Question about Watches
Where I can get a clock movement Quartz W993 S.Haller ?
2 Suggested Answers
SOURCE: I am trying to find a complete W993 Quartz
I have a complete Haller W993.
Is this what you are looking for?
d.hind685@btinternet.com
Posted on Apr 04, 2010
How to fix the pendulum on an elgin quartz anniversary clock
I am unsure wha you mean by "fix the pendulum". If you mean it stopped swinging, there are two reasons: first check the battery and contacts. Remember, even a new battery can be bad, which is why new things come with warranties. The other thing is quartz movements usually don't last too long. If the pendulum is not swinging, and is correctly attached to the movement and the battery is good, then the movement has gone bad and you need a new one. Most all clock shops keep quartz movements on hand. If you are a do-it-yourself type, you can get them off the Internet. Be sure to remove the old one first and check how thick the dial is, that's how they sell them by dial thickness.
Oct 26, 2017 | Elgin Watches
MINUTE HAND NOR THE HOUR HAND NOT ADVANCING AS THEY SHOULD. CLOCK STUCK AT 8:45 FOR DAYS, PENDULUM MOVEMENT OK. WHAT IS THE SOLUTION TO GETTING THESE BACK TO WORK? THIS IS ON A STRAUSBOURG MANOR...
without seeing the clock .....are you sure it isn't something as simple as the hands ( arms) detaching from the centre spindle which continues to turn but without the hands. Alternatively have the hands become stuck on something on the clock face or become intertwined themselves ? Very simplistic but all I have to offer...
Feb 24, 2015 | Watches
Nowhere in the little operations manual that came with my watch does it give the accuracy of the timepiece. Where can I get that information? I have a movado ESQ bracer chronograph.
Interesting question. I know little about watches but, as you would know, your watch does have a quartz movement, so, from Wikipedia, 'Quartz clock':
Standard-quality resonators of this type are warranted to have a long-term accuracy of about 6 parts per million at 31 degrees C (87.8 F): that is, a typical quartz wristwatch will gain or lose 15 seconds per 30 days (within a normal temperature range of 5 deg C / 41 F to 35 deg C / 95 F) or less than a half second clock drift per day when worn near the body.
If a quartz wristwatch is "rated" by measuring its timekeeping characteristics against an atomic clock's time broadcast, to determine how much time the watch gains or loses per day, and adjustments are made to the circuitry to "regulate" the timekeeping, then the corrected time will easily be accurate within 10 seconds per year. This is more than adequate to perform celestial navigation.
Assuming that you have a computer with internet-synced time and good internet, meaning around 1/100 second accuracy, why not compare the watch to the computer over the space of a week?
Sep 04, 2012 | Movado ESQ by Movado BRACER stainless...
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    What is the main internal assembly of the Casio forester watch called? Replacing the battery does not work.
    mcdevito75 here, The Internal workings of all watches and clocks, Quartz and mechanical is called the movement. You may have a weak or even dead battery, even if the battery is new. If you"ve dropped your watch, got it water logged, you could have hurt the Quartz movement. It'll take special equiptment to check the Quartz movement to see if it"s burned out. I would try another battery or at least double check this batteries instalation in your watch. For more info, here is Casio"s contact number, 800-435-7732 9AM--5PM EST.
    Aug 03, 2010 | Casio Forester PAS400B-5V Wrist Watch
    Ca i put new clockworks in an old clock face - i have a vintage coffee pot clock with a light up perculator that i love- the clock no longer works-the light does- can i just buy a clock mechanism from a...
    mcdevito75 here, If the old clock works are Quartz, you may not be able to get a new Quartz movement as it may not be made anymore, BEST BET, look for a small watch repair shop in your area, I'm sure they can do something.
    Jul 11, 2010 | Watches
    HOW TO SET NEW PIRELLI YACHT TIMER WATCH? MANUAL NOT SENT WITH WATCH. IS THERE A FREE MANUL POSTED ON INTERNET? MODEL 41008, S# 7951903215 Many thanks for the help.
    This information comes from the movement manufacture and helps figure out what does what. I also have a yacht timer with no instructions.....hope this helps
    A combination of design and technology, ISA 8270 is a precise racing timer developed especially for yachting races, displaying count-down during regatta departures with audible signals, followed by cumulated time during races. The dimensions (25.60mm, H 4.60mm) offer a large variety of opportunities for watch designs. It is suitable for the manufacture of models for gents and ladies watches.
    This new calibre is an analogue quartz timer fitted with an alarm function. It displays the hours, minutes, seconds (small jumping seconds at 2 o’clock counter), and date shown by a date window at 6 o’clock. In addition, it allows count-down and race timing. The small hand at 10 o’clock counter and the central hand facilitate the display of count-down and time measurement clearly visible.
    Count-down, Racing Timer and Alarm features
    ISA 8270 yachting movement not only provides the traditional count-down at 10, 6 and 5 minutes, but also the versatility of setting count-downs at any minute from 10 to 1 minute.
    One special feature is that it allows the possibility of recalibrating the count-down at every minute up to the last minute before departure. This latter function allows the navigators to readjust the watch at any time during the count-down to the closest full minute in order to be in line with the official procedure announced by the racing committee (RC) boat so as to get off the best possible start. Audible signals are emitted every minute to alert the progress of count-down. To give higher accuracy, every-second audible signals are emitted during the last 10 seconds count-down to ensure knife-sharp precision. Immediately after the departure, the count-down automatically shifts to the racing timer mode to measure the time of the race event for a maximum of 96 hours. Setting, start/stop and recalibration of count-down and race timing are facilitated by the pushers (at 2 o’clock and 4 o’clock), which are easier to operate.
    Thanks to an oversized counter hand and a highly visible flange on the dial that our customers may design, the navigators can best monitor the time remaining before departure and during the entire procedure.
    The alarm time is displayed in an analogue mode. Alarm start/stop is enabled by a pusher at 8 o’clock and is displayed by a central alarm hand (12 hours).
    Superb performance
    Born of precision, accuracy and innovation, ISA 8270 offers excellent quality and performance. Intended for yachting races, this movement gives answer to sports watches requiring indispensable qualities: strength, endurance, agility and outstanding speed.
    When the trend of sportive and fashionable quartz watches prevails, this new Swiss Made ISA 8270 priced competitively with outstanding performance answers the expectations of an increasing market demand and customers, who wish to add a number of value-added exceptional designs to their next collections with strong sporting character.
    Specifications
    Calibre: ISA 8270 Yachting Movement
    Size 11 1/2’’’
    Swiss Made quartz movement, 9 jewels
    6 hands, 2 counters, 3 pushers
    Hour, minute, small second at 2H counter
    Date window at 6H
    Count-down (max. 10 minutes)
    Racing timer (max. 96 hours)
    Alarm (12 hours)
    Technical information
    Diameter: 25.60mm
    Movement height: 4.60mm
    Height of stem and pushers: 2.25mm
    Jan 15, 2010 | Watches
    How does the swiss eta g10.211 quartz chronograph work
    I am not sure if I understand your question. Are you asking how this particular quartz movement operates?
    All Quartz movements are pretty much the same operational wise. They can vary greatly in materials used for construction and number of jewels.
    At it's basic a quartz watch uses a piece of quartz crystal called a transistor oscillator to vibrate a tuning fork. This vibration is a is brought down by micro processors to a meaningful number then converted into mechanical energy trough the movement and hands.
    In the case of a chronograph it means more internal gears and jewels.
    Although this is a good movement it is the low side of middle of the road.
    The G10.211 is an analog display of hours and measured time. These include hours, minutes and a small jumping second as 6 o'clock. Mechanical date and counters for 1/10 second, 60 seconds and 30 minutes with "ADD" and 'SPLIT" functions. Operated by 2 push buttons.
    It has 6 jewels.
    If you want to know something more specific please just ask.
    Hope this helps.
    Dec 31, 2009 | Bulova Watch
    Go to any watch or jewelry shop.
    Dec 27, 2009 | Watches
    Does anyone know where to get a replacement 'movement' for the Michael Graves's Alessi mantle clock.
    Yep - I know a clock repairman in California who still has some of the original Hechinger Quartz Movements for the Alessi pendulum clock . Definately worth repairing .
    Jul 13, 2009 | Watches
    Watches Logo
    232 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
