Question about Husqvarna Garden
This husqvarna has 4 wires for the seat switch, which one to bridge to bypass the switch
  • Eugene Rounds Apr 14, 2015
    Hi Reynold Gayahpersad, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the model number? Not are all are jumpered to bypass.
  • Reynold Gayahpersad
    Reynold Gayahpersad Apr 14, 2015
    It's. YTH20k46
2 Suggested Answers
  • 6468 Answers
SOURCE: My Husqvarna YTH2148 starts but shuts off when I let off of the brake/clutch pedal. I bypassed the seat swith and replaced the interlock switch. Any ideas?
replace the switch on the brake/clutch it is a dual switch so it can crank and still be bad
Posted on Sep 05, 2012
I have a problem with my husqvarna lth1542 when I start the motor up it start fine but when I take my foot of the brake on left side it conked out we don’t have the Deck on and we bypass the swich on the...
Hi Christopher, I understand you have bypassed the seat switch, but did you just leave it disconnected?. If so, you need to insert tooth picks or matches into the connector from the seat end, look into the connection and you will see a little clip, you need to insert the matches/tooth picks to separate all 4 of the clips.
Hope this helps.
Kind regards
David
Nov 13, 2017 | Husqvarna Garden
How do I bypass the seat safety switch on a 5424 Husqvarna zero turn mower?
ether unplug it if wont start then jump the wire pigtail with a wire you can bypass both switch like this
Sep 16, 2014 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Husqvarna yth1848xp wont turn over
Are you getting 12 volts to the starter? It sounds like one of the safety switches (seat switch) may be killing the circuit. The seat switch cannot simply be jumped. And check the 20 amp fuse.
May 30, 2014 | Husqvarna Garden
I need to disable seat switch on my husqvarna
Hi Dennis...
The easy way is to unplg the wires from the switch,remove the plastic ends of the wires and wire the two wires together, then tape with electrical tape and that will work for bypassing the seat switch
Bud
Apr 22, 2013 | Garden
How do I bypass my seat safety switch on my Husqvarna GTH2254 ride-on mower?
It's not a good idea. But if you must, it's just a switch. If it has two wires, cut them from the switch and connect them together with a wire nut. If it has only one wire, then cut it from the switch, put a spade terminal on it, and connect it to the frame of the tractor.
Jun 29, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
My husqvarna lth 1342 tractor stalls when the clutch is released even when its throttled up
Hello james_3228:
>>If this Unit is Stalling like Someone has Turned Off the Ign Switch, then the Seat Safety Switch is Bad or has a Bad Connection.
>>The Following is the Instruction File for Checking the Seat Safety Switch.
>>***PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.***
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed. **Make Sure the Switch has a Good Connection. Now; On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch Jumper from Same Color Wire to Same Color Wire). The Seat Safety is Showing No One is Seating in the Seat when the Clutch or Blades are Engaged.**
>>If the Unit is Jerking and then Stalling, then Check the Ground Drive Belt and Pulleys.
>>The Belt May be Caught between a Pulley and the Frame or Belt Guard or a Pulley May be Frozen and Causing the Engine to Stall.
You can View the Husqvarna Model List at this Site Addy, http://www.partstree.com/parts/ and Click on the Husqvarna Logo. Now Enter the Model Numbers in the Search Box on the Left and Click Go. Now Select the Model of the Equipment you Wish to View.
>>For Better Assistance, Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 16, 2009 | Husqvarna Garden
I RAN OUT OF GAS WITH A HUSQAVARNA RIDING MOWER AND PUSHED IT WITHOUT RELEASING THE BRAKE IN THE BACK OF THE MOWER, REFILLED WITH GAS AND NOW EVERTIME I RELEASE THE CLUTCH THE ENGINE DIES, ANY SUGGESTIONS?
Hello:
From your Description it Sounds like the Seat Safety Swithc has a Bad Connection or Requires Replacing. The Safety System is Registering No Pressure on the Seat when the Clutch is being Engaged.
Good Luck
Respectfully
jbridger (John)
May 15, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
74 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
