Question about HP LC3760N 37 in. LCD HDTV
Tv powers on with pic and sound for 3 sec then off with green power light flashing.
After that the tv locks out. I have to hold the channel button and the input at the same time and plug it in. But does the same thing every time. No markings on any of the circuit boards to know what the voltages should be.
  • 2 more comments
  • Kennith
    Kennith Apr 14, 2015
    I have tried looking for a manual also, I am hoping someone has had the same issue for help.
  • Chris Neary
    Chris Neary Apr 15, 2015
    take a look at the supply board and see if the capacitors have popped. From doing some reading this is a common fault with this device (and probably every other PSU on the planet).
  • Kennith
    Kennith Apr 15, 2015
    The power supply looks ok no popped caps I ordered a power supply today and I will post if it fixes it or not.
  • Kennith
    Kennith Apr 21, 2015
    Replaced power supply board with a new one and still same issue. Im leaning on the main board, i can unplug inverter board and does the same green flashing light after hard reset.
    Master:
  • 369 Answers
That sounds like the safety shut down for the power supply board kicking in.
You could shotgun repair it by replacing the board but without a manual it's a bit like shooting in the dark and I can't find the repair manual out there, but here's and idea of the component modular board costs.
http://www.shopjimmy.com/hp
Posted on Apr 14, 2015
Testimonial: "Yea I can't find anything on this tv and not work putting any money into. I had someone tell me the lamps are bad but they all test and look normal."
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
How can i set up my direct tv remote to my Haier tv
How to scan for TV codes on your DIRECTV remote
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9-9-1, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
Feb 13, 2013 | Haier HL22XLE2 - HL22XLE2 22 LED-LCD TV -...
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Then enter 9911, the green light on remote should flash twice.
  • Sep 07, 2011 | Televison & Video
    Can set up th remote control for this tv with the direct tv cable remote
    Here's how to scan for TV codes on your DIRECTV remote
    1.Make sure your TV is turned on.
    2.Slide the mode switch at top of remote to "TV".
    3.Press and hold the MUTE button. This is located above the number 1 button.
    4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
    5.Then enter 991, the green light on remote should flash twice.
    5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
    6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
    *If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
    7.When the TV powers off, press and release the SELECT button.
    *Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
    Mar 05, 2011 | Curtis LCD2425A TV
    Need rca crk17sa users guide for codes for Magnavox TV
    Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
    http://www.directv.com/DTVAPP/content/remote_codes
    Here's how to program your DIRECTV remote control:
    1. Press MENU on remote.
    2. Select "Parental, Favs and Setup"
    3. Select "System Setup"
    4. Select "Remote"
    5. Select "Program Remote"
    While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
    How to program the white DIRECTV remote to your TV
    1. Look up the control codes for your DIRECTV remote control.
    2. Make sure your TV is turned on.
    3. Slide the mode switch at top of remote to "TV".
    4. Press and hold the MUTE button. This is located above the number 1 button.
    5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
    6. Enter the first TV code you have. The green light on remote should flash twice.
    7. Aim remote at TV and press PWR button once. The TV should power off.
    8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
    If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
    If remote control fails to program using all available codes, try scanning for the code.
    1. Make sure your TV is turned on.
    2. Slide the mode switch at top of remote to "TV".
    3. Press and hold the MUTE button. This is located above the number 1 button.
    4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
    5. Then enter 991, the green light on remote should flash twice.
    6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
    7. When the TV powers off, press and release the SELECT button.
    Mar 08, 2010 | Televison & Video
    Tv come on for 2-3 sec. then cuts off no pic. (power button/green light)
    does the green light keep flashing or does the light go out right away?
    Larry
    Jul 05, 2009 | Mitsubishi WD-73833 73" HDTV
    I have have a playstation 3 and when I hooked it up to my tv as I normally do there is no picture or sound. I then tried switching to my HDMI cable with the same results. Yes, I made sure I set my tv input...
    Try powering on you unit press and hold the power button and the eject button for 30 sec unti the power light begins to flash thats going to reset the setting of your ps3, and if that does not work i would rec> sending it out so sony if its still under warranty or exchanging it from where u bought it.
    Jan 09, 2009 | Sony Playstation 3 (PS3) Console
    HP LC3760N 37 in. LCD HDTV Logo
    83 people viewed this question
    Top HP Televison & Video Experts
    Tony
    Computer Links
    Are you a HP Televison and Video Expert? Answer questions, earn points and help others
