Question about Honeywell Dryers
Stopped oscillating after 2 weeks.
I recently purchased a Honeywell Tower fan HY-o48BP. It worked great for a couple of weeks but now it will not oscillate. Ionizer seems to still work. Any ideas?
jmeredith
  • 417 Answers
SOURCE: Aloha Breeze Tower Fan Will Not Oscillate
hi,
yes this is the oscillation motor, and they generally arent servicable, and need to be replaced, you can try and oil it, sometimes they have small air vents, and you can do a voltage test with a voltmeter but I believe the motor has failed or is gummed up, you can try and take it apart, they are held together with bent metal compression areas along the circumfrence of the motor, try sewing machine oil, you might have to do some research to find a replacement motor, maybe take it to a local clock shop, those motors are very close to what they used to put in old wall clocks.
good luck
J
Posted on Aug 05, 2008
SOURCE: LASKO fan problem
Check for a loose wire in the wiring harness
Posted on Sep 04, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: heating element has stopped working just 2 days
use a multimeter to check the continuity of the heating elements. if there is an open, replacing it will solve the problem.
Posted on Aug 04, 2009
  • 347 Answers
SOURCE: Lasko fan will not ocillate
check the oscillating gears usually made of plastic
Posted on Aug 30, 2009
SOURCE: I have lasko fan sudenly it stoped oscillating can
I have the same issue, i determined the oscillating motor has a bearing failure. I need to find a replacement motor.
Posted on Jan 10, 2010
Hy108tgt
Our HY-108 (not a HY-108TGT) does not have a filter when it was purchased new from a Retailer.
IMHO, Honeywell/KAZ designed these Tower Fans to be disposable if they fail to work or need cleaning.
These Fans are hard to disassemble for service or maintenance, OEM replacement Parts are unavailable to the general public, service documentation is hard to find, and the Tower Fans tend to have a short Product lifespan. THEY BREAK EASILY! The OEM Service Manual points to replacing complete parts assemblies because few electronics diagnostics and no schematics are provided.
The HY-108 case can start to be disassembled (I have done so on ours) by *First* removing the screws and separating/removing the plastic Base from the main Case assembly. *Second* remove the Phillips-Head screws on the back of the Case. *Third*, the internal plastic 6 Tabs that keep the 2 halves held together need to be gently separated - careful, they break easily. You need to gently loosen the internal plastic "Tabs" by using a thin flat-head screwdriver to gently and carefully separate the outer shell cover.
Apr 19, 2014 | Honeywell Dryers
Honeywell HY-108 fuse
is imple you must take out the cover and see if the fuse is glass or ceramica unplugged the device from wall. and the same type of fuse, voltage, and amperios, YOU CAN NOT PUT MORE OR LESS ONLY EXACTLY. Otherwise you will have burning.
God bless you
Aug 02, 2012 | Honeywell HY-108 8-Level 32 inch QuietSet...
Where is the fuse on a honeywell quiteset hy-108
KAZ Inc. has franchised the use of Honeywell's company name to manufacture/market this KAZ OEM HY-108 Tower Fan. The small 2.5A fuse you are looking for is located inside the 2-Prong Electrical Outlet Plug. This tiny 2.5A Fuse can be hard to find as a replacement in retail Hardware Stores, but see if you have an old LONG string of indoor/outdoor Christmas Lights... some of these Christmas Lights Strings may have the correct 2.5A Fuse you need. IMHO, it's strange that KAZ Inc. did not put instructions in the Honeywell HY-108 Owner's Manual where the Fuse is located!
May 31, 2012 | Honeywell Hy108 Tower Fan
Hello i have the Honeywell Quietset 8 Speed Tower Fan. We purchased it from target last summer. It was a great working fan, loved how lightweight it was and it was extremely quiet. Not too long ago it...
The cord has a fuse at the plug. Check the fuse it could be blown. To access the fuse there is a slide open door that is about 1" x 1/4" on either top or bottom of the actual plug.
Jul 07, 2011 | Honeywell HY-048BP Tower Fan
Dryers Logo
56 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
