Had power outage and now we don't have a message recording anymore. Tried to set new message, but whenever press intercom, says it's not valid. Can't find an answer anywhere in manual.
SOURCE: panasonic KX-TGA1018 DECT 6.0 cordless
see manual on website below
http://service.us.panasonic.com/OPERMANPDF/KXTG1032.PDF
SOURCE: Digital panasonic kx-t7633
The 7633 has a FWD/DND button. Is it blinking, lit solid or dark? It's designed to be pressed 3 times for FWD DND or OFF....It's programmed as follows, assuming that 500 is your voice mail access code:
From the intercom dial *7101. That sets DND. Dial 710x 500 # to set call forwarding where x-2 for all calls 3 for BUSY for for NO ANS 5 for BSY/NA. 7&8 are FOLOW ME commands and they have a different set of instructions ie Dial *7107 plus your extension to have calls come to the phone you're at and *7108 plus your extension to cancel it. I have never seen it used. *7100 cancels all forward and DND arrangements from your phone..
This is just hte command set for ALL CALLS. You can also set up forwarding for Outside Calls and Inside calls seperately and you can program buttons to do the forwarding.
Your Panasonic dealer has 2 manuals that you would find interesting, one is the TDA Operating Manual and the PTPM Manual. The operating manual has a complete set of programming instructions for the manager and users of TDA systems, the PTPM has a complete set of programming features that can be performed from a Panasonic 76XX display phone.
THe pdf's aren't huge and they can be sent to your email address if you provide one under the Ask Me button.
Carl
SOURCE: Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
SOURCE: KX-T7433 - message light does not work
Assuming that the 74xx phone is connected to a Panasonic TD system, the only code is dialing 701 on the intercom, or pressing the MESSAGE button and dialing the 3 digit extension. You can't set your own MW, so you need to do it from another phone to your extension to test it. It also has to be the hardware number ie 101-116 or 132 and not Phantom numbers.
Your 74xx phone could be connected to a TDA or the numbering plan may have been changed, but those are obscure situations.
Carl
SOURCE: Record a voice message on the oanasonic KX-T7630
the panasonic KX-t7630 doesnt have a answering machine and runs through voice mail.. if you have voice mail set up simple dial your number for voice mail (eg. 500) press 311, then record greeting at the end of tone. hope that helps
