Question about Electrolux ICON Built-In Microwave Oven
How do I fix microwave
Microwave has power, internal light goes on, when you start it, timer counts down and interior light goes on, but oven makes no sound, turntable doesn't move and food doesn't heat.
  • Electrolux Master
  • 473 Answers
I doubt you have a Hi voltage problem or fuse problem. My guess if the microwave is not running is that one of the door interlock switches is bad or out of adjustment. Make sure one of the door hooks didn't break off also.
Posted on Apr 15, 2015
    Master:
  • 369 Answers
A microwave oven uses a device called a magnetron. Driven by a Gunn Diode this device can generate insane amounts of Microwave radiation. They also use VHT (Very high voltage) in the order of thousands of volts to energise the circuitry. In short they can be lethal, that is... unless you enjoy being cooked by being steam broiled from the inside out of course?
So you can understand my trepidation when you have to ask how to fix it on an support forum. If you are happy with ripping a $30 piece of equipment to bits to repair it and potentially not having any more children then it sounds like the power supply or rectification unit is failed. If you're luck there will be an internal fuse which has got tired and popped, if not its probably a bin job as the parts are not easy to get and when you can get them they are almost more expensive that buying a whole new unit.
Posted on Apr 14, 2015
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
May 10, 2014 | Microwave Ovens
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
GE JES1358 Microwave: lights are on but doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 06, 2010 | GE JES1358 Microwave Oven
Frigidare FMV156DCG Overheated?
I have the same problem....I think its the door switch because if you lift up on the door handle while you've got the timer counting down, it should start the microwave hum....
Apr 26, 2009 | Electrolux Microwave Ovens
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Electrolux ICON Built-In Microwave Oven Logo
62 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
