Question about Earthwise 1850 PSI Electric Pressure Washer
The motor keeps kicking off. It will cycle a few times and then stop. What causes it to shut off or lose power?
It ran for about 5 minutes and then the motor stopped. Water ran thru it but with no pressure.
2005 GMC Yukon Denali's computer shuts down after the truck warms up
sounds like a fuel problem, how many miles on vehicle? as a quick fix it would be worth using a fuel addative , you haven't said if petrol or diesel, if petrol get addative that covers the catalytic converter ,having a blocked exhaust system can cause engine to stall also get the OBD codes read as this will tell you what if any sensors/switch's are faulty
May 15, 2014 | 2005 GMC Yukon Denali
200,000 BTU Oil Fired Dayton: Shuts off
id check the theromastat for proper cycleing and the ignightor
Jan 15, 2008 | Dayton E52 Utility Heater
Won't start
most of the time it is a weak motor going bad,to weak to turn the drum-mike
Feb 06, 2010 | Kenmore Dryers
Shuts down after few loads....will run again after cool down.
sounds like motor is overheating,if capacitor is faulty this could be cause,the microfarards should be as per whats on side of capacitor,or motor could be bad ,most motors have a thermistor which stops motor from running if it overheats,next time it happens check if the motor is very hot ,be careful it could be very hot,make sure unit is switched off,also could be an overheated mains wire but usually fuse blows in this case,hope this helps
May 10, 2009 | Dryers
Our Oven seems to be stuck in the Self-cleaning mode
Have you tried unplugging it and then reapplying power after a few minutes? Sometimes a power down/up cycle will reset the logic..
Sep 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Mixer motor shut down
Mine did almost the exact same thing one day. I have the Artisian Model, It would do it on any of the lowest speeds. Dont know if this will help you or not but I just ran mine the next day on all the way high with the spash guard on for making whipped cream for about 6 minutes full throttle and for some reason it hasnt went slow and shut itself off since then. Mine is about 7 months old. I called Kitchen Aid but their customer service all of a sudden seems to not know english worth a poo...
Try running yours on full blast for 5 minutes with something simple in the bowl. If its a 250 watt or higher make whipped water out of 2 cups of water and a tablespoon of cornstarch. Run it till you get what looks like whipped cream. Oh yea. Use the Balloon whip. The lubrication in the motor is supposed to last for at least 5 years but I have seen on numerous post's that if you run them on all the way for at least 5 minutes the oil will even out in the motor. Running the mixers at low speed alot will cause the oil inside not to move as freely since the motor doesnt heat up the oil in the gears.
Good luck.
Nov 15, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Earthwise 1850 PSI Electric Pressure Washer Logo
116 people viewed this question
Top Earthwise Garden Experts
Steve Sweetleaf
Steve Sweetleaf
Call Bill
Call Bill
montehammons
Are you an Earthwise Garden Expert? Answer questions, earn points and help others
