Question about Sewing Machines
Babylock 4-736, thread will not make a chain. I have threaded it several times according to the proper order. What am I doing wrong?
  • Sewing Machines Master
  • 1,860 Answers
Try changing the needles
make sure the tension is correct
could also be a timing problem
Posted on Jun 03, 2015
Mimito7
  • 128 Answers
SOURCE: bottom thread is looping.
If the thread is looping on the bottom, then your problem is on the top. Pull the thread out of the needle and and put the presser foot down. If the thread pulls thru easily, then you need to rethread your machine making sure the thread is thru the top tension wheel correctly.
Rule of thumb::
Loops on the bottom, Problem on the top
Loops on the top, problem on the bottom.
Posted on Apr 26, 2009
  • 20 Answers
SOURCE: Feed dog on Serger Babylock 5260D
Make sure that the presser foot dial (the silver "knob") on top of the machine is not too loose. You can adjust this w/ a nickel; tighten it all the way down & then loosen about 4 full rotations for cotton fabrics. Also make sure the Differentail feed lever is on "N". You can order a book from your local Baby Lock dealership for all models. Good Luck.
Posted on Jun 18, 2009
  • 14 Answers
SOURCE: on a babylock elegante the bobbin thread shows,
Have you reset the tensions for this machine, look in your manual and follow directions. If this is an Elegante there is also a set of instructions on the machine. On the LCD screen there is a picture of a sewing machine with a question mark, touch it, find Troubleshooting and touch that then find the problem you are having and read. If this does not help take it to a Brother dealer and have it reset so as to keep you machine in good running order.
Posted on Jul 07, 2009
trial2962
  • 107 Answers
SOURCE: Babylock Serger Question
You might take a look on eBay item # 150373367524
Thank you for the question
Posted on Nov 06, 2009
bargainbox
  • 1388 Answers
SOURCE: Embroidery bobbin problems.
Each manufacturer have their own bobbins.......not interchangable
Posted on Nov 28, 2011
Babylock imagine - The left lower looper is NOT chaining with the rest. How can I correct this? I've rethreaded a zillion times and it goes thru OK - but not chaining still.
When you rethread or break a thread, ALWAYS pull the threads loose from the back of the needles so all thread are not entwined with each other yes still threaded. Try again and if not chaining there is one step missing on one thread. You just have to rethread again until you correct the missing thread guide.
Oct 19, 2017 | Sewing Machines
I was sewing along on my Babylock Imagine Serger and out of no where my upper looper stopped chaining. It appears maybe the timing is off? I am not sure what the deal is does anyone know?
Have you removed all the threads and rethreaded from the beginning? Sometimes a thread has popped out of a guide. Verify it is threaded correctly and be sure you ALWAYS RAISE the presser foot when threading.
It could very well be that your machine is out of time. Sergers are difficult to re-time so you may need to take it for service.
Mar 02, 2017 | Sewing Machines
Serger Jancome 7933 will not make stitches
Is most likely threaded wrong check your manual for a proper threading
Jul 21, 2016 | Sewing Machines
My brother 1034D is not making a chain stitch. I've rethreaded it hundreds is times & replaced the needless, I've cleaned it. I think it's the timing, but I can't find how to fix it. Any help?
You didn't indicate what happens when you try to stitch. Does the thread break? Is it just not forming a chain?
Confirm that the needles are installed facing the right direction and that they are pushed up as far as they will go before the skrew is tightened. (Are you using the right needles for the machine?)
Make sure that you are threading in the proper order and that every thread guide is threaded. Each thread has an order when it should be threaded, ie upper looper first, lower looper second.... If that order is not followed, there's a very good chance your machine will never work properly. The lower looper thread should cross over the top of the upper looper before being pulled under the presser foot and toward the back of the machine.
Second, be sure to RAISE the presser foot when threading so that the tension disks are released to seat the thread. Give each thread an extra little tug when going through the tension disk to make sure it is seated all the way.
Check that the tensions are set at the midway point between high & low numbers as an initial setting. They can be tweaked later to get the optimum tension.
Test your machine.
If it is still not forming a chain, it could be that the machine is out of time and needs to be professionally adjusted.
Apr 21, 2016 | Brother Sewing Machines
How do I get my Serger to sew properly?
I'm afraid you've threaded your serger incorrectly. I've done it myself more than once, so I try to make sure that I tie new thread to old and pull it through the machine rather than try to re-thread it. That avoids the problem for the future, but doesn't help you now.
Here's what you can do right now to work out the problem:
1. Get out your owner's manual and check the thread path(s) for each thread. Be sure you've got them right, especially the loopers (usually the two threads on the right-hand as you look at the machine).
2. If you don't find any obvious errors, change the sequence of the looper threads - that is, which one is threaded first. I know it doesn't sound like this will help, but it fixed mine.
3. Be sure that none of the threads are caught under the feed dogs, they should pull fairly freely toward the back of the machine.
4. Start sewing without fabric in the machine. I know this is wrong for a standard sewing machine, but you should get a 'chain' with a serger. If it's not 'chaining,' go back and try these steps again.
5. If that doesn't fix the problem, or if it chains and still won't stitch, change your needles. They should be changed now and then anyway.
6. Be sure to lubricate your machine often according to the owner's manual. Most sewing machines need more oil than they get.
Apr 08, 2015 | Sewing Machines
Babylock 5360e
try new needles
make sure to use ever thread guide
also check the tension
if none of these suggestion help then it may be time to have the machine serviced
Jan 19, 2014 | Sewing Machines
I have a elna 686 serger an it sounds perfect and acts like its sewing but there is no thread staying on the material.... I have tryed to rethread it several times and it does not help at all. What could...
There is several things to check:
Is the needle thread actually going through the needle eye?
Is it chaining off without fabric under the foot? If not, then you need to revisit your threading up, there is a specific sequence that you need to thread the loopers then needles, then pull the threads under the foot, lower pressure foot and press the foot control to make a few stitches, a chain of thread should form.
If this is not happening and you have threaded it up in the right sequence, then check both needles are fitted correctly, fully up into the housing and flat shank to the back. On most sergers the two needles sit at different heights in order to form the stitches. If you haven't done it for a while, change the needles.
If you still can't get a chain of stitching then it is possible that the timing between the loopers and needles has gone out and it will need to be serviced by a technician to get this back right.
Jul 18, 2011 | Elna Sewing Machines
On a babylock elegante the bobbin thread shows,
Jul 05, 2009 | Baby Lock Ellure
Apr 28, 2009 | Baby Lock Sewing Machines
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
