Question about Inverter Electronics - Others
I have solar panels that put out a little more voltage then they are rated at,and they keep faulting out my grid tie inverter.I need a resister to knock down the voltage about 8 volts, got any ideas?
Sy-GWV Series Smart Gridtie Micro inverter My grid tie inverter is 60 volt max 600 watts, 50 amp I keep getting a high fault code on the inverter. I get an output reading from the solar panel at 57.3 volts but it surges to 68.2 sometimes I have been using the panels by covering them with cardboard about a quarter of the panel. It looks kinda tacky!
  • Inverter Master
  • 2,760 Answers
You could use a PWM solar charge controller , to better regulate your voltages , but most grid tied inverters don't require them as they allow for a slightly higher voltages into them , a better situation would to maybe move half of your panels to another orientation , so that half your panels get full sun say sunrise to mid day and the other half miday to dusk this would produce a longer power supply than just all of them for midday sun plus would work better in the off seasons as well
Posted on Mar 11, 2016
I like to ask, is the voltage from the solar panel messure with some load connected or is open circuit, normally solar panels produce high voltage than the working system, the reasson for that is to have Amperes in of to charge the batery, these is related to the size and power generated by the panel.
No need a resistor or in any case use a voltage regulator to prevent over charge.
Posted on Apr 21, 2015
3 Suggested Answers
  • 4 Answers
SOURCE: Low voltage output from inverter
I am thinking this a high impediance device problem and this is normal operation - the user manual of my inverter warns about use with high impediance devices - if not I am interested also...
Posted on Mar 03, 2009
  • 61 Answers
SOURCE: In my question as to
this solution would likely work fine if you were only looking to have 110vac power. In order to have 220vac from two 110vac devices, you would need expensive equipment, and technical knowledge.
What you need to do in order to get 220vac is buy an inverter that will provide 220vac. There are many available.
Hope that helps.... Good Luck!
Posted on Nov 27, 2009
My Xantrex GT2.8-AU-QC-230 Solar power tripped the Inverter AC Isolator to off during a storm.
IF your inverter failed due to an electrical or weather related event then you need to have it serviced and you need to make an insurance claim if it is not under warranty.
Mar 10, 2016 | Solar Electronics - Others
Power supply
ok you will need a 8 volt zenor diode and prob about 100 ohm resister to lower your current. if you can't build this then how about gettin a cigar ligher adapter for auto that has a voltage selector on it. and hard wire it up.
May 06, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Is this true or scam Government pays you to go solar.
The US government WILL NOT PAY you to go solar. There have been incentives on the state level to get people to install solar panels. Most of these have dried up but it is possible to find programs that will reimburse you a portion of the total cost but don't expect much. We live in Florida and in 2009 we were promised nearly 1/2 back if we installed. We got less than 10% when all was said and done and it took 2 years to get that.
Aug 18, 2015 | Miscellaneous
How do i convert my 1.2kw solar inverter on my roof so i can run my home on stored energy ?
Solar panels produce DC voltage.
some solar panels have the inverter integrated into each solar panel.
I would suggest contacting a local solar panel supplier and asking them if they could add a Battery Charging System to the Solar panels you use. An then what sort of inverter to add to the bank of batteries.
An inverter converts DC voltage to AC voltage to use in the grid.
The AC voltages and DC voltages involved have the possiblity to kill if you much around with electricity.
Jan 15, 2015 | Inverter Electronics - Others
Have Solar PVa system with 10 panels on the roof. The Inverter is an Aurora model and displaying error message "Missing Grid", can anyone solve?
There is insficient input voltage to permit connection
to the grid: the inverter waits until there is grid
voltage to carry out the parallel connection
look at page 27 here for more info
http://www.hyland.com.sg/download/systemtech/POWER%20ONE%20PVI-6.0-TL/POWER%20ONE%20PVI-6.0-TL%20Manual.pdf
you may have a different model of inverter pvi so youll find the manual
i think your output from the panels isnt enough juce as it says
or the inverter or more likely a fuse has failed
remember this is input voltage and not the connection to the grid thats been autherised
Dec 05, 2014 | Office Equipment & Supplies
What is the DC input voltage range for this inverter
The answer to your question is 24 volt DC at the highest you can go that's the maximum
Apr 15, 2014 | Sma Solar SMA Sunny Boy SB7000TL-US-240 >...
Need installation instructions for aerosharp HR-INV-XOI-030 solar inverter
My HR-INV-X01 PV Invertor LCD Display has nothing. No power, run or fault lights however the blue safty switches note ON. What could be the problem?
Jan 07, 2011 | Solar Grid-tie Budget Package: Panels,...
Hi I have 2 inverters on my house each with 21 pannels. normally 1 puts out around 3500w and the other around 3100 during the peak of the day. lately however 1 is only putting out only 600w during the peak...
The inverter will only make AC at a rate per the current and voltage being supplied by the solar panels. The panel outputs need to be checked and compared to the panels that are working correctly.
It certainly sounds as if there is a power distribution problem from the panels supplying the 3100 W average output inverter. It can be anything from a corroded terminal to a damaged umbilical or anything in between.
A bad ground for the inverter will also limit output. It may read resistance / continuity but can not carry the amount of current needed to produce 3100 W output. Given it has only been 5 days the problem should not be hard to isolate and find.
I had a similar problem arise quite recently with an 18 panel system and the problem ended up being corrosion on a terminal block connection. Cleaned up the terminals and reconnected everything with a 2155W difference from the original output on a 3200W inverter system.
Thanks for using FixYa.
Kelly
Mar 19, 2010 | Solar Electronics - Others
Electronics - Others Logo
596 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
