Question about Panasonic Audio Players & Recorders
Pls how do I pair my new Panasonic subwoofer sb- hwa520 to it soundbar,thnx.
napps
SOURCE: Subwoofer
is it just the sub you have or do you also have the dvd unit with it?
Posted on Mar 10, 2008
  • 104 Answers
SOURCE: need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Posted on May 23, 2009
jedweller
  • 21 Answers
SOURCE: Panasonic sb-wa 340 active subwoofer
This is normal operation.. The subwoofer will only play sounds below a set frequency...There may be a crossover setting in your menu that you can adjust the frequency cutoff to your liking.
Posted on Oct 01, 2010
dunnbiker
  • 8546 Answers
SOURCE: how to connect the speakers to the sb-wa342
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Posted on Jan 21, 2011
SOURCE: panasonic dvd player for subwoofer
SA HT730 DISPLAYS NO PLAY OR NO DISC
Posted on Aug 09, 2011
I do not have the remote to my lg bluetooth soundbar subwofer anymore and they arent pairing can you help please
Press and hold PAIRING in the back of subwoofer for more than 5 sec,
until LED on subwoofer blinks red and green alternating.
Unplug the power cord of the soundbar and the wireless subwoofer.
Connect then again after the LED of the main unit and the wireless subwoofer fully turned off.
Jul 06, 2017 | LG Cell Phones
No to hook sound bar to element TV and my DVD player at the same time
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
Jan 11, 2016 | Sanyo Televison & Video
Can't sync my JBL SB400 subwoofer to the soundbar??....it flashes blue and goes back to orange. Sound bar works but can't pair sub!..HELP!!
PAIRING THE JBL SB400 FOR WIRELESS OPERATION
After turning the soundbar and subwoofer on for the first time, you will need to "pair" the subwoofer and soundbar so they both operate at the same wireless frequency. To pair the units, press the Wireless Pairing switches on both units within 30 seconds of each other. The units will communicate with each other and operate at the same frequency.
May 21, 2015 | JBL Audio Players & Recorders
Subwoofer not working.
Most likely, the "remote" wire to the subwoofer amplifier has come off or is not making good connection.
May 15, 2015 | JVC TH-BA1 Soundbar System with Wireless...
Vizio help
Not sure the issue. HDMI from cable box to TV. Same with Vizio.
The soundbar usually connects to the optical out from the TV to the in on the soundbar. Subwoofer has to be paired to the soundbar. Instructions should explain or maybe find online by manufacturer
Aug 15, 2014 | Televison & Video
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
Pairing my lsb316 sound bar and subwoofer
There is a button on the back of the sub that you need to press to complete the pairing..the led will be green when paired successfully or red if it is in standby mode
I have a Panasonic SB-WA340 Active Subwoofer, and need to know if this is compatible with other Panasonic home theater units?
It should be compatible with other Panasonic equipment that has an output for a powered subwoofer
Dec 25, 2012 | Audio Players & Recorders
I have the Panasonic SB WA1050 Subwoofer and can't keep it on. It turns on, plays for about a second and then the power light blinks from green to red and all sound stops. It is still paired with the...
I recently had the same exact problem and found a power transistor had got a broken lead. The one on mine was on the board that the cord plugs into. It has a large heat sink that worked loose from all the subwofering. I removed it added a wire lead to it and reinstalled it. With a lot of silicone to help stop the thing from moving during use. Not sure if your up to this but an electronic shop could do it. It took me about an hour to repair once I found the broken lead.
Jan 11, 2011 | Panasonic SB-WA100 Subwoofer
176 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
