Question about Bosch Ovens
Hi there i replaced the oven light in my bosch electric oven HBN 131 1.0 B today and when i switched it on there was a flash of light and it now wont switch on.
I checked the wattage on the bulb and it wasnt above the max. I also changed the 13amp fuse and checked the main fuse box. I even put a lower wattage bulb in but it still wont come on. Have you any ideas what i could try next please?
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
SOURCE: Bosch HBN 455 Oven Cooling-Fan Issue
Our HBN655 had similar issues- the upper cooling fan would cycle on and off on a relatively quick duty cycle until the whole mess cooled off enough and it shut off.
My workaround is to turn the temperature dial off but leave the oven function dial on to BAKE. This seems to force the fan to stay on; then we shut it off a while later and avoid the annoying fan cycling.
(note- 2 years ago, our fan became intermittent, varying speed, etc... for about 2 months before it quit entirely. When that happened, the oven started to heat then the thermal cutout kicked in and the oven shut down entirely. We ended up replacing the fan and that fixed the bug... except now it's starting to act up again...)
(also note- the racks on this beast have a faulty design. if you have a heavy casserole and slide the rack out all the way, it tends push the sidewalls apart and the rack drops. I spoke with Bosch about this and they sent me new racks, no charge... so they know there's a problem. But the new racks don't fix the bug; they just make it harder to reproduce. I have actually had one rack fall with 2 piping hot casseroles on it. Fortunately no one was hurt.)
Posted on Nov 04, 2007
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
SOURCE: Gaggenau EB294/295 Electric Double Oven
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
Posted on Dec 19, 2007
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    Why don't oven lights work?
    The switch on the oven for the lights may be bad or the panel fuse has blown
    Feb 20, 2016 | Bosch HBN 755 Stainless Steel Electric...
    Instructio manual for a Bosch oven HBN 574850
    http://www.bosch-home.co.uk/customer-service/download-product-manuals.html click on link, open new window as indicated and type in the ENr number without spaces, you can then download the manual (IU is user manual, II is installation instructions)All the best
    Aug 29, 2011 | Bosch HBN 742 / HBN746 Electric Single...
    Oven does not heat to selected temperature.
    If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
    Oven Problems Electric Oven is Heating Slowly or Poorly
    heatman101
    Dec 13, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
    My Bosch double oven timer is not working. No clock, notimer, but the oven is working fine.
    Sure this is the failure off the unit but make sure that the step down transformer for the power to the unit is faulty or burnt. If so replace the transformer. If power goes tto unit without display then the processor can be faulty . Change the clock timer. unit if you need the timings.
    Sep 19, 2010 | Bosch HBN 452 / HBN 456 Electric Double...
    MAIN OVEN DOESNT WORK
    Hi
    Pretty certain nofuse. Suspect switch. Guess would be as element blew it took out contacts on oven switch
    Feb 20, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
    Replacing interior oven light
    Here is the manual for your unit:
    Bosch HBN3550/01
    The instructions are on page 31.
    Hope this helps and please remember to rate this!
    Dec 06, 2008 | Bosch HBN 3550 Electric Single Oven
    Bosch hbn s gb
    oven element would need model and ENR No. to supply
    Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
    Bosch oven HBT346 - how do I reset the clock?
    Hi after a power cut my Bosch cooker clock is flashing but I cannot reset it as have no instructions - any ideas? Thx
    Apr 15, 2008 | Bosch HBN 442 / HBN446 Electric Single...
    Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
    NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
    Jan 20, 2008 | Bosch HBN 452 / HBN 456 Electric Double...
    Ovens Logo
    82 people viewed this question
    Top Bosch Ovens Experts
    ashburton
    reliableservice
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
