Question about Vizio Televison & Video
I have a 42" Vizio TV VO420E. The TV doesn't turn on anymore. The standby orange light stays on but when I press the power button the white light doesn't come on. What might be wrong?
djchillsnyc
  • 151 Answers
SOURCE: Power is there, but TV won't turn on
stored voltages are high no touching these circuts becuase they hold charges and alot of screws.
fualty capacitors you say after a while it stays on theres a full charge in the unit theres some type of discharging effect on the set after its off for a while. voltage goes to low or unstable after it is off for a while. your better off getting the service docs for this set if you want to diy..other wise get a tv tech to check it for you. hope this helps
Posted on Jun 25, 2009
stonephoenix
  • 563 Answers
SOURCE: Vizio VX32L The screen goes white,no response from buttons
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 28, 2009
milkburp
  • 416 Answers
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Posted on Mar 14, 2010
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
SOURCE: My Tv wont turn on, the standby light stay orange,
Hi, l had the same problem. HAD !!
l bought a universal remote control (5 euro), but unfortunetly no codes for Acer in it.
Then l did the setting up by auto search and YES : there was a code. But, wheeehh, it did not work.
A little bit sad l took the Acer control and guess what: it worked again!!!!! l guess the TV had a total reset, and l use only the Acer remote control now.....
Female and blond!
Posted on Nov 26, 2010
I plug in my Vizio TV and it will not power on however the orange light in the front is flashing.
Sounds like mine I replaced the Bridge Inverters ( easy job ) , and worked great after that. I got mine from Shop Jimmy dot com paid $85 cheap fix not like $300 - 500 ! you may pay for repair man.
Jul 23, 2014 | Vizio VO420E 42 in. LCD TV
I have a Vizio 42 in LCD, model VO420E. The TV makes a loud screeching noise, the screen goes crazy and then shuts off and starts again. There sometimes is a pop. Other times the TV just makes the POP...
Hi well what's happening is that the "Protection circuitry" in the SMPSU has/is detecting a potentially catastrophic fault, and to stop a fire AND EXPLOSION OR INDEED BOTH, IS ATTEMPTING TO SHUT THE SET DOWN FOR SAFETY REASONS, HOWEVER AFTER IT SHUTS DOWN, THE "FAULT" APPEARS TO "GO" AND THEN THE SMPSU STARTS UP AGAIN , ONLY TO DETECT THE FAULT AND SO ON... USUALLY ENDLESSLY OR UNTIL COMPLETE FAILURE OCCURS.
What to do, well in all reality DIY is NOT feasible unless one has LOTS of experience, test gear, tools, isolation transformer, and a service manual. So, contact the local or head office from VIZO, ask them for a referral to an authorised service center, hopefully a local one? in any event, make face to face contact here and ONLY ask first for a "Quote" as to prospective costings and go from there, this way at least you can make up your mind as to repair or replace?
Sep 25, 2011 | Vizio VO420E 42 in. LCD TV
I have a vizio 42 plasma model #vp422hdtv10a when i try to turn on the unit it makes 2 click sound like it is turning on but nothing happen. i open up the unit to look for popped capacitors but i see non...
I am having the same problem with my 42" vizio tv. When plugged in the standby light is on and when turned on the light switches from orange to white, however there is no sound and no picture. I am hoping to find what is wrong with it so i can get it fixed. Or atleast by the correct parts! I have only had my tv about 2 years
Aug 28, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio VO420E 42 in. LCD TV -- Less than 3 months old. Picture slowly darkens and then goes out all the way. Sound stays on. Picture goes out. We turn the TV & cable box off, wait 30 seconds, turn...
the problem its the main board of the tv not the power supply board.the main one controls all your imputs tv av component etc the cheapest place to find it its at www.shopjimmy.com cheaper than the manufacturer and those dudes that you find online that charge an arm and a leg just to come and just repair your old main board mine as well buy a new one at this site for less ok and you are welcome
Apr 13, 2010 | Vizio VO420E 42 in. LCD TV
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Mar 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
Orange light will not stay on when the tv is off.
replace the power cord, do not use tv till you replace the power cord ok, you will eventually short circuit the tv or even worse blow the internal components
Jun 22, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
65 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
