Question about Winter Sports
I have silver power packs that fit on the back of my snow boots but one has snapped so the connector from the boot is now stuck in the charger socket of the power pack.
My boots are Atomic Sport Fit 102 mm
3 Suggested Answers
  • 2712 Answers
SOURCE: how to fit a snowboard boot?
" * Put on Snowboarding Socks or at least the thick socks that you would wear when you'll go Snowboarding. Do not try your Boots with regular socks. You might think it's irrelevant, but the added thickness of the socks matter a lot when it comes to the size and fit of your Snowboard Boots. Still, some people have strange misconceptions about socks. One of which is that you have to wear more than one pair of socks. This is certainly wrong since Snowboard Boots should fit snugly. It is all right if toes are grazing the ends of your boots, but make sure they aren't jammed. After all, when the boots break in a little they will feel more comfortable. * Loosen the outer (and inner if available) laces of the Snowboard Boot and insert your foot. Make sure the heel of your foot is locked in the heel of the boot. * Tighten the inner lacing first (again if available). Make it pretty tight but make sure your feet can still breathe and you don't cut off circulation. Next, tighten the outer lacing, again pretty tight, without killing your feet. * Walk around a bit and get a feeling for how well the Snowboard Boots are strapped around your feet. Make sure you don't feel any isolated, painful or stressful areas. * Now the most important test: strap into (or step into) a binding attached to a snowboard. Take on a riding position and move your weight to the front and the back of the board. Be sure the boots are securely keeping your feet on their place. Also, make certain that they are not slipping to the back or front, and that you are not experiencing painful or stressful areas on your feet. The Snowboarding Boots should make you feel both comfortable and securely strapped-in at the same time. * Lean forward. When you do this, make sure that your heel is not lifted, but that the entire boot, binding and board are making the forward move without your heel slipping out of the heel of the Snowboard Boot. If you do experience heel lift, your boot tech can add some fit aids like an Eliminator Tongue to reduce volume and increase responsiveness. This will also ensure that your heel is not slipping out of the boot. * When you try on Snowboarding Boots, take into account that as you use the boots more often, the inner bladder will get less compact because of the pressure that the bladder will be exposed to. Consequently, the Snowboard boots will become less tight as you use it more. Try to anticipate this trend by buying boots that are slightly tight. After the boots break in a little they will feel a lot better. Snowboard Boots come in all regular shoe sizes. Still, keep track of how different boots of similar sizes can vary in the way they hold your feet and ankles. Don't Buy Snowboard Boots because the internet or your friend says its cool, or your favorite rider has his/her name on it. What may feel good to one person may be excruciatingly painful to someone else. Make sure to try on many boots and only buy one that you are 100% sure of. Quality Snowboard Boots can last long, so you will want to put in more time and spend some money on this. Regardless of the Type of Snowboard Boots you intend to wear, choose the pair that fit your feet best. After all, you wouldn't want to be out of control and in pain when you ride down the slopes."
Posted on Dec 01, 2008
  • 2712 Answers
SOURCE: boot size fit to board width
8 or Smaller Board Width 24cm or less (Narrow) 8.5 - 10.5 Board Width 24 - 26cm (Regular) 10.5 or Larger Board Width 26cm or More (Wide)
Te lower end of the boot is stuck on the spark plug on mx5 mk2 1999 how do i remove it, thanks
Try using long handled pliers and a rag to grip the part where the connector snaps on top of the plug. slowly work twisting a little back and forth while putting a pulling force on boot . Chances are the boot and wire are shot anyway. Replace with proper type wires with silicone boots and apply spark plug grease to prevent arcing and sticking the next time. Wires can be expensive but well worth the investment. Autolite makes excellent wire sets. Route them exactly as the old ones to prevent crossfire.
Dec 12, 2017 | Cars & Trucks
TomTom Rider unit wont charge. Tried mains charger, USB connector and bike charger. Swapped out the battery and the unit boots up but that is just the charge in the new battery. Any help appreciated.
Power board is faulty, repair or replace. Workshop repair required. Oh, stop plugging a charger into the USB socket. It doesn'tlike it, thats for data transfer only. The round pin socket is the charger port
Oct 30, 2013 | Tomtom RIDER GPS Devices
I unplug my front audio connector cable and usb 2.0 connectors on my motherboard while putting in a new graphics card in the pci-e slot. After I inserted them back, my pc didn't want to switch on and I...
Uninstall the newly installed Graphics card and boot again. If it boots up normally, then the graphics card must be incompatible with your motherboard or might have some defect with it. Or if the system doesn't boot up even after the new graphics card is uninstalled, then you need to recheck the connectors and make sure everything is connected/inserted properly and fitted. The best way to check connection faulty is, plug-in one after another while you boot the system everytime... you plug in a connector. First connect the power switch and so on..
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Oct 08, 2010 | Biostar MCP6P-M2+ Socket AM2+ GeForce 6150...
Where and how to change 2001 olds aurora spark plugs, 6 cyl? yhanks
1 - remove the engine vanity cover. 2 - Disconnect the electrical connector from the coil pack. This is the silver thing the electrical connector goes to. 3 - remove the coil pack (about 6-8 bolts). It may require some jiggling as the rubber boots that go to the plugs will have some resistance. 4 - Note, you should so this with the engine warm. 5 - Now you have access to the plugs. Rear: 1 - a little more difficult. You have to remove/loosen some of the assembly covering the coil pack to get it out. 2 - getting it back in is harder, because you can't see well in the back of the engine.
Aug 27, 2010 | 2001 Oldsmobile Aurora
Compaq presario a900 model a931nr wont boot, help!!!?
Sounds like the battery is in trouble (discharged) or the charger is bad. If you have access to a voltmeter, read the voltage across the power cable plug with the pack plugged into the house outlet socket. Does a lamp work when plugged into the same socket? If the pack checks ok, then the battery may not be able to receive charge. Have it checked by a dealer.
Jul 16, 2009 | Computers & Internet
Plug replace
This is a outstanding question!!! The plugs or wires are not visible from the top or sides of the moter. You just can't see em'!!! You have to remove the large black plastic air intake. Then remove the intake manafold(not too hard to do) to access the spark plugs and wires.
Also: After removing all the black plastic air intake stuff, you'll have to remove the coil pack (long black plastic thing that says "Ecotek" on top). The coil pack is removed by disconnecting the wire connector on the driver's side end and then removing four bolts. To lift off the coil pack, you'll have to pull upwards firmly and evenly from both sides, because the spark plug boots or wires are holding onto the spark plugs as well as the coil. With the coil pack removed, look down into the silver channels - there's the plugs. To remove, you'll need a plug socket head and a socket wrench with long extension. To replace the plugs, I use an extra or old spark plug boot to hold the plug and get it started turning into the engine threads. Good Luck!
Jun 07, 2009 | 2003 Saturn VUE
Replace spark plugs 2004 dodge intrepid
__________________
Changing Spark Plugs
First off, on this model you don't have plug wires, you have coil packs with a boot and coil connected to the pack. The boot slides on the tops of the spark plug. The good thing about this is that you don't have to mark each wire to its location.
So to replace the plugs you need to disconnect the electrical connector to the coil pack and then unbolt the two bolts that mount the pack down, then remove the pack.
Next with a ratchet, an extension and a special spark plug socket, which has an insulator inside to protect the porcelain from getting cracked, remove the spark plugs.
Next step is to replace the plug, usually I slide off the boot from the coil pack and then remove the coil from inside the boot and slide the boot over the spark plug and start to thread the plug back in. Using this method allows to you feel if you are threading the plug in right. Then with a torque wrench you would torque the spark plug to the specs for the type of engine you have.
3.2/3.5L Engine (20 ft-lbs)
2.7L Engine (13 ft-lbs)
Next reinstall the coil pack with the two mounting bolts, it is only necessary to hand tigthen the two bolts. Then plug back in the electrical connector and continue this process on the next 5 spark plugs.
__________________
Changing Dome Light
To remove the map light bulbs you need to first remove the overhead console.
To do this you need to remove the screw at the front of the overhead console (which is more towards the front windshield).
Next you need to pry down on the rear of the overhead console and then disconnect the electrical connectors.
Then, with the overhead console pulled down, pull of the map light bulbholders and replace the bulbs.
Installation is the reverse of the removal process.
Apr 14, 2009 | 2003 Dodge Intrepid
Changing spark plugs 2004 dodge intrepid
Apr 14, 2009 | 2004 Dodge Intrepid
System does not boot on 1st attempt
you first of all check your power switch and then your power pack
Jan 21, 2009 | Foxconn G31MX-K socket LGA775 motherboard
How to remove mirror glass 2008 ford f350
here's 2003, don't have 2008
Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
All exterior mirrors
  1. Position the exterior mirror glass in the full down position.
  1. Grasp the top and carefully pull the exterior mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior mirror glass.
Power exterior mirrors
  1. Remove the jack pins from the exterior mirror glass backing plate.
    • Use pliers to grasp the jack pins at the base to remove.
Installation
  1. Remove the sealing boots from the exterior mirror motor.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Hold the legs of the jack pins and push the jack pins back into the exterior mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar and turn each jack pin until the head of the jack pin is aligned with the slots in the sockets on the backing glass plate.
  1. Place the new exterior mirror glass assembly down on a smooth firm surface.
  1. Align the friction pins vertically to the exterior mirror glass backing plate socket and push down to snap the pivot ball into the socket.
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over heat the exterior mirror glass backing plate. Heat only until backing plate is warm to the touch.
    Using the special tool, warm the main pivot sockets in exterior mirror glass backing plate.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
NOTE: If the jack pins do not engage, they may not be aligned correctly. Remove the exterior mirror glass, align the jack pins to the slots in the sockets and repeat the installation procedure.
  1. NOTE: The jack pin should click while manually adjusting the exterior mirror glass.
    Tilt the exterior mirror glass to the full outboard position and then press on the outer side of the class until the in/out jack pin snaps into the socket on the exterior mirror backing plate.
    Tilt the exterior mirror glass to the full down position and then press on the outer side of the class until the up/down jack pin snaps into the socket on the exterior mirror backing plate.
Nov 14, 2008 | 2008 Ford F-350
Winter Sports Logo
189 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
