Question about Titan Impact 640 High Rider Airless Paint Sprayer
How to reset anti theft lock code if you don't know the current code
How to reset anti-theft on a 2000 alero
The security, antitheft or lock picture/icon is a visual indication that something in the car's antitheft system is failing. In most GM cars and trucks there is a hidden system that most people are unaware even exists. From the moment you put your key in the ignition, there begins a constant line of communication between your key's security chip or transponder, to the ignition's lock cylinder, and then to the car's TDM (Theft Deterrent Module). These 3 parts are in CONSTANT communication. If the key is in the ignition, then these parts are sending signals to each other. The security light illuminates when that signal gets broken, even just for a second. When the signal breaks, the car misinterprets this as an attempt at theft and goes into antitheft mode. The car thinks its being stolen or hotwired because it is not getting that signal from YOUR specific key. This is why the security light turns on and shuts down your vehicle. This link explains it pretty well.
http://www.diy-gm-security.com/
Apr 04, 2015 | 2000 Oldsmobile Alero
99 honda accord i need anti theft code can anybody help me
alot of cars with anti theft can be reset by locking and unlocking the drivers door with the key give it a shot
If you need further help, reach me via phone at https://www.6ya.com/expert/joe_a79eed575e8dd8b3
Mar 31, 2013 | 1999 Honda Accord
2003 f150 turns over but wont crank, also theft light blinking fast
Usually means the sensor in the lock cylinder is not reading the code in the key.
If the pass key system does not get the right signal from the key the truck will not start.
You might try taking the key off your ring - put it in the lock and turn the switch on - but don't crank it for at least a minute.
There are procedures to reset the anti-theft online - - if you do a search for resetting anti-theft F150 you can read them.
Jul 26, 2012 | Ford Cars & Trucks
NOKIA E5 ANTI-THEFT LOCK CODE FORGET
nokia e5 antitheft is locked and now asking for security code but i forgot so help
May 30, 2012 | Nokia Cell Phones
Is the anti-theft deterrant system the same system as the engine immobiliser or are they completely different?
Hello Jaclyn... Your Camry has an "engine immobilizer" designed to prevent "hot-wire" starting incorporated into the anti-theft system...This was standard on the XLE, & an available option on the LE. When the battery cable came off the immobilizer lost it's memory & is not reckoning the chip in the key. Try locking and closing all the doors. Then unlock the drivers door with the key. Repeat this several times, also tap the brake & gas pedal. If this does not help the dealer will have to reset it by the vehicles VIN number.
I hope this information is helpful.
Dec 01, 2011 | 1998 Toyota Camry
Lights were left on killed battery then anti-theft light came on and now the car wont start do we need to reset the compter?
should be able to call the dearlership to get a code to reset the antitheft system unless u know it
Mar 04, 2011 | Saturn Ion Cars & Trucks
The anti-theft code on our 1994 BMW 740iL was plugged in after the battery was replaced + that new code has now disabled the car, as you would want with an anti-theft system. Now, no one knows the code...
For 1995 and older models.
Simply lock the door with the key from outside of the car,then unlock it. Then start the car. I think this lets the computer know that someone who has the correct key is attempting to start it.
Nov 16, 2010 | 1994 BMW 7 Series
Battery died and anti theft code went into effect
Call your Volvo dealer with the VIN number. They can give you the code and advise if you can reset it yourself or if you will have to take it in.
Jul 19, 2008 | 2000 Volvo S40
Titan Impact 640 High Rider Airless Paint Sprayer Logo
220 people viewed this question
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
