Question about UPG 9Ah 12V Sealed BATTERY Fits Aqua Vu Marcum Vexilar 12VOLT - 2 Pack - UB1290MP28
When I move camera from suspension by cable I get no picture, letting it rest with no strain on cable picture comes on the monitor
When I turn on my micam junior video camera the screen is black and it only makes beeping sounds
it's monitor connecting cable may be broke, try by connecting to tv if picture not coming then must test inside.
Jan 16, 2016 | Video Cameras
SAMSUNG SMO-211QN SECURITY SYSTEM
1. Connect LAN cable of Cable/ADSL modem or Direct Fixed/Static IP LAN Line to WAN port of IP Router.or hub/sw with cable/lan terminal
2. Connect LAN ports of IP Router/switch/hub(1~4 or 1~8) to Ethernet port SMO-211QN/SMO-150QN to be set up and to
Ethernet port of Local PC to use during setup.
3. Connect Video cable of Camera to MONITOR.
4. Turn on the MONITOR power.
This a basic setup local no internet static ip you will have to
follow directions for setup in the software program you install
on the computer the uset the computer. The computer connected to the lan terminal
I am just giving you the basics you are goilng to have to read
and understand the rest as far as the rest of the setup on the
computer This is from page 107 of your manual
Link to manual if you dont have it
http://www.retrevo.com/s/SAMSUNG+SMO-211QN+users+manual+?sub.x=75&sub.y=14
Dec 07, 2007 | Samsung Color Indoor Security Camera with...
My benq monitor keeps coming up no signal detected
Step 1:
Problem isnt the monitor, its the computer not booting or a damaged Graphics Device..
1.) first verify that the cables are connected properly..
Step 2:
remove the side panel of the cpu, UNPLUG the power firsty..
Step 3:
locate and remove the battery on the main board (its like a big watch watch battery)
Step 4:
press and hold the power button for 30 seconds
Step 5:
release it, replace the battery
Step 6:
plug in and turn on
Step 7:
press the key to enter setup (its displayed on the screen)
Step 8:
restore default settings or optimized settings, save and exit
Step 9:
thats it your done.
let me know if you need more help just in case that doesn't work do you have a graphics card ?
Dec 29, 2012 | Computers & Internet
I was using my Nikon coolpix s205. after taking pictures, it went on standby mode and when i was going to use it again, the monitor was just black and i cannot take pictures anymore. i tried to turn it off...
All I can suggest is 1) Fully charge the camera. and 2) Make sure NO cable is attached to the camera when you turn it on.
Background; Lens motors use lots of power and with a dead battery they do not work very well (stuck) When you have a cable attached to the camera the monitor WILL shut OFF.
May 02, 2017 | Nikon S205 Digital Camera
My Monitor, which had never been used but been in storage for about 1 year, has a 2 inch translucent vertical pink stripe down the left hand side. Rest of image is perfect. Any idea how to make this go...
Check the RGB settings from the monitor panel.... Plus try moving the neck of the monitor left and right a couple of times.... Sometimes, the picture tube displays illegitimate pictures with some twisted cables or so...
Jan 09, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Only half the screen is showing up the rest is black and there is no way to click on the black space or move it
Hi im Rain.
Ok there is a way to check if its the monitor or the video card is bad.
  • unplug monitor from computer
  • look for the monitors self test screen
If the self test screen comes up and you have a full picture. Then its your video card that is the problem.
If the picture is still the same after being unplug from the computer, then your monitor will need replacing or servicing.
Nov 24, 2009 | Lands Phones
My coolpix l100 take very poor pictures. They are
Are you holding down the shutter button half-way and letting the camera lock in the focus before pressing the rest of the way?
Sep 26, 2009 | Nikon COOLPIX L100 Digital Camera
Monitor powering up and down at random
Check monitoc cableing. This might be the cause of cable having loose connection on the back of the monitor. (I mean data cable (VGA) not power cable)
Did you have a chance to check with another monitor? Will picture appear when cable on the back is moved?
Does this happen when you logon to bios screen? REstart PC and keep pressing F2. You will see bios screen - test unit there. If that is ok then everything is fine with the monitor.
Let me know if issue is not solved by checking cable and I will provide you futher troubleshooting steps.
Thanx
May 28, 2009 | Samsung SyncMaster 931BF LCD Monitor
No good pictures
The symbols you are seeing are the blur warning indicators.
The yellow hand warns you that the picture may not be quite sharp enough for a standard 6" x 4" print - however you may be happy with it.
The red hand warns you that the picture is most likely to be poor quality, and won't produce a good 6" x 4" printed photo.
The reason you're getting these indoors, is that there's not enough light for the camera to take a good picture. As it tries to do so, it opens the shutter for longer to let more light in - however on doing so, if the camera isn't absolutely still, then the warning symbols will come on.
To remedy the above I'd have the following suggestion - if possible and practical, when shooting indoors, try and rest the camera on something solid when taking a photo. If this is not possible - try leaning against a wall to stabilise yourself. Even though you think you are holding the camera still - it's moving quite a lot.
Try one hand held photo - and one photo with the camera resting on something solid like a table and see what the difference is.
May 24, 2009 | Kodak EasyShare C743 Digital Camera
Locked Memory Card
on the side of the memory card theres a little slide thats normally a differant colour to the rest of the card just move this slide to its other position
Mar 25, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
UPG 9Ah 12V Sealed BATTERY Fits Aqua Vu Marcum Vexilar 12VOLT - 2 Pack - UB1290MP28 Logo
723 people viewed this question
Top UPG Computers & Internet Experts
Richard416282
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you an UPG Computer and Internet Expert? Answer questions, earn points and help others
