Question about 1A Auto Parts 1983 Cadillac Deville Thermostat 195 degree
95 deville brake warning light stays on after start Used to go off after stopping and re shift to park Now stays on
Wont shift
possable bad brake lite switch. also check fuses.
Nov 21, 2012 | 1995 Ford Taurus
95 e 150 odometer,brake lights and wont shift out of park
Sounds like two different problems - the brake light switch and the speed sensor in the transmission.
Does the speedometer work ?
Sep 24, 2012 | Ford E-Series Van Cars & Trucks
Gear shift stays in park and abs esp and asr lights on
1) try to use the self diagnose.
2) place ignition swtuch in the start position, the lights coming on
3) engine starts, the brake light sould turn off inmediately. the ABS ligth will illuminate for aprox 6 seconds.
4) test drive the vehicle at speed above 20mph for a few minutes. during the test the both test lights should remain off, if any one of the warninign light utron, take note of the condition.
5) stop the vechicle using the braking pressure.both light should remain offf during the stopping procedure.
60 place the gear selector in to PARK, and observe the warning lights, they should both be off.
God bless you
Jul 09, 2012 | Cars & Trucks
1996 mercury sable starts after being charged but next day is dead again
there is a Safety Recall Notice
01S08Grease used on the adjustable pedal assembly may enter the brake lamp switch and contaminate the contacts. This may cause one or more of the following symptoms to occur:
-Brake lights stay illuminated or are inoperative.
-Shift Interlock disabled (will be able to shift out of "Park" position without depressing the brakes.
-Speed Control will not activate.
-Cannot shift the vehicle out of "Park."
-ABS Warning light illuminates on vehicles with ABS
-Battery Discharged."
Jun 11, 2012 | 2003 Mercury Sable
Why does my traction off light come on?
You either have a problem with your engine control system, the traction control system, or you are not in the correct gear. See the explaination below. This is from the 2000 Chevrolet Cavalier Owner's Manual.
TRAC-OFF LIGHT
... If you turn the system off by moving the shift lever
to FIRST (1) or SECOND (2), the warning light will
come on and stay on. To turn the system back on,
move the shift lever back to a position other than
FIRST (1) or SECOND (2). The warning light
should go off. (See "Enhanced Traction System"
in the Index for more information.)
 The warning light will come on when you set your
parking brake with the engine running, and it will
stay on if your parking brake doesn't release fully.
If the transaxle shift lever is in any position other
than FIRST (1) or SECOND (2) and the warning
light stays on after your parking brake is fully
released, it means there's a problem with the system.
 If the traction control system is affected by an
engine-related problem, the system will turn off
and the warning light will come on.
If the Enhanced Traction System warning light comes
on and stays on for an extended period of time when the
transaxle shift lever is in any position other than FIRST
(1) or SECOND (2) your vehicle needs service.
Aug 08, 2011 | 2000 Chevrolet Cavalier
95 Saab 900S brake lights stopped working also have an issue getting the transmission out of park
Most likely the brake light switch at the top of the brake pedal has failed
OR....
Your HAZARD / Tail fuse has blown.
Underneath the dash at the top of the brake pedal locate the brake light switch. Remove the connector / wires on the back of the switch and then jumper across the 2 pins to make the brake lights come on. Start the car with the brake on and try shifting the car out of park.
Thanks for choosing FixYa,
Kelly
Jan 19, 2011 | 1995 Saab 900
Left the keys in the ignition adn had AAA jump it. Now the T/C with a slash through it came on and the light that says low engine power. The car starts really rough and has no power when u drive it. WHats...
T/C light = Traction Control
Could be something going on with a wheel speed sensor. You'll have to have the ABS/TCS controller scanned for any stored trouble codes to see why the controller is turning on the light. The code(s) might help you to determine what part of the system is faulting. You'll have to take it to a shop that has a high end scan tool.
If the TC light is on, chances are there is a trouble code set and stored in the computer. You need to determine what the code is. If you take the car to a nationally recognized parts store, most will scan the computer for free, so there is no money out of pocket for you.
Actron also makes a ABS code checker called BrakeScan. Don't know how good it is, but it might be good for a DIY person.
TC Explanation:
If your vehicle is equipped with the Enhanced Traction System (ETS), this warning light should come on briefly as you start the engine. If the warning light does not come on, then have it fixed so it will be ready to warn you if there is a problem.
If the warning light stays on, or comes on when you are driving, there may be a problem with your Enhanced Traction System and your vehicle may need service. When this warning light is on, the system will not limit wheel spin. Adjust your driving accordingly.
The Enhanced Traction System warning light may come on for the following reasons:
If you turn the system off by moving the shift lever to FIRST (1), the warning light will come on and stay on. To turn the system back on, move the shift lever back to a position other than FIRST (1). The warning light should go off. The warning light will come on when you set your parking brake with the engine running, and it will stay on if your parking brake does not release fully. If the transaxle shift lever is in any position other than FIRST (1) and the warning light stays on after your parking brake is fully released, it means there is a problem with the system. If the traction control system is affected by an engine-related problem, the system will turn off and the warning light will come on. If the Enhanced Traction System warning light comes on and stays on for an extended period of time when the transaxle shift lever is in any position other than FIRST (1), your vehicle needs service.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL are appreciated for answering your FREE question.
Oct 09, 2010 | 2006 Chevrolet Cobalt
Three intermittent warning lights
I would think a sensor is going bad , but ,without testing that is just a guess , just like the dealer tech , assuming it's a module or a fuse ! With the light's on checking for DTC'S - diagnostic trouble codes would be a real good first step . The dealer tech should have hooked up the Tech 2 scan tool an checked codes an look at sensor data parameters ....
May 07, 2017 | 2003 Cadillac Deville
1A Auto Parts 1983 Cadillac Deville Thermostat 195 degree Logo
495 people viewed this question
Top 1A Auto Parts Electronics - Others Experts
Mark Magill
Mark Magill
Lawrence Oravetz
Are you a 1A Auto Parts Electronics - Other Expert? Answer questions, earn points and help others
