Question about GE Refrigerators
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
We recently had a power outage which caused everything in teh fridge to stop working except for the inside lights. I decided to swap out the motherboard and that appeared to fix the problem, now the fridge and freezer arent cooling properly. I can hear stuff blowing and feel the air but its just not cooling down. what should i check or replace?
  • Fung Soong
    Fung Soong Apr 14, 2015
    I just removed the dover in the basck of the freezer and the coils are not frozen at all.
  • GE Master
  • 473 Answers
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Posted on Apr 16, 2015
I have a whirlpool gold fridge and its flashing the po code why and how do I make it stop
PO stands for Power Outage. The fridge lost power for some reason. On my fridge I just hit "acknowledge" and it goes away. I don't own a whirlpool. Here's a page that lists different instructions for multiple different fridges in order to reset everything and turn off the PO light. http://removeandreplace.com/2016/02/02/refrigerator-display-panel-is-blank-not-working-how-to-reset/
Refrigerator Display Panel Is Blank Not Working How To Reset
Nov 15, 2016 | Whirlpool Refrigerators
We recently had a power outage, now the interior light is flashing and the fridge is not cooling
Try resetting the fridge and freezer temp, fridge 4 deg C freezer -18 deg C turn the unit off at the power socket leave for a minute then turn on be fore resetting.
Mar 03, 2016 | Liebherr Refrigerators
I have a ge gsh25jfta bb fridge.the power cut off one day and the display would not work, I messed with the back of display and it started working. Power went out last night and I can't get it to start...
Just check if any voltage is coming to the cooling aggregate. If so, and the aggregate does not run, it must be defect. When you can't measure the voltage on the aggregate, follow the leads back to the thermostat and other switches in the way.
You also could start from the mains, but I thought you had checked that already.
Feb 18, 2015 | GE Refrigerators
Hello I have an HMCF7W1 Magic Chef freezer, after a power outage the power light comes on, but the Run light will not turn on and everything is thawed. What can I do?
Perhaps the power outage, was caused by your freezer?
When you think a reset would help, the run light should come on, after a little while. But perhaps only the thermostat is defect.
Be aware there can be so many causes, and none has to be related to the power outage, for your freezer not to work.
It would be virtually impossible to see what is wrong, from a distance. Better try to bring the food to a working fridge and call a tech to solve the problem.
Feb 08, 2015 | Magic Chef Freezers
Re: Lights and fan problems for Sub Zero 532 Side by side refrigerator.
First of all if you're condensor motor is controlled by electronic control board varyable speed type you might want to think about looking at replacing the control board. But first I would take a voltmeter test to see if the fan motor is getting enough voltage. If the voltage varies with the temperature inside the box then you have a controller. If the voltage remaind constant (120) and the motor still slows down yoy have a bad fan motor. As far as you're like the problem goes the only thing I can think of besides loose wires or bad switch.would be if it operated off the same control board.
Dec 10, 2012 | Refrigerators
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
Gsh25jfta. defrost heaters not working. defrosted with heat gun and ran normal for 24 hrs. evaporator iced up again. any ideas whats wrong if the heaters check good.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 26, 2010 | GE GSH25JFT
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
