Question about Dell C1765nfw
Error message 077-900 help there is no paper visibly that I can see
  • Robert A. Watson
    Robert A. Watson Apr 14, 2015
    The plastic cover should come off. Make sure the plug is unplugged from the outlet and with just your fingers try to spin the rubberized rollers that you see. Stop and use a flashlight often and look for paper pieces. If you are convinced there is no paper inside. Put it back together and download drivers for your printer from the mfr's web site and install any updated software that is available, follow the on-line instructions exactly. When you finish the install, turn your PC off and reboot it and see if your PC recognizes the printer as before. Try a test page. If you need help just ask me.
  • 774 Answers
There is probably a small bit torn off somewhere. Unplug the machine, take the screws off and open up the lower portion from underneath to check. Use a flashlight. Always "fan" a paper ream before placing a pad of paper into the hopper drawer. Using thicker paper helps prevent jambs. Recycled paper, although good for the environment, is not good for printers or copy machines, it contains 20% virgin wood fibre and 80% paper mache'. Recycled paper tears easy as it doesn't have enough fibre to handle the forces of the rubberized spindles along the paper path. Machines that bend the paper twice in the paper path such as HP's are worse at jamming than are Epsons, for example.
Posted on Apr 14, 2015
Testimonial: "Thank you so much for responding. I have unscrewed the 6 screws,but the lower will not open up; can you be more specific as to what to pull on to look for small piece of paper; trying not to damage anything.' Thanks Queen"
How do I override a paper jam error message?
Dear
I am a bit of confused about paper jam but you are able to print but facing difficulties in scanning. I think the document jam is there. Pl. check the ADF (automatic document feeder) a small piece of paper or any foreign mater may obstruct or jammed at the sensor. clearing this may help you.
Thanks.
Feb 25, 2015 | Brother DCP 8085DN
Paper jam
Check the inside of the machine, and try unplugging the power cord for ten minutes first.
Sep 11, 2008 | Canon MX300 Office All-In-One Printer
Error message
If looking into the paper feed there is no visible jamb, check the outside of the printer elsewhere. There is usually an access panel that comes off to manually remove any caught paper from behind where your paper loads to copy.
Sep 19, 2013 | Oki Electric Industry B431dn Printer
I have the following error message:
SOMETHING MOST LIKELY FELL DOWN IN BACK PAPER PATH OR TORN PAPER THAT HAS PAPER SENSOR STUCK. HARD TO SEE SOMETIMES. MIGHT WHAT TO TURN MACH UPSIDE DOWN AND SHAKE BE VERY CAREFULL
Apr 14, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error message
You may check wether one of the sensors from the paper path is not blocked or broken! if everything looks fine and there is no paper inside it might be a more seroius problem! no reset button for this kind of proiblem!
Nov 16, 2008 | Canon PC-860 Black and White Copier
Error Messages
The false Jam at MP E is a common error caused a manufacturing error/problem. You can download a solution to this problem HERE.
The K dev unit error can only be removed by replacing the dev and completing the service mode adjustments. A service manual will help you with this issue. Get one HERE.
Jun 06, 2008 | Epson Aculaser C1100 Printer
Error message 50 and 30
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Apr 04, 2008 | Brother MFC-845CW multi-function...
see here: http://www.fixya.com/support/t211210-brother_mfc845cw In case this is a new printer give it back to the dealer. Its in guarantee.
Oct 08, 2007 | Brother Multi-Function Center MFC-240C...
Dell C1765nfw Logo
184 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
