Question about Garden
Keeps tripping ground fault outlet - Garden
  • Garden Master
  • 2,533 Answers
You likely have a pump where some water is leaking into the pump just enough to trip the ground fault. Could even be a bearing that is wearing out.Check all your wires as well for cracked or split outside insulation or wire coating as just a little split in the wires can do this as well. Probably needs a new pump. Just a thought is there any way moisture can get into your ground fault receptacle. I had to replace mine as over the years my rubber seals cracked open so when it rained hard moisture got inside. any moisture will set it off.
Posted on Apr 17, 2015
Simoniz S2000 XE02 internal cct breaker keeps tripping after 30secs tried to get a parts break down but that info is really ****** and nothing on line anywhere. Any idea what causes the cct breaker to...
First be very careful because the unit is protected by a ground fault internal circuit interrupter and may trip if there is a short circuit to ground. Even a very small short circuit will trip the circuit breaker.
Something else: If you are plugging it into an already existing ground fault outlet then that may also cause one of the breakers to trip.
Like I first mentioned, if you don't know what your doing be very careful. Electricity and water are not friends, especially if the circuit breaker is tripping.
Good luck,
Marty
Jun 26, 2014 | Coleman Powermate DuraBuilt 1400 PSI...
Gfci trips heater not turned on
GFI is Ground Fault Interrupter (or GFCI - Ground Fault Circuit Interrupter) It is doing its job, telling you that there is a short in the unit or wiring. Have a certified electrician check the wiring and unit.
May 17, 2014 | Pentiar Pentair MiniMax 100 BTU Natural...
Do I need a ground fault plug if I have a circuit breaker at the box
Hi Dale - I'm an electrician and can answer this question for you.
If the circuit is protected by breaker in the electrical panel is a ground fault type already, you should not install GFCI plugs on this circuit. If you do install one of the circuit, you may trip the GFCI at the outlet, the electric panel or both. You'll be spending more time trying to find the device that tripped to reset it if you add a GFCI outlet to a circuit with this protection already.
Apr 22, 2012 | Electrical Supplies
Over range microwave model jvm1650wb008 fan works nothing else does
Check to see if circuit breaker is tripped in the electrical panel, or if it is connected to a ground fault outlet, it may have tripped. Sometimes there is one ground fault outlet serving others in series in the kitchen.
Nov 25, 2011 | GE Microwave Ovens
After moving to a new home, the freezer keeps tripping the breaker every few days
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Sep 29, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Moved a/c to another window and wont work
Check your outlet wiring. The polarized outlet has a narrow slot and a wide slot, and a ground hole, of course. Anyways, the narrow slot should be hot. If you put a voltage tester lead into the narrow slot, and the other lead into the grounding hole, you should read line voltage if the grounding hole is grounded properly. If you test the wide slot to ground and get line voltage, you have reversed polarity and must swap (reverse) the lead wires in the outlet to correct the problem.
Jul 30, 2009 | Kenmore 6000 Wall/Window Air Conditioner
Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
Feb 26, 2009 | Cutler Hammer 1 Pole 15 Amp Ground Fault
My ULine icemaker just started triping the GFCI plug.
Ground fault should not be used when you have a compressor plugged to it. The start amps can trip a ground fault. You can try to plug the unit on a regular outlet and if it doesnt trip the breaker then unit should be good. You can try to replace the ground fault if you need it (but make sure you have a higher amperage on the new one.)
Dec 23, 2008 | U-Line Icemaker
Circut Breaker trips
  • i have no experience with RV units but if it were in a house i would suspect a bad breaker or a problem with the outlet itself. breakers  only trip when the wiring is gets hot.
  • unless it is a ground fault breaker (usually on the outlet) then this would trip if the flow of electricity is grounded. ground fault breakers do go bad often.
  • i think if the refrigerator itself had a problem then it would be consistent (as far as it is pulling amps anyway). not work fine sometimes and not others.
Jul 08, 2008 | Dometic NDR 1292 Refrigerator
Garden Logo
272 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
