/Dry Vacuum
The hose on my Rainbow vaccuum smells like mildew.....how do I clean the hose out?
  • 1,511 Answers
Agree with the others; however remember Bleach can leave the metal parts to rust if not completely dry after treatment. Only use a small diluted amount of bleach as strong bleach can pit metal parts and cause mechanical problems down the road.
Posted on Apr 17, 2015
    New Friend:
  • 27 Answers
Tie off one end of hose to keep water from coming out. You can use heavy plastic bag (freezer bag) etc and rubber band, or cable tie. Pour diluted bleach water into hose, tie off other end to keep water from coming out. Then swish back and forth to wash out hose. Be sure and rinse thoroughly so bleach water does not compromise you hose. Dry using the exhaust to make sure you don't smell any leftover bleach. Don't forget to put exhaust cover back on. Hope this will help.
    Habit-Forming:
  • Rainbow Expert
  • 119 Answers
If it is the standard hose then you can soak in bleach water. If it is the electric hose, you can still run bleach water through it to clean out.
Hook the hose up to the exhaust when finished to blow dry for about 15 minutes or so. Place the other end of the hose into the intake so all water that is blown out of hose will be sucked up back into the Rainbow. Creates a loop effect and helps dry the hose faster.
RainVac
www.rainvac.com
800-523-0510
Posted on Apr 14, 2015
How do I attatch the power nozzel to the e series rainbow vaccuum? it seems there is cord attatched to the nozzel : I can't figure out where this plugs in??>?
One of your hoses also has a cord that goes the length of the hose. Up at the handle end the cord goes to your handle. At the end that plugs into the unit, the cord plugs into the unit just under the hose hole. You should also have a hose with no cord that is used with the bare floor brush and other attachments.
Feb 10, 2015 | Rainbow Vacuums
My vacumn has a aweful smell coming from it when in use. Not motor smell.
smells are usually from bacteria. I have seen this before and you can get O.K results by rinsing the machine with cleaning soloution. I like ****-n-span. try to use a cleaner that you like the smell of as it will leave a little of that smell behind. use the vacum in the wet type aplication and use it to **** up the cleaning solution mixed with warm water with about the same mix as you would use to clean a floor. then after the machine fills up let the cleaning solution set in there for 5 to 15 minutes. dump out the cleaning soloution and repeat the process with clean warm water. If it has gotten really bad then you made need to repeat the entire process one or two more times. I also take the pick up hose and clean it with some cleaning solution then rinse outside with a water hose.
Apr 23, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Sour odor
You should always put a new hepa filter in any E and E2 series Rainbow vacuum, when it taken to a new home. It will smell like the home that it was in, until you do.
You can also use fragrances, and deodorizer air freshener in your vacuum, which not only eliminates odors, it add fresh aromas to your air in your home, also.
Replace the hepa filter first thing.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Jun 06, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My e series rainbow smells very badly... my teenager often leaves the water in for days and that nasty smell has saturated the sweeper itself. How do I get the smell out
You should always put a new hepa filter in any E and E2 series Rainbow vacuum, when it taken to a new home, or every two Years, or so, or if your Doughter makes it get funky smelling. :-) It will smell like the home that it was in, or how ever it smells, until you do.
You can also use fragrances, and deodorizer air freshener in your vacuum, which not only eliminates odors, it add fresh aromas to your air that you breath, in your home, also.
The water separator is the thing that spins in the center of the motor where your water basin attaches to it. It looks like a cone shaped fan looking thing. It should be cleaned after every use.
Use your Rainbow separator cleaning brush, or a tooth brush, if you do not have the Rainbow one. They are just like tooth brushes.
Never store your Rainbow canister on your water basin, with or without water in it. It can and will ruin your vacuum in dew time.
You can get manuals either here,
http://www.rainbowsystem.com/ or here,
http://www.rainvac.com
Thank you,
Ralph
Jan 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My dyson smells terrible while it's on
Clean the filters and check to make sure you don't have something fowl stuck in any inlets. Spray Lysol into the hose while the unit is on and see if it relieves the smell. If it is mildew or a dander smell you have to clean the filters and then use the Lysol.
Jul 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Burning smell and not picking up dirt
You probably need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Jul 02, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
E2 series not cleaning
Are the brushes spinning on the power head? If you disconnect the power head and just leave the hose only with the water canister filled .. does it "**** up" dirt?
Apr 16, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
312 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
