Question about Dryers
It has just made a huge noise like ball barings rolling around, what could it be?
  • Dryers Master
  • 5,323 Answers
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Posted on Apr 15, 2015
Dyson animal ball
Hi Max, I had a similar problem with mine a couple of years ago. I had just cleaned all of my filters on my Dyson, One of them being the one in the ball. Was almost impossible to roll across the floor, I messed with it for a couple of days, no solution. Called Dyson, the technician I talked to thought it might be the entire head causing problems, they sent a new head it was under warranty so no cost to me. Problem still existed. I took the ball apart and looked closely at it and it seems I had screwed it back together wrong after the filter cleaning. Long story short, check to see if the ball is put together correctly. Hope this solves your problem
Mar 25, 2017 | Vacuums
My dryer sounds like there are metal balls rolling around inside when clothes are drying
Sounds like the rollers are worn out. If they are fine then see if the dryer has glides on the drum.
Apr 23, 2014 | GE Profile Wizard DPSE592EAWW Electric...
Noise from mde4000ayw
What kind of noise? If it is bumping then check to see if the load is balanced in the drum and not gathered in a ball and rolling around. If it is squeeking, that's a belt problem...etc.
Jan 22, 2013 | Dryers
MY CROSLEY CDE8000 DRY SOUNDS LIKE IT HAS A BALL ROLLING AROUND IN IT
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 01, 2011 | Crosley Dryers
It sounds like a bowling ball rolling around inside the fridge.
Sounds like maybe one of the mounts for the compressor might be bad. The compressor is around the size of a bowling ball and does need the vibration dampened to stop noises like that.
Jul 03, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
When my washing machine is half way through a wash it sounds like there's a ball rolling around in it what could be causing this noise.
Something worked its way inbetween the tub and basket.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 24, 2009 | Kenmore 24032\24036 Top Load Washer
Blackberry rolling ball will not roll down
Cleaning the track ball on blackberry phones. Remove the metal ring then the ball mechanism remember how you removed it because it needs to go in the same way. You can also try removing the battery from phone taking a qtip with alcohol the higher the percentage of alcohol the better. and wiping and rolling the ball around even without removing it from the phone. this usually helps unless the ball is extremely dirty. Below are step by step ins for removing the ball. just follow the link
Removing blackberry tracball (non BOLD)
Dec 28, 2008 | RIM BlackBerry Pearl 8100
Agitator is making noise
bearings in the transmission are going out. they are fairly cheap if you can change them yourself.
Mar 29, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Open Questions:
Dryers Logo
79 people viewed this question
Top Dryers Experts
