Question about Food Processors
Multi purpose blade will not stay attached?
When using the blade comes loose in the bowl..
    Top Expert:
  • Food Processors Master
  • 10,875 Answers
Wrong blade or its worn out,get a bew one
Posted on Apr 16, 2015
  • 1,305 Answers
Brand and model would make it more likely you will get a sensible answer, best bet is start again with a new question containing the relevant information.
Why wont my chopper blade come off in the unlocked position?
Help! My Cuisinart is Stuck! - Chowhound
www.chowhound.com/post/cuisinart-stuck-353459
Dec 21, 2006 - Read the Help! My Cuisinart is Stuck! discussion from the Chowhound food community. ... The lid seems stuck and won't come off. I've tried pressing down,... Make sure all the buttons are in the neutral position. Reply ... In case of clarification- Turn the lid back on before unlocking, then twist off. Reply.
How to remove a stuck Kitchenaid Food Processor Blade (blade in ...
https://answers.yahoo.com/question/index?qid...
Aug 25, 2009 - Now the blade in the smaller bowl (4 cup) does not come off the bowl.... UNless i take out the 4 cup bowl blade, it doesnt allow me to remove the bowl ... I've used the screwdriver method for years in my shop with nearly 100% ...
Jan 12, 2016 | Food Processors
Blade spins and hits side of bowl
Get in touch with Kitchen Aid, that should not be happening.
Feb 19, 2014 | KitchenAid Food Processors
Attachment stuck on shaft of food processor
put the mixing bowl up as much as possible. spray some wd40 into the groove between the attachement and the motor shaft. Wait for several minutes, then with a hammer and a piece of wood, give the bowl a good wack. With a few goes, it will gradually come off. I will be putting some butter inside the attachement from now on to keep it lubricated
Jan 11, 2010 | KitchenAid KFP750 Food Processor
I used the shredding blade and now can't get the inside spindle to pop off or the bowl. It will still work if I put the blade in and turn it on. How can I get the spindle and bowl loose?
I posted about this somewhere else. Sounds simple but it worked for me. Give the spindle a good whack with a wooden spoon all the way around and it will come loose.
Sep 01, 2009 | KitchenAid KFP750 Food Processor
We can`t disasemble it with the dough blade in, any tips?
All of the blades "lock" (rest in a groove) when rotated clockwise. This is so they'll stay put when in operation. When you take the bowl out with a blade in, you're moving the pair in a clockwise direction. So, you lock the blade in, thus locking the bowl down. Either remove the blade first by rotating it counter clockwise, then up or move the blade back 1/10th of a turn after rotating the bowl as far as it will go clockwise.
Jan 02, 2009 | KitchenAid KFP750 Food Processor
Food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Oct 07, 2008 | Cuisinart DLC-5 Food Processor
Food processor
If the blade is actually fused, I would seek professional help to avoid slicing your fingers off. You can test to see if it is fused by removing the lid of work bowl, twisitng work bowl to the left, and removing the work bowl - if work bowl will not come off (difficult even under normal circumstances), then find out from Cuisinart if you are still under warranty.
Jul 14, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Food Processors Logo
134 people viewed this question
Top Food Processors Experts
eyecam
Are you a Food Processor Expert? Answer questions, earn points and help others
