Model # rcba-37656 what tonage is this
Evaporator coil it is a Rheem
5 Suggested Answers
  • 340 Answers
SOURCE: How can I validate the tonage of my Ruud air
you must have very old equipment are you sure of the model and serial number it might be a 69 if the serial number is the m0696. Tom double check those numbers.
Posted on Jun 28, 2009
james3751
  • 614 Answers
SOURCE: How many ton is this air handler?
3 ton Rus
Posted on Jul 05, 2009
SOURCE: Filter location? Rheem Classic Super Quiet 80, RCBA 2457GG14XI
Open the two side panels. The filter is at the bottom held down with a wire spring. Release the spring and the filter can be removed.
Posted on Jul 17, 2010
diodeic
  • 1622 Answers
SOURCE: 726@verizon.netI have a Rheem Model
a forced-air distribution system is just what the name implies. Air is forced from the furnace through ducts to registers in various rooms. Besides warming the air, the blower system that distributes the warmed air also returns the cold air to the furnace so it can be rewarmed and distributed to the rooms again.
A forced-air distribution system uses a blower to distribute warmed air and to
return cold air to the furnace so it can be rewarmed and distributed again.
A forced-air system is also efficient for distributing cool air from a central air conditioner with the same ducts, registers, and blower. There is little that can go wrong with a forced-air system. The big problems typically include noise and blockage of airflow, usually caused by dirt or by furniture or draperies blocking the registers. Forced-air systems should be cleaned and maintained regularly.
Floor registers are slip-fit into ducts or are held by retaining screws on the frame of the register. Wall and ceiling registers are also held in place by retaining screws on the frame of the register. Duct joints are usually slip-fit and held with sheet-metal screws or duct tape. The ducts are supported by wire or metal strap hangers nailed or screwed to wooden framing members such as studs and rafters. All of these parts are easy to disassemble. Lay them out in order as you work so you'll be able to reassemble them properly.
A problem can arise with this type of system in which the temperature of different rooms varies widely.
Forced-air systems often go out of balance, causing some of the rooms in a home to be too hot or too cold. The furnace is usually not to blame; the problem is caused by ducts and registers that are not properly set. You should balance the system while the furnace is turned on.
To balance a forced-air system, open all the ducts and registers in the system. There may be dampers in various ducts that need to be turned to open the ducts. The damper is open when it's turned parallel with the top and bottom of the ducting.
Next, gather six or seven thermometers and get them all to have about the same temperature reading. You can do this by laying out the thermometers together for about 30 minutes and then noting any discrepancies. Tape the thermometers on the walls of each room so each thermometer is about 36 inches up from the floor, away from the hot air register or cold air return. Wait one hour, then take a thermometer reading in each room when the heat is on. If one room shows a higher temperature than an adjoining room, close the damper or register slightly in the hotter room.
Follow this procedure for each room in your home, opening and closing dampers and registers until the same temperature is maintained in each room or the temperature balance you want is reached. The thermostat to the furnace should be kept at the same reading while you balance the system.
Posted on Apr 19, 2011
How many pounds of reon do you put In 2011 Rheem Classic packaged ac unit
look on the mane plate on outside unit... has voltage ratings model serial type of freon factory charge etc.
Jul 21, 2014 | Rheem Prestige 14 Series 4.0 ton 14.5 SEER...
I have a rheem classic 90 plus rcba 3765gg17 in my condo. What is the filter size?
Mike I would contact Rheem directly or just take it out and go to a store and match it up
You could do a search but think the other two ways will be a lot faster
Oct 19, 2013 | Heating & Cooling
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
May 23, 2010 | Heating & Cooling
I have a Rheem System Model number rcba-3765GG17 Serial number M1201. How would you turn the heat on?
At the low voltage terminal where thermostat wires atttach, and go to stat and ac unit,
there is R red, W white, Y yellow, G green, C common
red is hot white is heat, yellow is cool , green is fan
jumper red to white for heat
Nov 28, 2009 | Heating & Cooling
How can I validate the tonage of my Ruud air conditioner? The model number is M0696. The serical number is RCBA-3/65AS17
Jun 28, 2009 | Ruud Matching Split Air Conditioner
Rheem LX2000 intermittent start problem
check all wires are tight and good on both ends if you are not a sparky then turn it off first at the power box
Mar 01, 2009 | Heating & Cooling
Heating & Cooling Logo
96 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
