Question about Brother MFC-8480DN MFC8480DN Print/Copy/Scan/Fax ENET Duplex Laser Brother
My printer makes a "squealing" noise when it prints a lot at once. When I print no more than 5 pages its fine, quite, but if I print more than that its starts making the squealing noise.
Soulvisitor
  • 1113 Answers
SOURCE: Black pages when making a copy or printing something
Have you tried both drum and toner supplies? cause it sounds like a drum fault, if you have tried a new drum and toner, and it is doing it when printing internal reports, receiving fax's and copying then you have a tecnical issue to do with charge and this would likely render machine unecomical to repair (unless you can find a bad contact with drum on machine). If it receives faxs clearly but copys black then it is different issue (ie optics).
Posted on Oct 17, 2007
checkitright
  • 1362 Answers
SOURCE: prints extra blank page
here is the manual to set in the computer, check " advance options"
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=775422b88337921f373920693b8e48f9&q=brother+3800+manual
Posted on Dec 14, 2007
Logjam
  • 159 Answers
SOURCE: printing black shaded on complete page
Problem is usually a dirty charge corona wire. There is a cleaner on the drum unit, slide this across and back 2 or 3 times. If not, then the corona wire itself is missing or broken, change drum.
Posted on Feb 27, 2008
  • 1257 Answers
Shading May Print As Black Printing to Fax Printer
CAUSE:
loadTOCNode(1, 'cause')This problem is caused by the Intensity level for the fax printer being set to its default value. This default value does not take shading into consideration.
RESOLUTION :
loadTOCNode(1, 'resolution'); A workaround for this problem is to change the Intensity setting on the Printer Properties page for the fax printer on the client workstation. Select the Graphics tab of the Printer Properties setting, and change the value for Intensity to 125 or more until the shading is the desired tint.
Posted on Jun 18, 2008
dumb4ever
  • 3 Answers
SOURCE: Brother 5250DN printer noise
Check my solution here:
http://www.fixya.com/support/t641678-paper_tray_noise
Here's a solution for you with Brother HL 5250 D/DN/DNT
Change the paper setting tab in the tray to make sure you have a small gap between the top part of the paper and the bottom part.
so if this is the old settings : |paper| --> you want to make it: | paper| so you can have slide the paper back and forth.
DON'T adjust the setting to the next paper size because the roller wont catch the paper if it slide too far.
Good luck to all.
Posted on Oct 22, 2008
How to clean head HP 7260
HP Photosmart 7150 and 7260 printers
  1. Make sure plain paper is loaded into the In Tray.
  2. To perform the first level cartridge cleaning is a spit and wipe, press and hold the Power button while pressing the Cancel button twice, then release the Power button. The printer will generate a series of noises as it performs the cleaning.
  3. Print a test page from the computer.
  4. Once the cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 5.If the print quality is acceptable, disregard the subsequent steps.
  5. To perform a second level cartridge cleaning, press and hold the Power button while pressing the Cancel button twice. Release the Power button and press the Resume button. The printer will generate a series of noises as it performs the cleaning.
  6. Print a test page from the computer.
  7. Once the cartridge cleaning has completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 8.If the print quality is acceptable disregard the subsequent steps.
  8. To perform a super clean, press and hold the Power button while pressing the Cancel button twice. Press the Resume button twice then release the Power button. The printer will generate a series of noises.
  9. Print a test page from the computer.
  10. Once the super clean has the completed and the test page has printed, examine the test page. If the print is not clear and/or there are lines in the color bars, continue to Step 11. If the print quality is acceptable disregard the subsequent step.
  11. To perform a pen nozzle test, press and hold the Power button while pressing the Cancel button eight times. Press the Resume button four times then release the Power button. The printer will generate a series of noises then print a page displaying a test pattern. If there are gaps in the printouts the cartridge(s) may need to be replaced.
Jan 17, 2015 | HP PhotoSmart 7260 InkJet Printer
Nothing at all printing or copying, just blank pages
hi and welcome to fixya
Your printers ink Carthage is empty ! making noise of printing and blank pages is because of the empty cartage bring a new cartage and then printer will print the pages
Dec 07, 2012 | Epson Stylus Photo RX520/RX530
If I print a large quantity in one print, the first two or three pages wil print fine then the rest will mess up. The left hand side of the page will mis-print and it squeals every so often. I just...
the drive gear assy. that moves the opc belt are broken.
honestly is time to get a new machine instead of spending a lot of money trying to fix this Lemon,sorry.,
Sep 10, 2010 | Brother MFC-9420CN All-In-One Laser...
Printer squealing every time it prints? Help
This issues looking printer head problem. check the following Steps for cleaning printer head :
  1. Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
  2. Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
  3. Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
  4. Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
  5. Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
  6. Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
http://www.fixya.com/support/t6355639-hp_2640_half_right_side_page
Sep 09, 2010 | HP LaserJet 2840 Printer
HP Photosmart C6280 All-in-One making weird noises
this is hope, i had this problem once. what it was was a small piece of paper that was caught in the rollers. i know you said this, but check again, I am almost positive this is your problem
lastly, check the black cartridge, take it out make sure nothing is stuck to the ink dispensary for clear printing
hope this helps and good luck
Apr 29, 2010 | Office Equipment & Supplies
X5470 lexmark has paper jam now makes squealing noise when I use it!
Try this. Remove any paper jams, take out all sheets of paper and remove all cartridges from the printer. Close the cover. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer's ready, re-insert the cartridges. The printer will print an alignment page. Load just 5 sheets of paper only. Let it print the alignment page all the way through without cancelling it. If printer is not making the squealing noise, problem resolved. If it's still making the noise, the printer's mechanism somehow got affected by the paper jam now. If that's the case, any mechanical/hardware problem in the printer, it's better to ask assistance from Lexmark. If printer is damaged already, and it's still within warranty, they might send you one for replacement. Good luck!
Apr 07, 2010 | Lexmark X6170 All-In-One InkJet Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Hp 6200 makes machine gun sound before printing, when the print carriage goes all the way to the right is when i hear the machine gun sound, it still prints fine.
This is quite normal with this series of printers. Happens on my 6310. It "machine guns" only occassionally (once a month), and then the gunning noise slows down slowly, then the print starts. Might be shaking the head to clear ink rigorously or something.
Jun 11, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP 2100 makes squealing noises
It could be a roller, a drum, sometimes the auger in the cartridge can do it.
Should have a technician look at it to find specifically where it is comming from.
Jun 13, 2008 | HP LaserJet 2100 Printer
Brother MFC-8480DN MFC8480DN Print/Copy/Scan/Fax ENET Duplex Laser Brother Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
