Question about Braun 350cc Series 3 System Shaver with Clean and Charge Base
How can I fix a base that is charging the shaver, but not cleaning it?
So when I push down the button at the top of the clean and renew base to connect the shaver, it should automatically start cleaning the shaver, but it does not. The green light on the shaver is blinking, so I can see that it is charging. The blue light on the base, that helps you to see how full your cleaning solution is, is blinking (when the shaver is not connected it remains on, but does not blink) and nothing else is happening. What's going on, and how can I fix it?
  • 3 Answers
SOURCE: charging stand
I just had the same problem, where the top of the charger would not stay down. I tried a spring clamp to keep it in place, and that works like a charm! Try it!
Posted on Sep 14, 2008
delgriffith
  • 97 Answers
SOURCE: Shaver will not charge or clean in the base
All you have to do is take the base apart. Turn it upside down, and there are two plastic clips on the rear portion of the base. Press them in with a key or screwdriver and wiggle the base a bit to remove the inner portion from the outer shell. Make sure you unplug the unit and remove the cleaning cartridge before doing this. Once it is apart, place a small wedge underneath the portion of the electric contact that sticks out to touch the shaver, and press the back of that portion out so that it slightly bends the contact strip and makes it stick out a little further. Then remove the wedge and put the base back together. It will work again, as the contacts can now protrude to touch the shaver and run the cleaning and charging cycle.
Posted on May 09, 2009
SOURCE: Cleaning base
you need to replace the top of the cleaning unit, really hard to separate. Available online
Posted on Aug 24, 2009
Cytherian
  • 124 Answers
SOURCE: Clean and Renew stand for braun 8595 does not seem
The circuit board on the shaver may have become faulty. One thing you can try is to fully charge the shaver first, directly connected to the outlet, and then try using the cleaning base. Also, be sure that the fluid level is sufficient. Lastly, you may be able to buy a used but working condition cleaning station off of eBay. New replacements are a bit costly.
Posted on Nov 07, 2010
  • 67 Answers
SOURCE: Braun 8995 clean and charge stand
it sounds like it may be dead, i do know of this great site that sells Braun stuff check it out maybe it can help. http://stores.ilikenew.com/-strse-Braun/Categories.bok
Posted on Mar 17, 2011
The top will not stay down for charging
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at shaveroutlet.com. See links below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sep 22, 2011 | Braun Syncro 7526 Electric Shaver
Can't get the 7526 cleaning arm to stay down on the shaver for charging, cleaning, etc. Is there a sequence e.g. hold the arm down then select a cycle, or select then push down? What is the blue button...
The locking mechanism in the arm is broken. This is a common problem with your model. To repair it you will need to purchase a replacement part. You will find the part at shaveroutlet.com. See link below
If repairing your existing clean and charge machine is not an option, you will find the entire machine available at the link below
May 08, 2011 | Braun Syncro 7526 Electric Shaver
I cannot click the top on when i try to charge it ....
The latch on the 'arm' of the clean and charging base is broken. You can either change out the top portion of the clean/charge base or replace the whole thing if you don't thisnk you can do the repair.
Both itemsare available at shaveroutlet.com. See links below. Basic instructions for installing the top part are included on the item page
Sep 26, 2010 | Braun Syncro 7570 Electric Shaver
Braun 8595 clean and renew will not charge or clean my razor, in fact it just ignores my razor
it sounds like your clean and renew base will need to be replaced. you will find a replacement at shaveroutlet.com
Dec 17, 2009 | Braun Activator 8595 Electric Shaver
Use your Warranty. Or you could simply buy another one and return the Lemon one with the reciept for the new one.
Aug 17, 2008 | Braun Syncro 7526 Electric Shaver
Charging stand
Aug 19, 2007 | Braun Syncro 7680 Electric Shaver
Braun 350cc Series 3 System Shaver with Clean and Charge Base Logo
311 people viewed this question
Top Braun Electronics - Others Experts
ray gallant
paul
Tom Chichester
Are you a Braun Electronics - Other Expert? Answer questions, earn points and help others
