Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
Need to clear In Use/Memory light on Canon MX340 printer
When I try to print, I get Support Code 300 and it says printer won't respond. The In use/memory light is on and won't go off. How to clear that?
    Master:
    Sergeant:
  • 226 Answers
Step 1 Press the "Menu" button on the MX340 until "Device Settings" appears on the LCD display.
2.
Press the left or right arrow keys to select "Reset Settings," and then press "OK" to load the Reset Settings menu.
3.
Press the left or right arrow keys to select "All data," and then press "OK" to reset data on the MX340 to factory default settings.
Posted on Apr 17, 2015
Testimonial: "Thank you but I had tried that and it didn't work. I did try again and it still doesn't work. Light stays on???"
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
How do i print from a canon mx340
what menu settings do I need for canon Pixma 340 to print
Apr 02, 2013 | Canon PIXMA MX340 Wireless Office...
My Canon Pixma MX340 printer keeps telling me that there is a document in the ADF and won't print. There is no paper anywhere and none has been stuck in the ADF but the message remains. I have tried...
Solution: Setting the MX340 back to default settings
Instructions to change the machine back to its default settings.
  1. Make sure that the machine is turned on.
  2. Press the Menu button repeatedly until Device settings appears.
  3. Use the l_mark_s.gifr_mark_s.gif button to select Reset setting , then press the OK button.
  4. Use the l_mark_s.gifr_mark_s.gif button to select one of the following, then press the OK button.
    Telephone no. data: Reverts the telephone number settings to default. Setting data: Reverts the machine settings other than the telephone number settings, such as the page size, media type, and other settings, to default. All data: Reverts both the machine and telephone number settings to default.
  5. Use the l_mark_s.gifr_mark_s.gif button to select Yes on the confirmation screen, then press the OK button.
Jul 10, 2011 | Canon PIXMA MX340 Wireless Office...
Canon MX340 I just replaced the ink (black and color). Black now prints in grey. What to do?
if you put a refill cartridge the printer are printing in grey.Try to put original cartridge canon.
Mar 09, 2011 | Canon PIXMA MX340 Wireless Office...
I can't print anything on printer, and when I try, it says the printer is not responding. In Printers and Faxes, it says it is ready.
helaineliew,
Sure sounds like you have another printer as the default. Click on start. Then click on control panel. Click on printers and other stuff. See which printer is set as the default. If the Canon Pixma mx340 isn't change it. This should solve your problem.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 13, 2011 | Canon PIXMA MX340 Wireless Office...
My Canon MX340 is all set up wirelessly and has the blue light on. But when I try to print something from Word is shows that the printer is not responding. I know it prints because I used it to copy...
You MUST put in the password of the router in or it will never connect. Pressing a number key several times quickly should change the number to letters.
May 16, 2017 | Canon PIXMA MX340 Wireless Office...
I have a canon pima mx340 printer/fax machine. How do you get a stored fx to print out
Printing a Memory List or Specified Document in Memory
1. Load paper.
2. Press the FAX button, then press the Menu button.
The Fax settings screen is displayed.
3. Use the button to select Memory reference, then press the OK button.
4. Print a specified document or memory list.
· To print a memory list:
Use the button to select Print memory list, then press the OK button.
The memory list is printed.
· To print a specified document:
1. Use the button to select Print specified doc., then press the OK button.
2. Use the Numeric buttons, or the button to select the transaction number (TX/RX no.) of the document you want to print, then press the OK button.
3. Use the button to select Yes, then press the OK button.
If you select Yes, only the first page of the document will be printed. If you select No, all the pages of the document stored in memory will be printed.
To print other documents, repeat the procedure from steps 2 to 3.
Nov 08, 2010 | Canon PIXMA MX340 Wireless Office...
My Canon MX340 printer says there is a paper jam .... there is no paper jam. I've opened the cover, the scan cover and checked in the back. There is no paper jam. i've tried resetting the printer by...
I had the same problem...after trying everything suggested on the forum. I had enough and decided to disassemble the printer. I removed the CAD and disconnected the wires and it solved the problem. No more paper jam error code on the screen. This probably includes that the CAD won't work anymore but I never used this anyway. So now I can print and scan like I used to.
Nov 06, 2010 | Canon PIXMA MX340 Wireless Office...
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
524 people viewed this question
old marine
old marine
