Question about Refrigerators
How to transfer or forward a call - Refrigerators
For a GE ProSeries telephone Model 2-9980A S/No 00098864 corded business phone - 1 line with speaker phone. What are the directions to forward the phone to another number? And, also, how to cancel the...
Go to settings on your phone, click on the phone option, it will display different option, select call forwarding or call divert, enter the number you forwarding the call to and press ok, you are done. follow the same procedure, when you get to call forwarding, you can select to cancel as you can no longer add a number.
Take care.
Oct 14, 2010 | Cell Phones
How do i transfer calls
by transfer calls, do you mean call forwarding?
On most phones, a *72 then the number you want to forward to (xxx) xxx-xxxx. then talk (or send)
To unforward, usually *720. (then talk or send)
Additional cost per minute usually apply to forwarded calls.
Unless that is not what you meant.
Good luck. Don't forget to vote.
Oct 08, 2010 | Cell Phones
Phone is transferring to another phone extension, how do you take the transfer off?!
Hi Somehow you have set 'Call Forward'
you need to cancel it...
Leave the Handset in it's cradle then press Feature # 4
Display will say 'Forward Cancelled'.
Aug 09, 2010 | NorStar Meridian M8009 Phone (NT2N24)
Transferring call to my voicemail
DK system call forwarding in icm #604 for forward busy and no answer
Jun 19, 2009 | Toshiba DKT-2010 Corded Phone
Transfer my landline number back after traveling.
did u delete the number u forward from your forward menu?
Feb 27, 2009 | Motorola Mobility TracFone® V170 Cellular...
How to configure call forwarding on RCA RCA Phone model 25425RE1-
CALL FORWARDING HAS TO BE DONE THRU THE PHONE COMPANY IF YOU HAVE CALL FORWARDING - AND I DO THIS IS WHAT I DO - I HAVE AT&T IN MEMPHIS TN PICK UP HAND SET AND HIT *72- YOU WILL GET A BEEP- DIAL THE PHONE # YOU WANT TO FORWARD THE PHONE TO - SOMEONE MUST BE AT THAT PHONE NUMBER TO ANSWER IT! ONCE THE LINE IS ANSWERED- THEY HANG UP AND THEN YOU HANG UP AND PHONE SHOULD BE TRANSFERED- I ALWAYS TEST IT TO UN- TRANSFER IT PICK UP PHONE AND HIT 73# AND IT WILL BEEP 2 TIMES- NOW PHONE IS NOT TRANSFERED ANY MORE
Jan 16, 2009 | RCA 25425RE1 Phone
My transfer case goes into gear but doesn't turn the wheels.
The lights can come on wihtout the transfer case really working..the lights are actvated by a simple switch and only indicate the switch has been depressed.
It's sounds as if you have a problem with the lickage, or maybe damage inside the transfer case itslef
Dec 20, 2008 | 2003 Ford F150 Regular Cab
Transfer lever positions on 85 hilux 4x4
h2 should be left and all way forward h4 will be straight back from h2 and l4 willbe right and forward of h4
Sep 17, 2008 | 1985 Toyota 4Runner
Can I forward an incoming call to an outside line?
External transfer to Mobile 1. Transfer 2. press 1 and external # 3. Wait for ringing 4. press feature then transfer 5. hang up
Jun 11, 2008 | NEC Electra Elite 32D-1 Corded Phone
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
