Question about AM Auto Parts 1997 to 1999 Cadillac Seville SLS Power Window Switch Front Driver
Power Steering Right turn ok Left turn hard Changed Power Steering Power Pump and PSP Switch
What is power steering pump switch?
If it is hard to steer, I don't think that switch is the problem? More likely the power steering pump or rack/pinion. Just my opinion.
Usually that switch is to help up the idle, so the vehicle doesn't stall when turning at idle.
Mar 04, 2015 | 1999 Mercury Villager
Po551 code
code po551 refers to power steering pressure(PSP) sensor/ switch--range /performance problem===causes --PS system--PSP sensor/switch
Have the power steering pressure checked as it may be a pump problem or just the sensor/switch.. Check the reservoir level as it may be lacking fluid.
Apr 22, 2014 | 2001 Plymouth Neon
Power steering hard to turn
The power steering system includes a P.S. pump which will whine when you turn a hard left or right while in park. There are also power steering hose that can leak. Then there is also a power steering gear box. Unless you have a rack and pinion steering system. Then that is changed as a unit.
Oct 03, 2013 | 2007 Pontiac G6
Changed power steering pump and it is hard to turn
Sounds like your steering gear box may be the culprit rather than the pump. What were the original symptoms?
Jun 03, 2012 | Cars & Trucks
2000 F150 Hard to steer, changed pump problem still there.
When ever you open up the lines to the power steering pump, there is a procedure you have to do to take the air out of the system, you have t raise your truck off the ground put it on jack stands, turn motor on and turn the wheels right and left and apply fluid to your pump as needed do this about 7 or 8 times, then put it back on the ground and if the air is out of the system, your power steering should return back to normal. you don't have to put it in gear when you raise it, so long as you can turn your steering freely to the right and left all the way. good luck!
Aug 21, 2011 | 2004 Ford F150
Power steering pump replaced, start to work ok, after 10 milles driving, steering wheel is hard, like pump is not working, under hood everything look ok.
YOU HAVE AIR IN THE POWER STEERING SYSTEM.YOU NEED TO BLEED POWER STEERING PUMP FIRST BEFORE DRIVING VECHICLE.CHECK POWER STEERING FLUID LEVEL ADD MORE POWER STEERING UNTIL REACH FULL COLD MARK..RAISE VECHICLE FRONT WHEELS OFF THE GROUND.START ENGINE LET IT IDLE WHILE TURNING STEERING WHEEL LEFT TO RIGHT NON STOP DONT LOCK OR STOP STEERING WHEEL KEEP TURNING IT SEVERAL TIMES CHECK POWER STEERING FLUID IF LOW ADD UNTIL YOU GET COLD MARK ON DIP STICK DONT OVER FILL POWER STEERING PUMP BLOW A SEAL.IF POWER STEERING FLUID LOOK TAN COLOR SYSTEM FULL OF AIR.TURN OFF IGNITION LET CAR SET FOR A WHILE CHECK FLUID LEVEL.IF STEERING WHEEL FEEL STIFF HARD TURNING DONT DRIVE CAR UNTIL YOU HAVE NORMAL STEERING.IF STILL HAVE AIR IN SYSTEM BLEED SYSTEM UNTIL AIR IS OUT.
Feb 25, 2011 | 2002 Chevrolet Avalanche
WHEN DRIVING AND MAKING TURN'S STEERING IS SOMETIME'S HARD WHEN MAKING LEFT OR RIGHT TURN'S.
check the power steering fluid make sure it is at full line and check the tension on the serpentine belt make sure it is tight and if these are all ok you may need a new power steering pump
Sep 24, 2010 | 2004 Kia Sedona
2002 mercury sable power steering hard to turn left or right has new power steering pump no leaks no sounds just hard to turn hardest when slow moving and parking
Bad steering rack, or bad spoolvalve,in rack. leaky pressure between cylinder & piston in the rack. Check A/C PRESSURE SWITCH,UNPLUG SEE IF CHANGES POWER STEERING EFFORTS.
Sep 16, 2010 | Mercury Sable Cars & Trucks
Steering problem
check your power steering belt. it may have broke or slipped off the pulley. if it seems ok check your fluid level. if it is still at normal operating level for hot or cold then your power steering pump may have just seized up and you may have to replace it.
Sep 19, 2008 | 2001 Chevrolet Tahoe
AM Auto Parts 1997 to 1999 Cadillac Seville SLS Power Window Switch Front Driver Logo
385 people viewed this question
Top AM Auto Parts Home Experts
Donni Steen
Tom Chichester
Are you an AM Auto Parts Home Expert? Answer questions, earn points and help others
