Would like to find out about delivery - Computers & Internet
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Yes you would definitely find out your place of delivery of product or item.
Whenever you ordered any product online then you must give a address for delivery then if your product will come then you must receive your item from that delivery address.
Know More:- Build Online Store In India
Posted on May 01, 2015
E000012-0106
The machine cannot be operated and the error code <E000012> appears on the display.
Cause and Solution
The delivery feeder unit may not be installed correctly. Follow the procedure below to install the delivery feeder unit correctly. If the error code persists after the delivery feeder unit is installed correctly, contact your local authorized Canon dealer.
Re-install the Delivery Feeder Unit
NOTE
  • You have to remove the delivery feeder unit and reinstall the delivery feeder unit correctly.
  • When you remove the delivery feeder unit, you have to turn the main power switch OFF.
  • Sending or receiving documents cannot be done when the main power switch is OFF or the power cord is disconnected.
  • If the main power switch is turned OFF, all jobs waiting in the print queue will be erased.
  • Documents received into memory and documents stored for delayed send will be retained for approximately 60 minutes after the power cord has been disconnected.
1. Turn OFF the main power switch and disconnect the power cord.
2. Open the front cover.
If you are using the stack bypass tray, close it before opening the front cover. Open the front cover gently holding the handle (A).
3. Push the levers (A) on both sides of the delivery feeder unit and remove the delivery feeder unit gently, holding it by the tabs (B).
CAUTION
Do not place any object on or touch the transfer belt (A) of the delivery feeder unit. You do not need to manually clean the transfer belt even when it is stained by toner, as the delivery feeder unit has a self cleaning function for the belt. Breaking the delivery feeder unit or damaging the transfer belt may result in misfeeds or deterioration in print quality.
4. Install the delivery feeder unit so that the protrusions (A) of the delivery feeder unit fit into the guides (B) and click into place.
5. Confirm that the triangle marks (A) on the delivery feeder unit are aligned with the triangle marks (B) on the machine.
6. Close the front cover.
Close the front cover gently holding the handle.
CAUTION
Be careful not to get your fingers caught.
7. Reconnect the power cord and turn on the main power switch.
Jun 22, 2015 | Office Equipment & Supplies
Need to get in touch with amazon put wrong delivery address
Go to your account, select your orders. where you see the item with the wrong address, select contact seller next to that item and contact them as soon as you can. If they dispatch to the wrong address before you contact them, it's your fault and you take the loss
Jan 22, 2015 | Home
What are the usual designs of mail boxes?
Letterboxes or mailboxes consist of four primary designs:
  • A slot in a wall or door through which mail is delivered (through-door delivery)
  • A box attached directly to the house (door-to-door delivery)
  • A box mounted at or near the street (curbside delivery)
  • A centralised mail delivery station consisting of individual mailboxes for an entire building
  • A centralised mail delivery station consisting of individual mailboxes for multiple recipients at multiple addresses in a particular neighborhood or community
-wikipedia
May 07, 2013 | Home
Have problem receiving the delivery report when it says the message is sent. I have made settings to receive the delivery report.Actually the problem is when i am sending the message with 0 prefixed to...
pending means not delivery yet just on processing. and remind that you have to use 0 or + then press the number accurately. if any message sent successfully then the delivery reports shows not the pending situation okey . thanks
Oct 26, 2010 | Nokia Cell Phones
How do i chage the fuel injector for a geo metro 1997 LSI?
REMOVAL & INSTALLATION Fig. 1: Removing injectors from fuel rail 84245032.gif
Fig. 2: Make sure injectors rotate freely in cylinder head 84245033.gif
  1. Relieve fuel system pressure and disconnect the negative battery cable.
  2. Remove intake air hose between throttle body and intercooler.
  3. Remove accelerator cable.
  4. Unclamp PCV and fuel return hoses from deliver pipe.
  5. Unclamp injector wiring harness.
  6. Disconnect injector coupler.
  7. Remove cold start injector pipe from delivery pipe.
  8. Remove vacuum hose from pressure regulator.
  9. Remove fuel feed hose from delivery pipe.
  10. Remove pressure regulator from delivery pipe.
  11. Remove delivery pipe with injectors.
  12. Remove injectors from delivery pipe. To install:
  13. Replace injector O-rings and lubricate with fuel. NOTE: Make sure injectors rotate smoothly. If not, probable cause is incorrect installation of O-ring.
  14. Check if insulator is scored or damaged. If it is, replace with new one.
  15. Connect delivery pipe with injectors.
  16. Install pressure regulator to delivery pipe using a new O-ring.
  17. Install fuel feed hose to delivery pipe.
  18. Install vacuum and fuel return hoses to pressure regulator and clamp securely.
  19. Install cold start injector pipe to delivery pipe using new gaskets.
  20. Install injector coupler. Clamp injector wiring harness.
  21. Install PCV hose to cylinder head.
  22. Install throttle position sensor coupler.
  23. Install accelerator cable and adjust free-play.
  24. Install intake air hose to throttle body and intercooler.
  25. Connect the negative battery cable.
  26. Start engine and check for leaks.
Jul 03, 2010 | 1997 Geo Metro
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
Unwanted delivery reports
try soft reset after unchecked msg delivery notification.
Jul 24, 2009 | HTC Touch Pro Smartphone
Samsung G600 - delivery reports
hi,
you need to go to messages > settings > text messages > sending options and then check the "request delivery receipt" box. however, it seems there may be a problem as many people have requested delivery reports and yet do not seem to recieve them.
hope that helps!
Dec 16, 2007 | Samsung SGH-e315
Computers & Internet Logo
457 people viewed this question
David Payne
David Payne
