Question about Microwave Ovens
What is the silicon plate? On the inside of yhe machine
  • Microwave Ovens Master
  • 932 Answers
James,
Actually it is a silica cover plate, and it is usually mounted on the wall on the right side of the cavity up near the top. It covers the tube that goes back to the magnetron. It can occasionally get food particles behind it which can cause holes to be burned through the cover. A periodic wiping down of the inside should help in preventing problems like that. Hope this helps!
Posted on Apr 14, 2015
Outer glass on microwave door came loose how do you repair
if the glass can come off then use high temperature RTV gasket maker silicon, dip the silicon towards the inside of the glass and attach the glass to the door.
leave it there for 24 hours to cure.
Oct 23, 2017 | Microwave Ovens
Our base inside the machine won't go round
Sounds like the motor has blown, I did have this once before and I found by taking the glass plate out and turning motor top where plate rests on by hand a few times it started to work again but it might be gone anyway, you might be able to get a second hand one but a new one is about 30 pounds so might be advisable to renew machine.
May 10, 2014 | Sharp R-1405 / R-140 Microwave Oven
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
I have a whirlpool RM278BXS microwave oven. Inside the microwave oven along the rear bottom is a thin strip of sealant. The sealant is melted/burned in the middle section for about 1-inch long. I can...
Your best bet is to pull out all the old seal you can, and to trim what's firm with a razor blade.
Sand it smooth if necessary, then clean it squeaky and apply new caulk / silicone sealant.
Leave the door open to allow it to dry out overnight.
If it's not repaired, moisture can cause rust, which will lead eventually disintegrate the metal and lead to to arcing and possible fire in time.
Jun 07, 2012 | Whirlpool Microwave Ovens
Purchased this machine a few years ago but never used it or even opened the box. Now want to try it out with grandson, but no instructions or recipes were inside the sealed box. Can you please provide...
Most instructions and plate/rollers etc are inside the cavity and are available as one opens the door in with the packaging.
If not contact the manufacturers web site and download the instructions.
Hope that helps.
Feb 25, 2011 | Microwave Ovens
Maytag over the range micrwave is intermitely sparking when in use otherwise working well.
If there is carbonized food on the plate or wheels for the turntable, that will make it spark as will a contaminated Wave Guide Cover. Yhe mica cover that protects the magnetron from food debris and steam. Check the cover is not arcing on the inside.
Feb 07, 2011 | Maytag Appliances Over-the-Range Microwave...
My microwave was making a popping sound. then while i was nuking some popcorn, i heard a loud bang. when i opened the microwave, i saw that the glass turntable plate on the inside had split into two...
What usually happens to make the plate break or shatter is heat build up in one place, caused by spillage of food stuffs that have "welded" themselves to the plate or a scratch on the plate allowing water to enter and when it gets hot explodes the plate.
There, from what you have explained and the information you have supplied, no reason to doubt the machine. A new plate and it should work again with no problem.
Hope that puts your mind at rest.
Nov 04, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Can i bake cookies on my sharp carousel with bake setting. can i use an ordinary micro safe plate or do I need something else?
yes you can bake cookies in the carousel on BAKE I suggest those new rubber looking bake plates help a lot to reduce the moisture that makes them soft.
I think they are silicone rather than rubber, i am sure you know the ones I mean
Thanks for using FIXYA
Oct 11, 2009 | Sharp R-1850A Convection/Microwave Oven
Our Jenn-Air built-in microwave in the kitchen appears to have had a bead of white silicone that sealed the interior cabinet walls and interior base. That has deteriorated away. Is it just cosmetic or...
Silicone will not block microwave radiation. However, it isn't only cosmetic. The silicone keeps liquid that spills inside your microwave (or even steam) from getting into the guts of your microwave and rusting and causing shorts.
Sep 18, 2009 | Microwave Ovens
Microwave Ovens Logo
47 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
