Question about Janome Memory Craft 9500 Computerized Sewing Machine
9500 says lower the pressure foot it is already down
  • Janome Master
  • 1,860 Answers
It sounds like the computer is not responding correctly, it would be a good idea to have the machine checked
Posted on Jun 04, 2015
Message says to lower pressure foot but it is already down
There is a little switch up behind the tension unit....when you lower the presser foot a lever moves, one side closes the tension discs, the back closes the microswitch. Your switch is either not engaged because the tension unit was not re-installed correctly of the switch has been blocked by something. I have never had a switch fail.
Nov 24, 2013 | Baby Lock Ellure
I get message to lower pressure foot but it is already lowered
Pressure foot microswitch behind the tension assy is not working.
Toyota sp100 sewing machine - can't lower foot pressure on clothing
Berend: Thick fabrics require a longer stitch length. If the longer stitch length doesn't work check your attachments for an Easy Feed foot (It sort of mimics a walking foot.)
Dec 06, 2012 | Sewing Machines
Janome 9500 bobbin thread showing on monogram
it sounds like the machine needs to be serviced & the top tension needs to be checked
Apr 14, 2012 | Janome Memory Craft 9500 Computerized...
Pfaff 6091 Presser foot won't go all the way down
HAVE THE 6091 MACHINE AND THE FOOT IS NOT FROZEN BUT WON'T GO DOWN. OILING THE MACHINE DID NOT HELP AT ALL. HAD A REPAIR MAN COME TO THE HOME AND CLEAN THE MACHINE. STILL THE FOOT WILL NOT GO DOWN.
Nov 21, 2011 | Sewing Machines
How do I change the presser foot on an elna mini sewing machine?
I dodn't know your model really well but it will be one of the following:
a clip on foot that you just pull down on to remove,
a clip on foot with a button at the back of the pressure foot holder - press the button to release the foot
a clip on foot with a little lever at the back of the pressure foot holder - lift the lever to release the foot
If it is a clip on foot, then you just need to raise the pressure foot lever, put your fingers onto the pressure foot and press downwards, it should unclip.
To put one on, place the pressure foot onto the needle plate under the pressure foot bar and lower the pressure foot bar down onto the foot, lining up the base of the foot holder with the little bar on the foot, it should click into place.
Oct 10, 2011 | Elna 2007 Mechanical Sewing Machine
What is pressure foot on sewing machine. where is pressure foot
This is the foot that comes down and holds the fabric layers under the needle.
There will be a pressure foot lever to raise and lower the pressure foot at the back of the sewing area, it usually operates vertically, although some makes have a lever that works horizontally.
The pressure foot needs to be lowered BEFORE you start stitching as it activates the top tension and also helps with the stitch formation by holding the fabric firmly as the needle moves up and down.
You can read some general sewing machine info at www.sewing.about.com too.
Mar 29, 2011 | Janome Harmony 2039 Mechanical Sewing...
I place the fabric on the machine, lower the foot and apply pressure to the foot peddle, when the machine begins to sew fabric is pulled down and the lower thread tangles, the machine make a crunching...
This is easily solved. Before you start sewing make sure your upper and lower threads are long enough for you to hold before lowering the presser foot. If these threads are too short they both get carried down into the bobbin along with the fabric and cause a big tangled mess. Always hold your threads at the back of your work with your left hand then lower your pressure foot and don't release the threads untill you have taken several stitches. Keep holding these threads during backstitching at the beggining of a seam too. Works like magic.
Dec 21, 2010 | Brother XL-3500
Janome Memory Craft 9500 Computerized Sewing Machine Logo
79 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
