Question about Epson Stylus DX4450 All-In-One InkJet Printer
Why is my ink light on a steady red? I have new Epson ink cartridges in it and it has also been cleaned.
    Sergeant:
  • 305 Answers
Sometimes the printer does not recognize that you have changed inks, however check that they are in correctly and are full, check status monitor and check ink levels on screen. As a last resort, turn printer off wait a few seconds and then turn on again.
Posted on Apr 14, 2015
Have not used my Epson R1800 for almost 6 months. When I turn on the power the printer head, with the cartridges, stayed at the very right end, not moving. The paper and ink lights flash and the head just...
Your User's Guide is available here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
After leaving the printer inactive for a extended period you should expect the ink cartridges to be dried up and the print head 'gummed' in place.
You will need to refer to page 82 of the pdf, Cleaning the Printer.
As part of cleaning remove the existing ink cartridges and while the cartridges are removed try and clean the print head of any ink residue. Note that if the red light is on or flashing above an ink cartridge the printer sees it as empty (dried up).
The print head will not move if ink cartridges need replacement; replace ink cartridges according to the red lights, likely all. Press the ink button to see if the printer will begin the charging cycle. If all is well the green power light will stay on and the red ink light will go out.
If you do not get this desired outcome try Cleaning the Print Head, page 73 of the User Guide. Hold down the ink button when the red light is off for 3 seconds. Run a nozzle check pattern; if nozzels are not printing a clean pattern, repeat this process up to 3 or 4 times.
Feb 03, 2011 | Epson Stylus Photo R1800 InkJet Printer
We changed the ink and the red light and green
Some times you need to find the epson tools that comes on the CD to reset the printer. If you have upgraded the computer you may need to update your drivers at the epson sight.
Once you have opened the epson tools try cleaning the print heads.
then it should reset the inking system to default and read the new cartridges. If this doesn't work try shutting down the printer and removing the ink cartridges, restart the printer and allow it to find no cartridges the go through the process of reloading the ink cartridges again and cycle the printer.
If this doesn't work you may need to try and find a cleaning cartridge for the print heads. Since the printers always check to see if ink is getting to the print heads if there is no ink flow it will always come up like there are no ink cartridges installed.
Hope this helps
Make sure paper is in properly they can be very picky about that.
Try turning it off wait three minutes and turn back on.
Then
Push Paper refill button Wait for cycle and see if paper light stays off if so...
Push the ink button
Sep 18, 2009 | Epson Office Equipment & Supplies
Replaced a new cyan cartridge for Epson 1400. Printer ignored it.
Ye of course it could be faulty and Epsons are sometimes very fussy about using third party carts. Get it replaced at your store, try a different brand or buy a genuine Epson cart if you can afford it.
Jul 04, 2009 | Epson Stylus 1400 InkJet Photo Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
The red light on my epson printer wont turn off and it wont print,ive changed both ink cartridges and still no change.
Hi
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
Hope this helps
May 13, 2009 | Epson Stylus C40UX InkJet Printer
Cannot recognise ink cartridges
open the door cover of your printer and then clean the tab circuit where the cartridge is installed ...and also clean the tab circuit of the cartridge...maybe it suffered loss connection..
May 12, 2009 | Epson STYLUS R230 InkJet Photo Printer
Problem printing with epson stylus office t30
Hi.
Please try to uninstall and re-install the drivers on your laptop now that the ink light is not on steady anymore.
As i see it, the issue is hardware. The printer will not allow you to print anything if any cartridge is not recognized or any cartridge is out of ink. The red indicator light on the printer that was on steady while your installing the drivers on your laptop, indicates that there was a cartridge that was out of ink.
May 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Both the Red and Green lights are burning steady
k, heres a long 1...=P
>the green light is just your power light, if it is glowing, its on, if its blinking...its receiving a job/replacing cartridge/charging cartridge/or cleaning heads
>the red light being constant on is any of the following...
-ran out of ink, ran out of paper, or has a paper jam.
hope this helps.
PS: re-manufactured cartridges can not always be trusted...some companies accidentally send empties...simple mix up im sure,we're all human after all, but be on look-out.
Feb 08, 2008 | Epson Stylus C60 InkJet Printer
Epson 880
if red ink light is still on, check that the lid for the cartridge is fully seated
Dec 19, 2007 | Epson Stylus 880 InkJet Color Printer
Epson Stylus DX4450 All-In-One InkJet Printer Logo
139 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
