Question about Refrigerators
How does the drain tray that sits on top of compressor come off or out.
Getting strong odor from drip tray
  • Refrigerators Master
  • 932 Answers
Gerard,
Sometimes they are bolted onto the top, but many times they are welded in place and you cannot remove them. I would suggest putting some warm soapy water in the pan for a few minutes and then vacuum it out if you have a wet vac, other wise just put towels or rags or a sponge in there to soak up the water and just wipe it out as best that you can. Hope this helps!
Posted on Apr 14, 2015
Customer service phone number???
Clean the hose out at the back of fridge going down into catch tray, it probably blocked.put vanilla essence in fridge to get rid of odors.
Dec 23, 2014 | Refrigerators
Our refrigerator had bad odor due to electricity failure. I cleaned the entire refrigerator and it still smells bad. Is there a drip tray or another place I can see if there is any drip that I can pull out...
msot have a drip tray. pull the botom cover under the door off too see it. Try putting a cup of fresh coffee grounds in for a day works better than baking soda
Sep 05, 2011 | Kenmore Refrigerators
Strong gas odor by gas tank but I don't see anything leaking. I need to know how to remove the back seat to get to the tank.Any ideas or previous problems w/this model?
Go to gas station and fill the tank all the way. Don't move the car for a minute and look at the ground for gas drips.
Apr 17, 2011 | 2001 Saturn L-Series
We have the Penguin 630515 with the heat pump ..we get a strong musty odor when we use the heat pump or the AC... we have sprayed Lysol into all the duct work and still have it. We have had the roof...
There is a condensate tray under the coil. There should also be a drain hose or port that could be clogged. Take off top of AC unit and pour a 10% solution of bleach and water over coil, follow flow of water to drain and make sure it is working. Pour a very small amount first otherwise you will have water everywhere.
Jan 23, 2011 | Dometic Rooftop RV Air Conditioner
Refrigerator has spoiled meat odor. Can't find
drip tray is under unit remove toekick and check if pan heater is connected
Nov 06, 2009 | Amana ABB1927DE Bottom Freezer...
Odor in my home
There may be mildew on the condensor (the big radiator inside the attic) and/or the water drip tray underneath it may not be fully draining causing the odor.
Your senses get "used" to the odor. Your brain will mask it so that you will be able to sense other odors.
Replace the return air filter more often. clean the airway taht the filter covers. Spray Lysol will help temporarily.
You must check the condensor & water drip pan.
Sep 28, 2009 | Heating & Cooling
Strong odour coming from non-removable tray under new fridge
do not frustrated .firsly you should look for any THING THAT block the drip tray from geting out. usually it can be pulled out by PUSH ASIDE THE DRIP HOST SOMTIMES BLOCKING THE DRIP TRAY MOVEMENT IN OR OUT.
LATER CLEANED THE DRIP TRAY & REINSERT IT BACK TO ORIGINAL SITE
Sep 24, 2017 | Kenmore 44273 Side by Side Refrigerator
There is a sour smell that comes out of the bottom front of my fridge. It is a side by side Frigidaire with an ice maker. It does not smell inside, only the exhaust air and it smells up my kitchen. I have...
There is drip tray underneath the unit. Depending on model, there are multiple ways to access. This tray needs cleaning regularly. Once clean, sprinkle in Baking Soda to keep odors down. Cleeaning this on a regular basis is the only way to beat this smell.
May 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Strong odor of gasoline in passenger compartment
for sure there is fuel leafing but you have to locate from where, usualy this can happen from a leaking fuel pressure regulator and this can drip on the hot manifold and cause it to boil and smell the whole car secondly the vapor canister could be damaged and cause the same problem
Nov 19, 2008 | 2004 Nissan Quest
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
