Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I installed a new Honeywell RTH74/75 series thermostat and it has the incorrect day displayed.
Today is Tue and it displays Thu. I have read the Operating Manual and quick installation guide with no luck.Some functions do not appear in the display to get to the DAY change function to change the day. Any suggestions would be great. If I take the batteries out and uninstall the thermostat, will it reset back to factory settings?
    Problem Solver:
  • 17 Answers
It calculates the day based on the year/month/day of the month in the system setup. The first time it is powered on, it asks for year month & day of the month. After that you can get back into setup by: press & release the left button/ then press & hold the cente button until the screen changes (5 seconds). Now you see a number in the middle (function) and a number on the right (the items you can set). use the center (next) button to move up through the functions. 0120 is the 1st half of the year it should be 20 - function 130 is the second half of the year 15. ( use the up/down arrows to adjust if needed). 0140 is the month and 0150 is the day of the month. after you finish correcting the press the right button to save & exit.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2487ES.pdf
Posted on Apr 17, 2015
  • 42 Answers
Yes it will reset itself when you do that, it really should not be too hard to figure out the day.
Posted on Apr 15, 2015
  • anna gunns
    anna gunns Apr 15, 2015
    And then also go to the reset button, the master and reset it to factory.
  • 96 Answers
SOURCE: Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Posted on Nov 25, 2008
  • 9 Answers
SOURCE: -AC appears in the display of chronotherm III
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
Posted on Dec 12, 2008
SOURCE: Battery Issue
This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
Thank you and warm wished for the new year!
Mary
Posted on Dec 30, 2008
  • 116 Answers
SOURCE: how to remove thermostat cover to replace
the cover pulls off if it has a green screen then most likely takes batteries if does not light up then no batteries with a small piece of insulated wire jump from green to red if indoor fan does not come on then transformer bad
Posted on May 15, 2009
  • 19 Answers
SOURCE: permanent hold message on thermostat
press run program.... from there, set the schedule for maximum efficiency. permanent hold only shows up after the hold button has been pressed 2-3 times. If this does not fix the issue, there is a master reset button on the thermostat that will set all settings back to factory default.
Posted on May 17, 2009
Where am I suppose to vote? My address is 7824 Daniel Dr N Richland TX 76182.
We are in California but here is what is listed.
645 Grapevine Highway Hurst, TX 76054 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 B 828 West Harwood Road Hurst, TX 76054 Directions Closed · Opens 7 AM MonHours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Last day to vote early at this location is Nov 3 C 5350 Basswood Boulevard Fort Worth, TX 76137 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 100 Main Street Colleyville, TX 76034 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 6801 Glenview Drive North Richland Hills, TX 76180 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 1100 Bear Creek Parkway Keller, TX 76248 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 700 Mary Drive Hurst, TX 76053 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 2424 Forest Ridge Drive Bedford, TX 76021 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 3201 Friendly Lane Haltom City, TX 76117 Directions Closed · Opens 8 AM FriHours this week Today 8 AM-5 PM Fri 8 AM-5 PM Sat 7 AM-7 PM Sun 11 AM-4 PM Hours week of Oct 31 Mon 7 AM-7 PM Tue 7 AM-7 PM Wed 7 AM-7 PM Thu 7 AM-7 PM Fri 7 AM-7 PM Last day to vote early at this location is Nov 4 201 North Ector Drive Euless, TX 76039 Directions Closed · Opens 8 AM Fri
Oct 27, 2016 | Cars & Trucks
Honeywell thermostat is locked in the off position
sounds like keypad is programmed in lock position read manual for set up to activate keypad again.
Nov 25, 2012 | Honeywell Programmable Thermostat Heater
Hey Very Strange Issue
Send me the screen shorts if you can not send me through fixya then mail me at geekjango@hotmail.com.
I'll get back to you ASAP.
Jun 22, 2010 | Yahoo Mail
Honeywell TH6000 series thermostat does not turn Fan on.
It's one of two issues; either the wiring to the thermostat is incorrect, or possibly you have an open ground. Depending on your system the wires at the thermostat end might have to pair up on one lead. go to where your unit is and look at the schematic for the control board, it will let you know what color you are looking for on the blower lead -- then make sure the corresponding color matches at the thermostat. Knowing the make and model of you unit and the board on it would allow me to be more specific, hope this helps you out some in the meantime.
Jun 17, 2009 | Honeywell Focus 6300B 5-2 Days...
My thermostat quit working
Does it have batteries that need replacig. I think so. good luck.
May 31, 2009 | Honeywell Programmable Thermostat Heater
Rth230b honeywell display screen faint
Mike, The static electrical spark probably 'zapped' the Rth230b Honeywell Display unit. If you have already tried removing the power (batteries) from the unit and after waiting several minutes; reapply the power (batteries). If the problems remain unchanged, then it is time to replace the Display unit with a new one. The static electricity problem is problematic and the only way to prevent the same problem from recurring is to discharge yourself before touching the Honeywell Display. As you walk across the room which (probably has carpet), causes the static electricity to build up on your body and then discharges itself through the Display unit when you make contact with the Display unit. You might try coming to a complete stop and attempt to discharge the static charge on your body by touching the wall first with one hand for a second before touching the Display unit with the other hand. Naturally, cold weather with low humidity makes the static electricity worse. Hopes this helps you. Henry
Feb 04, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
135 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
